2013/05/09
validatus said
I am an inexperimented french old guyBut first thaanks
My remarks:
multi user ok
system 4 gb ok
installation ok ok
but no explorer
WHAT TO DO
many thanks - grand merci
Hi!
You can download file explorers from the play store. Just type "file explorer" into the search box.
The following users say thank you to geloczigeri for this useful post:
validatus
2013/04/26
You can find this apk on the web and not on playstore: http://handheld.softpedia.com/get/GPS/BlueGPS4Droid-111453.shtml
I've tested tomtom europe from my office to home. Perfect!!!!, Impossible to miss the road with this hugge screen....
To put this app to your tablet, airdroid.... on playstore....
The following users say thank you to marcobus2005 for this useful post:
fana75
2013/05/24
stassen said
airman said
Well, I was talking about the well known Jelly Belly patch. I think you know what I'm talking about, anyway here they discussed about it...https://www.dropbox.com/s/qsrgvutowxqwefj/U30GT2_4.2.2_v2.03_20130606_root_wifionly.zip
THER YOU GO, its last version with wifi only
This version gives me the following error: "Unfortunately com.android.provision has stopped". It keeps popping up. The only thing I did before upgrading was deleting the phone related apps. Maybe it has to do with that. I went back to the previous version 4.2.2 20130515 and everything is ok again.
Any ideas why this did not work with mine?
2013/05/11
marcobus2005 said
You can find this apk on the web and not on playstore: http://handheld.softpedia.com/get/GPS/BlueGPS4Droid-111453.shtmlI've tested tomtom europe from my office to home. Perfect!!!!, Impossible to miss the road with this hugge screen....
Hi
I tested this tonight and unfortunatly i didn't succeded.
I paired the cube and the Galaxy note for bluethooth.
Gps 2 bluetooth on my galaxy note was very long to detect my cube
I enabled gps test on my galaxy note: it detected the satelite but it stopped each time there is the screen saver.
On the cube, i select my galaxy note in BlueGPS but sometimes it worked (no retry messages) sometimes not.
When it worked i tried to use map but it said that i must enable location for google app while i though it is already the case
I tried to installe then GPS test also on the cube and i couldn't see the satelite....
Any ideas?
On the cube side do i need to toogle the GPS toggle button into the status bar?
Regards
2013/04/26
In the settings of GPS test, turn on the option " keep screen on" . gps2bluetooth as just one option: activate or desactivate. In bluegps, i've selected sirf option. That 's all....don't forget to allow mok location un the tablet settings
fana75
2013/05/11
Ok i will have another look tonight
Where the Mok location setting is? And what is it?
I didn't need to toogle the GPS Toggle button on my cube?
Regards
2013/05/02
Hi stassen,
Just wanted to say Thank-You for this ROM.
Out of all the one's I've tested on my tablet so far, this one is a keeper. It's not giving me any strange behaviour or surprises, everything is working well enough.
1. Flawless install
2. Easy enough to install CWM via terminal method; following instructions from this page:
http://androtab.info/clockworkmod/rockchip/install/ following the "from root shell" section in a terminal window on the tablet (I can actually reboot into CWM recovery with root terminal or JRummy ROM Toolbox Lite 'rebooter' tool)
3. Multiple Users work (though one odd thing: I have to shut down WiFi before switching users, or the "other" user will "still be using" the WiFi connection)
4. I installed the .zip for the Tablet UI fix, in CWM recovery, but it didn't seem to do anything... with the standard Launcher. But later I tried out the Apex Launcher because I wanted a more dense icon arrangement & to do away with the "phone UI" view of the regular launcher, and I don't know if it was Apex Launcher (free) or the Tablet UI fix .zip that accomplished it (because Apex Launcher has a toggle in settings for Tablet UI? so?) Either way... I was able to achieve the desired Tablet UI and get away from the Phone UI that made me unhappy. Honestly, I think this "point 4." was solved by Apex Launcher most likely.
5. My happiest bits: The tablet is running smooth, no hiccups, lockups, hard crashes so far, and in-browser flash-player, and Netflix app (v.2.0.2 apk) video streaming is working very well.
I'm glad to finally start enjoying the tablet instead of worrying maybe I made a boo boo in purchasing this. I think I can relax now.
Best
2013/05/24
@thatoneguysomeplace. The ROM you talk about is that the one that Stassen mentioned in a previous post?
Like I said before, this version gives me the following error: "Unfortunately com.android.provision has stopped". I went back to the previous version 4.2.2 20130515 and manually deleted the Phone.apk to solve the battery issues and it is working ok now.
I am still very unsatisfied with the performance of my U30GT2, especially scrolling in the browser. No matter what browser I try (native, FireFox, Opera, Chrome, Ocean, Dolhin), it is laggy and much slower than my Ipad 2. Maybe it is just an android thing.
The following users say thank you to Meewind for this useful post:
stassen
2013/06/20
Meewind said
@thatoneguysomeplace. The ROM you talk about is that the one that Stassen mentioned in a previous post?https://www.dropbox.com/s/qsrgvutowxqwefj/U30GT2_4.2.2_v2.03_20130606_root_wifionly.zip
THER YOU GO, its last version with wifi only![]()
Same here, browser lags and some of my news apps lag too! With my old window n90 dual core the apps and browsing are way smoother, iI hope the people at cube pull there heads out of their asses and at least put a bit more effort into their ROMs instead of the stuff they re throwing at us
2013/06/01
DarthJabba said
You can install the CWM Recovery image (recovery.img) using RKAndroidtool.exe. Just untick everything else, selecting only the recovery image, and flash.
if it was so easy...
just did it and it didn't install
ps:
http://androtab.info/clockworkmod/rockchip/install/ root shell work
56 Guest(s)
Devices in use: Desktop (53), Phone (3)
jacksonrid
usdown
ibob64
kawi
vetBro
