2013/04/09
Sethi said
Hi there;Â
I can´t connect hrow Rockchip.. It turns pink, then when i click switch, it goes off and doesn´t come green.. any chance for a CWM file?
I´m on Win8.1 x64 - just to point out, if anyone can help me
Yea. Waiting for a CWM upgrade. DarthJabba?
Thank You.
2013/10/09
Sethi said
Hi there;Â
I couldn't get it to work on win 8.1,  as soon as I went  into flash mode windows decided the tablet was faulty. Lucky I have a pc  with win  7.
2013/04/19
Hi mates. I have the rom of Funrom_Studio tried and am also very enthusiastic. this is really very good. also the problem with skype and the scratching of the voice seems to be gone. very good work. thank you for that. Unfortunately, the contacts no longer go again. last update you could activate it with the arctools again. this time it unfortunately does not work. can you then look again?
and another question. where is the difference to the other rom from oma?
Thank you, that you are still working on that cube.
keep it up
The following users say thank you to paulusingo for this useful post:
maikal
2012/05/18
Ok, let's do some quick testingÂ
Cube U30GT2 has RK903 wifi.
Just finished an aproach for a generic KK build, which is here: http://www.arctablet.com/blog/forum/crewrktablets-rk3188-entwicklung-customroms-development-croms/rom-kiano-elegance-android-4-4-2-kitkat-custom-root-firmware-20140610/#p43136
Before flash just replace the kernel in folder rockdev/Images: http://crewrktablets.arctablet.com/?wpfb_dl=1817
Model fix (install via CWM): http://crewrktablets.arctablet.com/?wpfb_dl=1823Â
Model Fix works correctly rotate, not work auto brightness and can not add widgets to the lock screen
thanks
The following users say thank you to jmiat1100 for this useful post:
Jgarciaillanf1
2013/07/01
I also use the OMA version.
I've found an other thing is missing. No Google address book.
but I installed gapps from here http://wiki.cyanogenmod.org/w/Gapps , and the problem has gone.
But it also installed google play music, games, and some other things.
thanks
Ok, we need to add a few lines to the init process. Cube is still of the opinion that this is a rk28board
#backlight
   chown system system /sys/class/backlight/rk28_bl/brightness
   chown system system /sys/class/backlight/rk28_bl/bl_power
   chmod 0664 /sys/class/backlight/rk28_bl/bl_power
Pls flash this boot.img (just tick parameter and boot): http://crewrktablets.arctablet.com/?wpfb_dl=1846
maikal, jmiat1100Per aspera ad astra, we rock the Tablets !
jmiat1100 said
Model Fix works correctly rotate, not work auto brightnessthanks
#backlight
   chmod 0664 /sys/class/backlight/rk28_bl/bl_powerPls flash this boot.img (just tick parameter and boot): http://crewrktablets.arctablet.com/?wpfb_dl=1846
add lines to the init.rc?
2013/09/05
Ok, we need to add a few lines to the init process. Cube is still of the opinion that this is a rk28board#backlight
Flashed OK, rotate is OK, camera is OK. Auto-brightness still unavailable. I forgot to mention what I also like about this ROM - it allows to set lower brightness/backlight level than Cube/Kasty 4.4.2 ROMs, I believe even lower than 4.2.2 ROMs but not really sure without direct side by side comparison. Screen can go really dim now, ideal for evening/night conditions as it no longer wants to burn through your retina.
Just to be sure: the model fix is running?
Definition is in init.rk30board.rc. To verify can you pls test this boot? http://crewrktablets.arctablet.com/?wpfb_dl=1849
raulmayselPer aspera ad astra, we rock the Tablets !
Just to be sure: the model fix is running?Definition is in init.rk30board.rc. To verify can you pls test this boot? http://crewrktablets.arctablet.com/?wpfb_dl=1849
Hi!
I've just tried it, but still No Auto Brightness . I only flashed boot and parameter.
Thanks for your work OMA!
the lines is in init.rk30board.ro, auto-brightness still unavailable
another question, is it possible charge with the tablet off?
thanks
92 Guest(s)
Devices in use: Desktop (74), Phone (18)
forty42
samih
macsierra2
sachatanya
Nursat
MaXXWar
