U30GT2 Screen replacement help advice
Dismantled tablet, screen serial is 101050-01A-V1. Need help choosing replacement screen and differences between them
firemanpek
2014/12/01 - 23:45
Hi i have dismantled my cube u30gt2 after breaking the screen some months ago.
The serial number for the screen is 101050-01A-V1.
I have noticed by the sellers on aliexpress sell 3 different types of screens for the Cube U30GT and GT2 the serial numbers are as follows
101028_01A-v1 101075-01A-V1.
I was hoping if someone with knowledge than me could tell me if
1. what is the difference between these models
2. are the interchangeable
3. which is better.
Thank you, Damo (firemanpek)
firemanpek
2014/12/01 - 23:58
i just found this on a russian website
Interchangeable with the models:
  • 101075-01A-V1
  • 101022-01A-V1
  • 101028-01A-V1
  • CTP101050-01
Suitable for tablet models:
CUBE U30GT
Perfeo 1006 IPS
Ployer MOMO 12
Title 101075-01A-V1
Diagonal 10.1 "
False panels Yes I Am
Width x height (mm) 256 Ă— 167
Loop connector (pin) 6
Loop length (mm) 30
Distance plume left x right (mm) 43 Ă— 209
Categories:
maikal
Jacksonville, Florida
Forum Posts: 394
Thanks Received: 51
2014/12/04 - 04:32
According to Oma its pretty tricky, read my thread down below your concerning my search for a replacement lcd if that's what you are referring to.
http://www.arctablet.com/blog/forum/cube-u30gt2/need-to-get-replacement-lcd-for-cube-u30gt-any-ideas-where-besides-china/#p48139
good luck, I am in a holding pattern but was able to buy a new cube for $87US on eBay last week. Still holding out hope for someone to put a broken or bricked Cube so I can purchase the lcd out of it. China is a long ways from Florida to return something that don't work out.
firemanpek
firemanpek
2014/12/04 - 10:18
thanksto Maikal for taking the time to reply to my post.
I only have to replace the touch screen, i hope. I have ordered one from Aliexpress serial 101050-01A-V1.
The funny thing is that from what everyone tells me this touch screen belongs to cube u30gt no u30gt2, but this is definately the serial number of the screen in my u30gt2.
I asked an Aliexpress seller what is the difference between the screens and this is his reply,
quote
You have a new message from AliExpress supplier Jessie Z.
Jessie Z: The difference between these two kinds of touch screen is 101050-01AV1 apply u30gt dual core tablet.
101075-01AV1 apply u30gt quad-core tablet.
Two kinds of touch screen is not universal.
I will keep everyone posted when i get the screen and install it, it looks pretty straightforward at least.
Thanks, Damien
firemanpek
2014/12/06 - 03:31
just an update, the screen i have ordered form aliexpress is still in processing. I found another interesting thing on a russian forum. You'll have to excuse the Google translate.
Support service feeling that pigeon post exchanges 3 days have passed since the question as asked by e-mail and did not answer .. But as money Stritch interest wakes
Who could be useful dug here and realized that the touch screen that under u30gt that under u30gt2 absolutely identical.The only difference is the price of $ 20 on that we should not pursue this marketing works)) The model number is still 101050-01A-V1 there is out there. Touch costs $ 45-60. Here are the links to order
http://www.aliexpress.com/item/Original ... 11292.html
http://www.aliexpress.com/item/Free-shi ... 47982.html
If anyone else has replaced there screen at sometime, could you message me and let me know how it went, any problems etc.
Thanks, Damo
p.s the links don't work, but you get the idea
maikal
Forum Posts: 394
Thanks Received: 51
2014/12/06 - 04:41
Sorry, hard to understand. Good luck.
firemanpek
2014/12/06 - 08:11
i guess the google english to russian translator isn't perfect...Harder for me i'm Australian, we have our own version of english.
Damo
firemanpek
2014/12/08 - 23:15
update. I ordered from Aliexpress 9 days later still awaiting shipment. Contacted supplier, he said no stock!...Another supplier ordered again...fingers crossed
firemanpek
2014/12/19 - 06:33
update: screen ordered from new supplier and is on its way
I will keep the forum up to date incase someone out there needs to replace their screen
firemanpek
2014/12/25 - 11:03
Merry Christmas all. My screen arrived ended up being a 101075 even though I orderd 101050. I installed it very easily and it works perfectly. I can confirm for those needing a new screen that they are interchangeable. Thanks for the posts and help. Damo
The following users say thank you to firemanpek for this useful post:
maikal
Mark06
Forum Posts: 222
Thanks Received: 41
2015/04/27 - 09:03
is it more powersaving with the new display in your cube?
You mean this one right, is it a complete screen or just something else "panalizer".
edit: i think it's this one. 100 dollars is very much though, but is it more powersaving?
This one is the same, but costs bout 60 dollars exl shipping.
This one is the cheapest, same amount but free shipping, it says it's original, so no better power specs.
Cube u30gt2 tab
firemanpek
2015/04/29 - 23:59
I just replaced the digitizer, as in the first link. Haven't noticed any difference in power usage. I find the power usage pretty decent. Prob about 5-6 hours watching vids etc
Mark06
Forum Posts: 222
Thanks Received: 41
2015/05/03 - 13:39
Advice: get in a dark corner, install 'dimly', tune your display with it and start watching movies. Am curious how long you can watch movies now.
Cube u30gt2 tab
55 Guest(s)
4 Guest(s)
Devices in use: Desktop (45), Phone (10)
wogoko8553@yubua.com
hellander
elousstad
relaytester
revoltown
