2013/04/23
--CoolZone-- said
Definitely waiting for the CWM update package from DarthJabba.
Well, are you prepared to take the risk of flashing an untested CWM update package?
2013/04/23
--CoolZone-- said
No, not really since the reason I am requesting a CWM package is that I cannot get my tablet to get recognized by the usual flasher programs and yes, I have tried the usual methods in order to solve this by replacing the drivers and so on.
That is what I thought. A CWM package for the Cube u30gt2 from me would be untested, as I no longer have any way to test it.
2013/04/09
Jgarciaillanf1 said
Could be interesting that someone make an OMA ROM thread... don't could?
Agree with you that OMA rom discussion should preferably be on a separate thread as the information are all over the place. The process to flash the rom using the RKAndroid Tool is different from using the Rockchip Batch Tool. Took me a while to understand it.
Anyway I flashed OMA's rom and did the model fix. All is good and is happy with this rom. An improvement over the Feb Kasty Rom. Can't give a comparison to the Funrom Studio as I am happy with OMA's rom and don't intend to switch. Thank You OMA and Admin for your support on this Cube.
2013/04/26
For those, like me, that has Windows 8.1 (x64) and couldn´t flash the new ROM yet, here is my "walkthrouth" (just did and worked).
You run the .exe, plug the USB cable, it will be PINK, you click Swith and it goes gray (like nothing happened).
You open the control painel, click the unknown device -> update drive and select option #2 -> browse to the ROCKCHIP folder and inside you will see a "RockusbDriver" folder -> select the OS you have and accept the installation.
the Gray icon will be green now.. you do what you must do.. click the restore button and wait a few minutes.
That worked fine here..Â
Good lucky.
The following users say thank you to Sethi for this useful post:
maikal
2013/07/09
Darth if you post it I might go for it. I've been a bit cavalier with my cube since I got here. what's the worst that can happen? We've been told that so long if we do a backup you really can't brick a rk3188 right? It may take me a day or two to work up the courage, or I may not at all! But the challenge of it may draw me to it. I may wait for the weekend so I have enough time to get my crying done before returning to work on Monday. But I picked up a Surface RT real cheap on eBay that may console me until any damage to the Cube can be overcome.
So... if you build it, I may play with it.
Its too bad we could not have enough donors to put a Cube back in your hands though. Offer is still there if anyone wants to help getting Darth a Cube, with a $50US commitment from me. Android 5.0 is right around the corner and the more developers we retain with this Cube the longer we can expand its longevity.
2013/04/23
Use at your own risk!
2012/05/18
I am on the OMA rom (I am not sure whether this makes a difference) and occasionally the tablet shuts itself down and will not restart by pressing the power button. Â The only way restart is to put the power lead in. Â I have not had this before the OMA rom, so I am not sure whether this is firmware or hardware based. Â Has anyone else had the same problem?
81 Guest(s)
Devices in use: Desktop (66), Phone (15)
forty42
samih
macsierra2
sachatanya
Nursat
MaXXWar
