2013/09/23
canany one help with my issueÂ
I have a new cube u35gt2 and i am trying to flash it with this cleaned up 4.1.1 rom
I am using win 8 and I however cannot get the pc to recognise the tablet so I can install the rockusb driver.
I have enabled usb debugging in developers tools and I have tested all my otg cables and usb ports. Same result :
USB not recognised.
The last usb devices you connected cannot be recognized or has malfunctioned.
so in device manager it has a an exclamation mark and I cannot install drivers to it
help I am at my wits end
2013/09/23
Thanks,
but it it's been resolved. I did a heap of research online. I had suggestions of powering off my PC to removing the battery to updating my USB 2.0 Drivers.Â
What nonsense...
so it turns out, and to any one who sees this...
chinese tablets like the Cube  u35gt2 need more than normal power to run in recover mode connected via a OTG cable. The usb ports on a laptop just don't have the power at times. So windows basically says the device has malfunctioned.
the device will show up as unknown but you can't install the drivers.
So solution:
plug it into a desktop PC. The power supply to the USB is what it needs.
i had to go to a neighbour to figure this out.Â
2013/09/23
phb1993 said
u35gt2 have a cube and I have problems with the audio when I put the headset to push till the end the sound is "weird" and all other forms only works one side of the headset, anyone have this problem? know how to solve it?
Don't use an iphone or similar headset. Just a standard stereo headset. It's the additional band for the mic that puts the stereo out of line
2013/11/06
Hello. I've just installed kasty-cube_u35gt2-411-104_20130710-rooted4 rom on my U35GT2.
It works very well, even better than before the original firmware (official 1.04).
Wifi works better.
Antutu score with original firmware was approximately 18500 and now 19500.
So thank you for this rom !
And I have some questions : which recovery is in kasty-cube_u35gt2-411-104_20130710-rooted4 ? Stock recovery, normal, CWM, TWRP ?
Because i have a problem with SuperSu : In this rom there is with SuperSu 1.41, when I went to Google Play i updated SUperSU (1.65). When I opened SuperSu after this update, there was a message asking to update the binaries. If I choose "ok" another message appears and ask to choose betwenn two selections : "normal" or "TWRP/CWM". What do I have to do ?
Thank you,
Acube
138 Guest(s)
Devices in use: Desktop (129), Phone (9)
