Here is an Android 4.1.1 Jelly Bean rooted firmware for the Cube U35GT-W tablet based on latest Cube official update version 1.04 released 2013/05/26Â
(U35GT-W_V1.03_20130614.rar)
Build information:
Kernel:Â Linux version 3.0.36+ (cb@cb-eyes) (gcc version 4.4.3 (GCC) ) #364 SMP PREEMPT Mon Jun 3 11:41:34 CST 2013
Android 4.1.1 JB:Â rk30sdk/rk30sdk/rk30sdk:4.1.1/JRO03H/20130503.175606:eng/release-keys
- root with latest SuperSU version 1.34 (free version)
- increased space for application (/data partition) to 4 GB
Download:Â kasty-cube_u35gt_w-411-103_20130614-rooted4.zip
Please flash with Rockchip Batch Tool 1.7, use Restore button.
Please report any problem with this firmware, I can't verify this custom firmware works as I don't have anymore a Cube U35GT-WÂ tablet to test the custom firmware.
2013/06/18
Im a bit new to all this but the driver file is in a folder that downloads when you download the ROM. I plugged Cube in initially and the laptop installed the rockchip drivers automatically but the Cube driver doesnt.... I saw a posting on another forum (flash my droid or liliput maybe???) that described how to go into devices, find the Cube ("unspecified" or something similar)... you then have to go in and manually load the driver using the "have disk"option.... you then just browse to whereever you extracted the ROM to and open up the driver folder, and install the appropriate driver for your laptop... mine is a 64bit..... Hey if I can do it with not computer knowledge..... it must be easy.... good luck
The following users say thank you to marcoolajames for this useful post:
julz24lageman said
I put update.img on a sd card en put it in the cube ug35gt-w.Make the installation and now the tablet does nothing. the screen is black and will not boot.
is still a possibility there? or I have a serious problem?
2013/08/19
is still a possibility there? or I have a serious problem?>> Please flash with Rockchip Batch Tool 1.7, use Restore button.
thanks you but I'm doing something wrong. I connect the tablet but rockchip finds no device. when i press the on button on the tablet, the PC makes a beeb (as a USB connection is make), this is just not visible and rockchip does not recognize deviceÂ
New Android 4.2 firmware posted for the Cube U35GTW and U35GTS models.
gadfly, make sure you flash the right firmware for your U35GT model.
108 Guest(s)
Devices in use: Desktop (91), Phone (16), Tablet (1)
3nf
lesfurets
lbalexa001
rkg2303
sergey-tax
houseofcandy
