2013/05/30
hi there been doing some tests and most rooted roms have wifi speed issues where if there non-rooted (stock) the speeds are good
ie: rooted wifi download speed max =2.4 megs
non-rooted wifi download speeds  max 19.7 megsÂ
can anyone explain that or even look into fixing plsÂ
scott
I don't know about root firmwares from other sources but for the ones I built here on arctablet.com, I don't see any impact of my modifications on the WiFI speed or stability.
I wonder if your WiFI tests are precisely measured and all parameters are equal when you check speed between two firmwares. If you are measuring Internet bandwidth there are a lot of factors than can influence the results, the only reliable measurement I would see if measuring network speed on a local area network.
2013/05/30
I don't know about root firmwares from other sources but for the ones I built here on arctablet.com, I don't see any impact of my modifications on the WiFI speed or stability.I wonder if your WiFI tests are precisely measured and all parameters are equal when you check speed between two firmwares. If you are measuring Internet bandwidth there are a lot of factors than can influence the results, the only reliable measurement I would see if measuring network speed on a local area network.
hi there admin i use a wifi ftp that is a foot away from my router and when i use the non- rooted 4.2.2 that was released on the 10 may it was transfering between 12 and 19 megs  now i installed the lastest off this site and also used few others from this site and i cant get a transfer higher than 2.4 megs i did try and reinstalled the 10th may firmware but link never worked but i must add the only differance between my original and the lastest one on here is that it rooted ....its a pain cos love this latest 2.04 fast as and every running sweet other than the slow wifiÂ
oh and i have tried 3 differant routers cos i have 2 in room and all still same the rooted is slower than the original non-rooted oneÂ
thx bud
2013/05/30
hi there just install nonrooted 10th may stock and im getting 15 meg dowload with 12 meg up load on tablet where on custom i only got 2.2 could u look into that pls boys i really want ur custom roms back
The following users say thank you to sirdogg8u for this useful post:
cuberiordan
2013/06/27
I managed to find one here:
http://pan.baidu.com/share/link?shareid=528258&uk=3459288054
but it did not make difference. When I am a bit further from the router, speed drops significantly.
Currently Online: matinf
86 Guest(s)
Devices in use: Desktop (75), Phone (11), Tablet (1)
matinf
floki
orocamora
Ellocojoe
Tonysc17
olegator
