2013/04/04
airman said
stassen said
Don`t use the OLD version! download the newbtw am working on a new version trying to fix the permanent bugs!Â
have anyone tested flash other kernels like pipo m9 kernel? or its working?..
i have found Linux3188-master.zip its Linux Source - RK3188 - PicUntu https://github.com/aloksinha2001/Linux3188
I never had the chance to get the NEW file. Â MEGA site always returned the message "Temporary error, retrying" and nothing happened. Â The same for the Tablet UI zip file.
BTW the OLD is working nicely. Â I applied the Phone patch and now the battery is lasting as ever. Â This morning in standby it uses only 1% in 4h30m !!
Ok, i will upload it to a mirror! ok can you link me to the Patch i will chek how it work!
airman said
2013/05/06
Well, I was talking about the well known Jelly Belly patch. I think you know what I'm talking about, anyway here they discussed about it...
Which applications have you tried ?
2013/04/04
https://www.dropbox.com/s/qsrgvutowxqwefj/U30GT2_4.2.2_v2.03_20130606_root_wifionly.zip
THER YOU GO, its last version with wifi only
The following users say thank you to stassen for this useful post:
robiomI already gave you some hints in this forum weeks ago, it could be interesting to test a few apps, maybe there's one that work. I can't test anyway as I don't have an U30GT2 here.
2013/05/11
Yop i remember your hints and that why i tested Share GPS and a few other but it didn't work...
Even if you don't have a cube maybe you have another tablet?
2013/05/11
marcobus2005 said
hi fana75,I use my Galaxy S3 as a bluetooth gps with U30gt2 and it work fine.
GPS2BLUETOOTH app on S3
BLUETOOTH GPS PROVIDER app on U30GT2
Tested with maps with me pro & maps
Thanks i will test it tonight: i am at work right now.
You didn't have a GPS software on your cube such as Sygic/Tomtom or another one on which you could have done test
I look at the Help after installing the soft on may Galaxy note...
They say that you must add a COM Port on a PC, but because i want to use my cube instead of a PC do i need to do something on my cube?
Could you please, describe the seuqence you do to connect your S3 Phone to your Cube in order to use map on the cube with the GPS of the phone?
Regards
2013/04/26
Fana75,
here is the sequence:
install gps test and gps2bluetooth app on phone
install bluetooth gps provider on tablet
First connect bluetooth betweem phone and tablet.
run gps 2 bluetooth and click "activate".
run gps test on the phone to avoid gps to go to sleep.
run gps bluetooth provider on tablet and select your phone. the connection must be ok.
Run map or maps with me and you will see your location.
I've tried tomtom but seems to not see gps... ;-( it tell me gps not activated...)
mok position is allowed in settings...
Currently Online: avv2011
84 Guest(s)
Devices in use: Desktop (73), Phone (11), Tablet (1)
avv2011
leadpan101
jumbo65
kalkpits
m12k
StatusQ
