[ ROM ] Cube U30GT2 Android 4.4.2 KitKat custom root firmware (2014/06/06)
nelySLB
Forum Posts: 34
106
2014/06/29 - 20:14
some games don't work on this ROM, like asphalt 8, the Sims, what can be done to solve this? i appreciate your help.
Bafou
107
2014/06/30 - 00:04
The full screen toolbar disturb the game
dragogo
108
2014/06/30 - 10:15
Me i have no problem on asphalt 8 and the keybord is ok
on antutu i have > 19000
I'm really appreciate this rom
musico59
Forum Posts: 14
109
2014/07/02 - 11:11
Hi Guy's !
  No more returns about this rom from Admin ?
Thanks for feedbacks !
ntinos_tech
Forum Posts: 19
110
2014/07/04 - 14:10
Hi, once I installed this ROM suddenly the tablet shutdown....and NOT coming back....unless I plug the power cable! the battery says 100% charged..if I remove the cable the tablet shut down again after 30 minutes....does anyone knows how to reset the battery percentage? battery status.....is there anybody can tell me how to wipe EVERYTHING.....including battery status...I think there is a file or something..please help....else I have to throw the tablet in the basket with scrab!it is useless! Is there a way to go back to 4.2.2 rom?
Regards
ian
United Kingdom
Forum Posts: 30
111
2014/07/04 - 18:09
Regards
Have you tried calibrating the battery?  I use Easy Battery Calibration found in Google Play.
ntinos_tech
Forum Posts: 19
112
2014/07/05 - 12:40
To be honset I tried 2-3 times to do calibration....but no luck...I do not believe that the batteries just died once I used this ROM....I tried also to do reboot recovery adn I wipe everything...both cache and user data!Same issue....is there a way to do back to 4.2.2....just to find out if the same issue with batteries exists...today after 12 hours of charging....I calibrated the battery...then restart....and then 10 min... worked and then off!it is very hot for these 10 minutes from ther side of the ports....left hand corner....thank you anyway for your help...any help would be something before scrab it!
maikal
Jacksonville, Florida
Forum Posts: 394
Thanks Received: 51
113
2014/07/05 - 16:16
yes there is more than a few post on going back in the tread about these last kit Kat rom and the kit Kat before that.
DarthJabba
Forum Posts: 551
Thanks Received: 396
114
2014/07/05 - 18:32
http://www.arctablet.com/blog/forum/cube-u30gt2/cube-u30gt2-turn-back-from-4-4-2-problem-solved/
mohag519
115
2014/07/06 - 12:25
I have the u30gt2 MH variant of this tablet and the previous kernel didnt work so well with the device. I tried this version and I can confirm it works flawlessly and I'm very satisfied with this ROM. Thank you.
maikal
Forum Posts: 394
Thanks Received: 51
116
2014/07/07 - 00:18
Can folks liking the rom please be specific ? Do you mean the kasty or the Oma rom. That would be helpful to others. Thanks in advance.
cocofish
117
2014/07/08 - 08:25
Does the a/v async problem solved?
frazze
118
2014/07/08 - 21:39
Please, solve the audio/ video sync problem. What's the use of this nice screen if you cant watch decent streams on it... Its driving me crazy.
Maxim
119
2014/07/09 - 04:30
ian said
I am on the OMA rom (I am not sure whether this makes a difference) and occasionally the tablet shuts itself down and will not restart by pressing the power button.  The only way restart is to put the power lead in.  I have not had this before the OMA rom, so I am not sure whether this is firmware or hardware based.  Has anyone else had the same problem?
I've the same problem with all KitKat roms. Does anyone knows what to do?
I've heard the suggestion to try a different kernel. How do I do this?
ntinos_tech
Forum Posts: 19
120
2014/07/09 - 09:27
A lot of people have the same strange situation...also another question for you Maxim and Ian  what is the behavior of the batteries? I mean once the tablet is off....and then you plug the power...what is the status of batteries? for me it is directly charged! and after a lot of hours on the charger it says....93 96 99 % etc....right after the shut down...the left hand corner(keys side) of the tablet is too hot. I cannot understand if the issue is from the batteries or the charger or the main circuit of tablet....or the rom!I cannot go back to 4.2.2 because I do not understand how...I am not android expert....just rockchip batch tool and restore is my knowledge! I want to get rid of the tablet but I do not know how and what to do with it!
Currently Online: norton-norton-norton
78 Guest(s)
Devices in use: Desktop (65), Phone (13), Tablet (1)
gaecraco1
gaecraco
freem
geokgian
s_t_y_m
