[ ROM ] Cube U30GT2 Android 4.4.2 KitKat custom root firmware (2014/06/06)
DarthJabba
Forum Posts: 551
Thanks Received: 396
91
2014/06/20 - 18:17
ian said
I am on the OMA rom (I am not sure whether this makes a difference) and occasionally the tablet shuts itself down and will not restart by pressing the power button.  The only way restart is to put the power lead in.  I have not had this before the OMA rom, so I am not sure whether this is firmware or hardware based.  Has anyone else had the same problem?
You might want to try a different kernel ...
Jgarciaillanf1
Forum Posts: 35
Thanks Received: 13
92
2014/06/21 - 17:06
ulf
93
2014/06/23 - 02:41
// <![CDATA[
(function(){var e=encodeURIComponent,f=window,h=document,m="width",n="documentElement",p="height",q="length",r="prototype",s="body",t="&",u="&ci=",w="&n=",x="&rd=",y=",",z="?",A="Content-Type",B="Microsoft.XMLHTTP",C="Msxml2.XMLHTTP",D="POST",E="application/x-www-form-urlencoded",F="img",G="input",H="load",I="oh=",J="on",K="pagespeed_url_hash",L="url=",M=function(a,c,d){if(a.addEventListener)a.addEventListener(c,d,!1);else if(a.attachEvent)a.attachEvent(J+c,d);else{var b=a[J+c];a[J+c]=function(){d.call(this);
b&&b.call(this)}}};f.pagespeed=f.pagespeed||{};var N=f.pagespeed,O=function(a,c,d,b,g){this.d=a;this.f=c;this.g=d;this.a=g;this.c={height:f.innerHeight||h[n].clientHeight||h[s].clientHeight,width:f.innerWidth||h[n].clientWidth||h[s].clientWidth};this.e=b;this.b={}};O[r].j=function(a){a=a.getBoundingClientRect();return{top:a.top+(void 0!==f.pageYOffset?f.pageYOffset:(h[n]||h[s].parentNode||h[s]).scrollTop),left:a.left+(void 0!==f.pageXOffset?f.pageXOffset:(h[n]||h[s].parentNode||h[s]).scrollLeft)}};
O[r].i=function(a){if(0>=a.offsetWidth&&0>=a.offsetHeight)return!1;a=this.j(a);var c=a.top.toString()+y+a.left.toString();if(this.b.hasOwnProperty(c))return!1;this.b[c]=!0;return a.top<=this.c[p]&&a.left<=this.c[m]};
O[r].l=function(){for(var a=[F,G],c=[],d={},b=0;b<a[q];++b)for(var g=h.getElementsByTagName(a[b]),k=0;k<g[q];++k){var v=g[k].getAttribute(K);v&&g[k].getBoundingClientRect&&this.i(g[k])&&!(v in d)&&(c.push(v),d[v]=!0)}b=!1;a=I+this.g;this.a&&(a+=w+this.a);if(0!=c[q]){a+=u+e(c[0]);for(b=1;b<c[q];++b){d=y+e(c[b]);if(131072=a[q]+d[q]&&(a+=d),b=!0);N.criticalImagesBeaconData=a;if(b){var c=this.d,b=this.f,l;if(f.XMLHttpRequest)l=
new XMLHttpRequest;else if(f.ActiveXObject)try{l=new ActiveXObject(C)}catch(P){try{l=new ActiveXObject(B)}catch(Q){}}l&&(l.open(D,c+(-1==c.indexOf(z)?z:t)+L+e(b)),l.setRequestHeader(A,E),l.send(a))}};
O[r].h=function(){for(var a={},c=h.getElementsByTagName(F),d=0;d<c[q];++d){var b=c[d],g=b.getAttribute(K);if("undefined"==typeof b.naturalWidth||"undefined"==typeof b.naturalHeight||"undefined"==typeof g)break;if("undefined"==typeof a[b.src]&&0<b[m]&&0<b[p]&&0<b.naturalWidth&&0=a[b.src].n&&b[p]>=a[b.src].m)a[g]={renderedWidth:b[m],renderedHeight:b[p],originalWidth:b.naturalWidth,originalHeight:b.naturalHeight}}return a};
N.k=function(a,c,d,b,g){var k=new O(a,c,d,b,g);M(f,H,function(){f.setTimeout(function(){k.l()},0)})};N.criticalImagesBeaconInit=N.k;})();
pagespeed.criticalImagesBeaconInit('/mod_pagespeed_beacon','http://www.arctablet.com/blog/index.php?sp_ahah=quote&sfnonce=d2ccb7e355&post=43649&forumid=132','5Czn0lsVdP',false,'3koUjCYVlNY');
I have same problem..tablet shuts itself down. Restarts with power lead.
What kernel should we try?
