2013/05/11
Sounds like you have used a generic CWM, that doesn't have the correct mount points for the sdcards, only way to correct it would be to replace the recovery.
If however its also not finding the storage when booted then that would suggest a larger issue (have you modified the vold.fstab in /system/etc/ at all)
It may be that the easiest fix is to start from scratch with a know working rom, I beleive that one of the Kasty 2.04 roms that you flash with the RKBatchTool includes a working CWM, perhaps try flashing that and see if it resolves the issue.
115 Guest(s)
Devices in use: Desktop (97), Phone (18)
cutierogue
hans41
