[ ROM ] Cube U30GT2 Android 4.4.2 KitKat custom root firmware (2014/06/06)
jesmail
usa
Forum Posts: 26
Thanks Received: 5
46
2014/06/13 - 13:44
Cuz, you may be able to duplicate it with the NBC app in play store.
Just call up any of the recent HD programs and play.
The interesting thing is the CBS app works fine and I have HD stuff on my server that play fine as well.
On another topic does any one have the driver to make the compass work again?
DarthJabba
Forum Posts: 551
Thanks Received: 396
47
2014/06/13 - 14:19
There are several NBC apps. Which are you referring to?
targa
Forum Posts: 14
48
2014/06/13 - 15:28
maikal said
can you provide a picture of the tablet? could it be a vido m10? We already had one person who was shipped a vido instead of a cube. we also had at least two people who got tables that were a different model, tow letters after the u30gt2. So a picture might help identify your tablet.
hi,
yes, it seems you're right, I don't have it at hand, but from Google images I'm pretty sure that I have a Vido M10, though it displays U30GT in the system dialog, and on the actual case it saus just nothing.
What do I do ? Try to return ? Seems to me the specs are very similar and the metal case seems good, the only disadvantage I can see is not so very good Wi-Fi, which seems to be the case for the Cube as well ?!
Thanks for advice.
/To
jesmail
usa
Forum Posts: 26
Thanks Received: 5
49
2014/06/13 - 16:39
https://play.google.com/store/apps/details?id=com.nbcuni.nbc
DarthJabba
Forum Posts: 551
50
2014/06/13 - 18:35
Apparently, it is "incompatible with all of [my] devices".
frazze
51
2014/06/13 - 19:28
i have the A/V problem with the Fox Sports app. I'll try to make a video of it and post it.
targa
Forum Posts: 14
52
2014/06/13 - 22:15
NeurOSick
Montreal
53
2014/06/13 - 22:17
All work great for now. tanks for this release.. probably the best for my CUBE.
And tank you to keep the original logo and boot animation.
Good continuity
maikal
Jacksonville, Florida
Forum Posts: 394
Thanks Received: 51
54
2014/06/14 - 01:18
targa said
Hmm don't know what to tell you. The one guy who found out he got a vido decided to keep it rather than spending the time and money to send it back. Its dependant on your communication with your dealer. Contact them and see what they say! If they choose to pay for return it may be worth it to you. Did you get it from a store in your country or China? Is it getting support? There is an arctablet forum for it and a YouTube video on that tablet. Talk to folks on the arctablet forum about it. I almost bought one on eBay but lost the auction on it. Its a nice looking tablet though, like you say, specs are similar to cube. Sending it back to China is going to be too much a hassle I think and you may still not get what you want or loose your money. You can try selling it on eBay and buy a Cube through a non Chinese dealer on eBay. I just saw a Cube there for $199US.
Good Luck
Cuz
Forum Posts: 11
55
2014/06/14 - 01:37
Hi late reply been at work...
I've got the same as Darthjabba posted above the app is  "incompatible with all of my devices"?
jesmail
usa
Forum Posts: 26
Thanks Received: 5
56
2014/06/14 - 02:33
Hmmm, oh well, I was trying all my apps to see if I had any A/V problems mentioned by others.
This app was the only one giving me problems, but I did not get the incompatible message.
Any way all my movies play fine, the only issue I had left is the compass issue that started with 4.4
The driver is missing to run the mag chip and so it does not work. This is a minor issue as the uplift we got in 4.4 for everything else. There is no going back.
Thanks for the reply!!
serdarau
57
2014/06/15 - 00:27
Here is an Android 4.4.2 KitKat rooted firmware for the Cube U30GT2 tablet . This custom firmware is based on Chinese KitKat Funrom_Studio firmware dated 2014/06/06.
(Funrom_Studio-CUBE_U30GT2_4.4.2_V1_140606.img)
400xNxpipo_m9_pro_android442_kitkat_20131226_kitkat_b.png.pagespeed.ic.OX66oTHP96.jpg
Build information:
Kernel: Linux version 3.0.36+ (tangy@tchipserver2) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #95 SMP PREEMPT Sun May 4 15:50:58 CST 2014
Android 4.4.2: CUBE/u30gt2/rk3188:4.4.2/KOT49H/eng.root.20140211.100632:eng/opinions-on-teclast-p90hdst-keys
ro.rksdk.version=RK31_ANDROID$(PLATFORM_VERSION)-SDK-v1.00.00
RK3188Loader(L)_V2.10.bin
As you can read, this firmware seems to be mostly a kernel update as the Android system is still one from February 2014.
  • root with latest SuperSU version 1.99r3 (free version)
  • increased space for applications (/data partition) to 7 GB
  • added Google Experience Launcher (GEL) in addition to Cube's stock launcher
Notes:
- current KitKat based firmwares should be considered as beta software
Download: kasty-cube_u30gt2-442-funromstudio_20140606-rooted7c_mu.zip
If you like our work, please support us to keep the site alive and contribute to our efforts.
I've got Cube U30GT2 and test this rom .Thank you verymuch that is a good job,but only one think this rom has not browser and calender.Smile thanks
targa
Forum Posts: 14
58
2014/06/15 - 20:04
thanks for your advice... actually I wanted to post pics, seems they got lost due to their size. Anyway, I think I keep it, seems quite decent, and there's KitKat ROMs available.
this must have happened on purpose given that it was package with the cube logo, it starts up using the cube logo and identifies using a cube product code. I wonder how I can make sure that vido roms will work....
It's probably enough that I'm kind of taking those risks usually ;)
vlevi
Forum Posts: 46
Thanks Received: 4
59
2014/06/15 - 23:32
Ok, let's do some quick testing http://www.arctablet.com/blog/wp-includes/images/smilies/icon_wink.gif
Cube U30GT2 has RK903 wifi.
Just finished an aproach for a generic KK build, which is here: http://www.arctablet.com/blog/forum/crewrktablets-rk3188-entwicklung-customroms-development-croms/rom-kiano-elegance-android-4-4-2-kitkat-custom-root-firmware-20140610/#p43136
Before flash just replace the kernel in folder rockdev/Images: http://crewrktablets.arctablet.com/?wpfb_dl=1817
I tried this ROM, using your kernel replacement, and after a few minutes of trying, it looks soo good!
With the CWM update, the rotation problem is gone. I will try it, and I thik, I will use it.
The following users say thank you to vlevi for this useful post:
Sethi
Brazil
Forum Posts: 93
Thanks Received: 10
60
2014/06/16 - 05:02
Hi there;
I can´t connect hrow Rockchip.. It turns pink, then when i click switch, it goes off and doesn´t come green.. any chance for a CWM file?
I´m on Win8.1 x64 - just to point out, if anyone can help me :(
Currently Online: pater, kpointcom
75 Guest(s)
2 Guest(s)
Devices in use: Desktop (64), Phone (11), Tablet (2)
kpointcom
fendt126
victorprdm1994
sif
tayten
vrtroper
