2013/07/09
after some use and several flashes, out of the blue my micro USB port does not work anymore.
I'm stuck there with a 4.1 old ROM and the tablet has very poor performance, especially with battery and wifi.
I'd like to re-flash the latest Kasty release, but I can't since I cannot use flashing tool from PC.
Is there a way to install the latest Kasty from recovery/SDcard?
Thank you so much
M
2013/04/23
2013/07/09
Hey Darth, does it work well? How critical is the risk for this task? I only have one shot available since my USB port does not work so if I fail I'll use my tablet to serve tea.
Thank you, just want to be sure but I think I don't have any option left.
2013/04/23
Well, it works for me. If you have CWM Recovery, there is no reason why it shouldn't work. However, updating firmwares is ALWAYS a risky venture, and any number of things could go wrong with the process, for any number of reasons. So if you are risk-averse, then the best thing is to stay with your current firmware.
45 Guest(s)
Devices in use: Desktop (37), Phone (8)
nikitamaan
VMILCINOV