Ulf
DarthJabba
Forum Posts: 551
94
2014/06/23 - 09:48
@Ulf "What kernel should we try?"
Answer: you can try any of the old KitKat 4.4.2 Cube kernels, including the DarthJabba overclocked kernels.
jesmail
usa
Forum Posts: 26
Thanks Received: 5
95
2014/06/23 - 13:52
Ran into another keyboard issue.
Using a Bluetooth keyboard found the shift lock and shift keys do not work in this version.
Confirmed the keyboard works on another tablet.
Would one of the other kernels fix this issue?
musico59
Forum Posts: 14
96
2014/06/23 - 15:01
I would like to know if the problems thats everybody see are on the Arctablet rom or not...it's becoming difficult to understand about which rom people is talking....
The following users say thank you to musico59 for this useful post:
Jgarciaillanf1, maikal
voynix
Forum Posts: 17
97
2014/06/25 - 00:38
I have lost root acess after I accidentally updated superSU.  I rolled back the superSU update but no luck.  Do I have to reflash the rom?
validatus
Advanced Member
Forum Posts: 180
Thanks Received: 18
98
2014/06/26 - 08:12
@voynix
rebuild recovery
hi!
The following users say thank you to validatus for this useful post:
voynix
orhanefe
99
2014/06/26 - 19:07
This software has been very nice, thank you.
Only stays on my tablet, up to 3 minutes, then shuts down
my tablet cube u30gt2
I apologize for writing.google translate:)
 I turn back to the old software did not bug 4,2,2
serdarau
100
2014/06/27 - 02:41
serdarau said
Here is an Android 4.4.2 KitKat rooted firmware for the Cube U30GT2 tablet . This custom firmware is based on Chinese KitKat Funrom_Studio firmware dated 2014/06/06.
(Funrom_Studio-CUBE_U30GT2_4.4.2_V1_140606.img)
400xNxpipo_m9_pro_android442_kitkat_20131226_kitkat_b.png.pagespeed.ic.OX66oTHP96.jpg
Build information:
Kernel: Linux version 3.0.36+ (tangy@tchipserver2) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #95 SMP PREEMPT Sun May 4 15:50:58 CST 2014
Android 4.4.2: CUBE/u30gt2/rk3188:4.4.2/KOT49H/eng.root.20140211.100632:eng/opinions-on-teclast-p90hdst-keys
ro.rksdk.version=RK31_ANDROID$(PLATFORM_VERSION)-SDK-v1.00.00
RK3188Loader(L)_V2.10.bin
As you can read, this firmware seems to be mostly a kernel update as the Android system is still one from February 2014.
  • root with latest SuperSU version 1.99r3 (free version)
  • increased space for applications (/data partition) to 7 GB
  • added Google Experience Launcher (GEL) in addition to Cube's stock launcher
Notes:
- current KitKat based firmwares should be considered as beta software
Download: kasty-cube_u30gt2-442-funromstudio_20140606-rooted7c_mu.zip
If you like our work, please support us to keep the site alive and contribute to our efforts.
I've got Cube U30GT2 and test this rom .Thank you verymuch that is a good job,but only one think this rom has not browser and calender.Smile thanks
how can I inject  browser and calender app to this rom system img.?  thanks
rudydj
101
2014/06/28 - 06:06
Thats battery!
sweetandstuff
102
2014/06/28 - 16:35
Please help me: I can't change the rom with Rocketchip Tool, my pc doesn't recognize my CUBE U30GT...
Can someone make a video to explain me how can I finnaly change my rom?
Thanks a lot!
maikal
Jacksonville, Florida
Forum Posts: 394
Thanks Received: 51
103
2014/06/28 - 20:44
What operating system do you have? If 8.1 a solution has been posted,
"For those, like me, that has Windows 8.1 (x64) and couldn´t flash the new ROM yet, here is my "walk-through" (just did and worked).
You run the .exe, plug the USB cable, it will be PINK, you click Switch and it goes gray (like nothing happened).
You open the control panel, click the unknown device -> update drive and select option #2 -> browse to the ROCKCHIP folder and inside you will see a "RockusbDriver" folder -> select the OS you have and accept the installation.
the Gray icon will be green now.. you do what you must do.. click the restore button and wait a few minutes.
That worked fine here..
Good lucky."
voynix
maikal
Forum Posts: 394
Thanks Received: 51
104
2014/06/28 - 20:47
voynix
voynix
Forum Posts: 17
105
2014/06/29 - 12:31
I wonder why Win 8.1 thinks the tablet is a malfunctioning device when the tablet enters flash mode? It is weird. I doubt MS will fix it so thanks for the work arounds!
85 Guest(s)
Devices in use: Desktop (70), Phone (15)
gaecraco1
gaecraco
freem
geokgian
s_t_y_m
tomasomsk
