U30GT2 4.2.2 20130606 (v2.03) Clean, Root, 4GB, AOSP Look!
airman
Milano
Forum Posts: 33
Thanks Received: 5
2013/06/17 - 08:30
Hi Stassen, I would report that in OLD version the gallery is showing the local pictures ONLY, no google albums or instant loading.
airman
Milano
Forum Posts: 33
Thanks Received: 5
2013/06/17 - 08:31
HI, the new version in MEGA is still not available: temporary error.
Uznamer
Poland
Forum Posts: 42
Thanks Received: 12
2013/06/17 - 09:06
stassen said
Thats strange, its works perfect for me, and yes i test all roms before i upload... so i dont think its my rom,
If it is happening only in case of my tablet then I am sorry for my negative opinion. Nevertheless I was flashing my device with all your three succesive  custom roms and always had big problems with restarting of system. Usually you can hear a click after few seconds of pushing the power button then you can see cube factory logo. Now the system should be loaded but it is not. You get only black screen and nothing more. After that you can wait forever and nothing happens. Anyway if you left your tablet for few hours turned off then it starts normally. I have no idea why it happens. When I was using your previous rom it was only first reboot with problems. Second and following restarts were going smoothly. In case of your last rom I was not able to restart it at all. After initial sound of click there was nothing on the screen.
Skydsler
2013/06/17 - 09:39
Rom is ok, Tablet UI ok, CWM ok. Rom looks fine. But ANTUTU Score are very bad at 14000 pints. With 4.1.1 / 1.5 Rom 16-17000.
We need a Custom Kernel... :)
ElVinche
2013/06/17 - 12:30
stassen said
Can anyone test this TabletUI fix (BETA 2) https://mega.co.nz/#!ENYhXJZY!fdwRmkVjEJay9g8NebmKPFi2k4QGNq3EjXHrx2YQzRw
Hello, can you tell me what we can expect with it ?
thanks.
ElVinche
2013/06/17 - 12:39
Hello, does your rom contains the changes from 13 june 2013 of the Cube's firmware ?
http://www.51cube.com/ch/DownShow.asp?ID=169
i'm a bit lose as you talk about the 06 june rom based version with comments of the 13 june firmware on Cube site...
thanks.
Brnky
Forum Posts: 15
2013/06/17 - 15:48
stassen :
Hi, I found an interesting thing when charging. I can partially control the IPS panel without even touching him. (finger over the surface) Work with the same time, but not much - unstable. Sorry for my English
Bsoft2007
Portugal
Forum Posts: 36
Thanks Received: 8
2013/06/17 - 22:34
Hi Stassen, I already installed the OLD version.  Could you please let us know what is the difference ?  I  saw that the new is 21Mb lighter than the old... BTW, I could't install the CWM.  I followed the instructions, got no errors, but when I reboot in recovery mode, I get the robo with the open red heart.. Thanks for your work !!
I´ve the same question....
@Stassen, think you should add more details about the ROMs, since you have two versions and we can´t tell the difference between...only the size...
Thanks,
Bsoft2007
Portugal
Forum Posts: 36
Thanks Received: 8
2013/06/17 - 23:31
Thanks,
Just found out the difference.... ROMs are the same, OLD one it´s a AIO package(apps,rom,RKtool)....
Bsoft2007
Portugal
Forum Posts: 36
Thanks Received: 8
2013/06/17 - 23:49
Finally a Rom that let me save APN config 😉
Just need to try out my Huawei e220 to see if it works! Until now I was unable to set APN config, I couldn't find out a way to save APN config.
This is what I did:
(Settings/More.../Mobile Networks/Access Point Names) and select "New APN"
Fill with your APN config....  then Press POWER BUTTON until Menu with "Power off" appears, click it.
Power On the tablet and check if APN is set...
The following users say thank you to Bsoft2007 for this useful post:
stassen
airman
Milano
Forum Posts: 33
Thanks Received: 5
2013/06/18 - 00:54
Well, nice to know, I haven't to reinstall all the stuff...
Everything OK, CWM too finally (my fault, of course).  Antutu stops to 15100.
So, Gallery doesn't show Picasa albums, in 4.1.1 v1.05 it did.., I installed an app by the market, Cool 3D Gallery, that does the job.
Stassen, thanks a lot !!
stassen
Sweden
Forum Posts: 62
Thanks Received: 43
2013/06/18 - 11:12
Don`t use the OLD version! download the new :) btw am working on a new version trying to fix the permanent bugs!
have anyone tested flash other kernels like pipo m9 kernel? or its working?..
i have found Linux3188-master.zip its Linux Source - RK3188 - PicUntu https://github.com/aloksinha2001/Linux3188
stassen
Sweden
Forum Posts: 62
Thanks Received: 43
2013/06/18 - 11:14
thanks.
Its the same kernel is from 06/06 cube releas it 13 its all! :P
airman
Milano
Forum Posts: 33
Thanks Received: 5
2013/06/18 - 12:21
I never had the chance to get the NEW file.  MEGA site always returned the message "Temporary error, retrying" and nothing happened.  The same for the Tablet UI zip file.
BTW the OLD is working nicely.  I applied the Phone patch and now the battery is lasting as ever.  This morning in standby it uses only 1% in 4h30m !!
Bsoft2007
Portugal
Forum Posts: 36
Thanks Received: 8
2013/06/18 - 12:35
This is what I did:
Finally i got 3G working!! Tested my Huawei E220 and it works great! I've tried it on two networks, one of them the APN was set auto :-) . The other i set Apn config as said above....
Really like this ROM
stassen
147 Guest(s)
Devices in use: Desktop (142), Phone (5)
