2013/04/04
Cube U30GT2 Android 4.2.2 Jelly Bean rooted firmware based on latest Cube official update v2.02 2013/06/01
Kernel: Linux version 3.0.36+ (lcp@tchip) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #71 SMP PREEMPT Sat Jun 1 13:44:33 CST 2013
Android Jelly Bean: 4.2.2 JDQ39
FW Ver: 4.1.01
FW Time: 2013-06-01 15:35:10
BOOT Ver: 1.20
BOOT Time: 2013-05-18 14:54:12
Support Chip: RK31
- Root with SuperSU v1.30, Busybox v1.21.0
- Removed all Chinese and unnecessary Cube applications (Now Like AOSP)
- Removed Rockchip ota update system/settings, Change some stuff in Launcher
- Google Play Store visible/compatible fixes
- Update Gapps (Play Store, Talk and more...)
- Init.d boot scripts support
- External SDcard read/write access
- Multiple Users (Max 4)
- 4GB System apps (2BG default)
- U30GT2_CWM_6.0.3.1.zip (CWM Recovery Flash Kit) Download: https://copy.com/dsppcGwcNw6E
- Apps, like working netflix, and other nice apps! Download: https://copy.com/NThwgQHzSn1f
Name: U30GT2_4.2.2_v2.02_20130601_clean_root.img Download: https://copy.com/Gb2wv7s8lTgG (Don`t make mirrors)
CRC32: BDDEBCED
MD5: A8C3EF07AF11CA4E9F8AB35809D7C81C
SHA-1: 4E8A88512643EBEBBE04AC8D80D59CCFC33C41AD
Cube Changelog:
-Release 20130601 (V2.02)
- Corrected version of part of the machine on a gravity sensor failure problem
- Optimization of the overall system operation fluency, enhance the user experience.
Pleas report any bugs, in this topic, and remember i will keep it so close to AOSP as its possible!
hope you like it,
Bless!
The following users say thank you to stassen for this useful post:
agis-pro, kibachan91, airman, Bsoft2007, vildkatt, sapphirus, robiom, Uznamer, JunglBell, thatoneguysomeplace
2013/05/31
I installed this rom.
But after creating 2 new users, I select one new to log in.
After the creation process, I have an error 'The application com.android.provision has stopped' and it looped on this error message.
I can just log in my principal account, with the 2 others I have the same error. It was working fine with the 2.01 firmware
Well, what comes in my mind very fast, is to use the com.android.provision from the 2.0.1 firmware.
2013/05/31
Ok, do you have it ?
Or how can I read the img files (I tried with winrar with no sucess) ?
Edit:Â
I renamed the com.android.provision folder and reboot. I can now log in the new users.
I did not find usefull information on this app, do you know what it is supposed to do?
The following users say thank you to porque for this useful post:
airman
2013/04/04
porque said
globula_neagra said
Well, what comes in my mind very fast, is to use the com.android.provision from the 2.0.1 firmware.Ok, do you have it ?
Edit:Â
Ok, i upload provision from the 2.0.1 https://copy.com/nnsw4QJzGJgEÂ try it, so i can fix in next version any other problems?
and i need a tool named RK31xxImageTools to unpack the .img, after that you will have, boot.img kernel.img, system.img, and bounch of other files, then you need to mount system.img, its a linux image, then start to mod... hope you like my work, bless
porque
2013/04/04
airman said
Hi, i already nave CWM installed. Do i ne ed to reinstall it after the mod ?Thanks.
No its just like orginal Firmware flash with RKBatchTool_v1.7.1.1_RK3188 and after you can install CWM with the pack i linked!
maybe i will intergrate CWM later, bless
airman
2013/04/04
porque said
stassen said
Hmm strange i just added 4 users and no error, working perfect!I had no problem when adding the users. The issue arise when I log in the new users.
I removed the phone, mms, telephonyprovider apps before creating the users, I don't if it's linked.
Ohh yes mauybe its that, i tried to use that patch befor but i got strage error, and i will use external 3G and that will not work, if you use that patch... so i think its that, any ather error? need to know new version comming!
2013/04/04
Soon we will have Tablet UI on this 4.2.2 Rom can samone test this https://copy.com/LSRW9rcuBbNLÂ just replace the files in system (remember to chek so its have the right premissions then reboot!) tell me how its working!
Currently Online: pater
71 Guest(s)
Devices in use: Desktop (61), Phone (9), Tablet (2)
kpointcom
fendt126
victorprdm1994
sif
tayten
vrtroper
