U30gt2 battery
harryc1
2014/01/04 - 13:09
Hi.
I've had the table for about 10 days and have a big problem with the battery.  The battery charges to full and when I use the tablet it's OK.  When I leave it on and it goes to standby, after I try to use it the battery will go to 0% and the take a few hours to charge.  After the battery drains, the table resets the date and time as well.  The drain has also happened once while it was turned off.  If I use the table the battery seems fine.  Various battery saver programs tell me my battery is OK.  I've tried different firmware but still have the problem.
Any help is greatly appreciated.
I think it's a hardware problem, not software as the battery is on the charger for a few hours and is still 0% charged.
Four days have passed and the tablet seemed to be working with the stock cube firmware from 29-10.
The tablet charged and finally turned off after 22 hours on (most on standby).  The new problem is that it's not charging again (unless the firmware is restored).  I don't know if this is a hardware or software issue.
84 Guest(s)
Devices in use: Desktop (64), Phone (20)
roro17920
anbague
run2droi
iceman14
AnyFox
BAMHAB82
