[ ROM ] Cube U35GT2 Android 4.1.1 custom root firmware version 1.04 (2013/07/10)
Thanks Received: 268
2013/08/06 - 13:58
the system partition is increased to 512 MB ( more default application can be used as default system apps, you just need to copy them in the app folder, and set the permission properly)
The stock firmware has the system of ~370 MB
aleitaly
2013/08/09 - 06:56
I updated my u35gt2 with this firmware and it works perfect. Thank you very much
Do you have any plan on new firmware with android 4.2.2??
Ale
Phelec
2013/08/09 - 23:14
Firstly, I would like to thank globula_neagra for his help with understanding the firmware flashing process. I was able to enter the correct mode. However I have not upgraded the firmware as yet. This is a brand new unit (under warranty) and I want to check everything else is ok before modifying.
This Cube U35GT2 suffers from poor wifi range. I noticed rc4race mentioned the antenna could be improved. Is everyone else noticed this problem. Our wifi is at one end of the house while we use our netbooks, ipods and now the Cube at the other end of the house. The Cube is so fussy as to how you position it. My son also takes the cube to school and suffers the same problem there.
I noticed Cube suggest updating the firmware to fix this. Does the firmware mentioned here help in this respect?
Can anyone suggest a help. Thank you.....
aleitaly
2013/08/10 - 07:45
@Phelec
I diddn't see any improving after i install the new firmware.
Cube in general is not very strong on wi-fi from my experience.
tanyo
2013/08/22 - 14:18
Installed the Rom 2 weeks ago on U35GT2. Works very well so far. Only bug I noticed is BT not working properly. It pairs but later doesn't send/receive . Will test the HDMI soon.
Hope next ROM update will fix it....
Many thanks to tghe developers
jptablet
2013/08/23 - 01:04
I installed this ROM and everything is running perfectly so far.
WIFI range was improved for me, not much, but I can hardly connect to WIFI neworks that I didn't be able to connect before.
One detail regarding the flash process(using Rockchip Batch Tool 1.7), it was a little difficult, the initial part, to be able to install the drivers and have the "green light" at Rockchip tool to do the flashing. I needed to activate debug mode, shut down the tablet, connect through USB to the computer, and only then turn the tablet on with the +(volume) pressed. After that, everything runs smooth.
tanyo
2013/08/27 - 09:35
Just to confirm that HDMI works fine, although highiest resolution is 1280x720 not 1920x1080.
Wifi  range is not great ( all China tablet suffer  that) , BT still not working.
Some noticeable lag even in simple games like Freecell compared to my old HTC Desire.I noticed  while  I
download torrent tablet become very busy so overall perfomance is affected quite a bad.
OTG USB accepts flash drives.
2013/08/27 - 11:58
You use the tablet to download torrents ? :) Don`t expect on a big life from the nand
vhalko
2013/08/28 - 18:11
thank you for this rom!! it works flawlessly up to this moment ..
one question though .. where can I download the original cube roms ... I've tried at http://www.51cube.com but I'm getting nothing :-\
Metalazzo
Forum Posts: 29
Thanks Received: 5
2013/08/28 - 19:56
4.2.2 firmware is released by Cube.
Can we expect a custom version ?
0tomar
2013/08/28 - 20:16
Please, can you send link for update? I can not find update to 4.2.
Metalazzo
Forum Posts: 29
Thanks Received: 5
0tomar
2013/08/28 - 20:23
Thanks a lot. Have you tried this rom?
Metalazzo
Forum Posts: 29
Thanks Received: 5
2013/08/28 - 20:32
I'm waiting for a clean rooted version (without any chinese apps) as I don't know how to mod a ROM :)
2013/08/28 - 20:56
Yes you can ! Wink
Should be uploaded tonight.
124 Guest(s)
Devices in use: Desktop (119), Phone (5)
