[ ROM ] Cube U30GT2 Android 4.4.2 KitKat custom root firmware (2014/06/06)
targa
Forum Posts: 14
2014/06/11 - 11:32
I'd like to try that build, but I'm a bit concerned whether I reallly have a U30GT2 ? In the system it only shows U30GT, but it has 3188 chip not 3066 according to CPU Checker, but i.e. Antutu also reports it as U30GT (Rating ~15000). Any clue how to verify ?
Thanks./To
Thanks Received: 3170
2014/06/11 - 12:20
targa,
Maybe check in Settings / About tablet and see if kernel version and build number match one of an existing firmware we have in the U30GT2 forum section.
targa
Forum Posts: 14
2014/06/11 - 16:35
Thanks for that... could have come to my mind earlier ;)
2014/06/11 - 17:43
Last update can be found in post #1, the keyboard issue is hopefully fixed.
maikal, Wintermute
DarthJabba
Forum Posts: 551
Thanks Received: 396
2014/06/11 - 19:21
maikal said
Hmm so right now there is a persistent keyboard problem, and its rejecting the workaround.
Perhaps Admin needs to do another fundraising drive to get arctablet a Cube to work on. With 4.4.3 out and who knows probably 4.4.4 or maybe 5.0 in the future it would be good for us users to get a Cube in their hands or even DarthJabba's able hands.
If we can agree I'm willing to pony up the first $30 or $40 dollars to keep my cube going and up to date. What say you folks? And will Admin or Darth agree if we can come to a consensus on this? EBay has a few going for less than $250US. I saw one going for $219US.
I know the tab is going on two years now but frankly I just haven't seen another with these specs at the price its going for in the past and now. Yeah we can all upgrade to IPads or Surface or whatever, but personally I just haven't got that kind of money and my cube is in pristine condition. If I can keep the operating system up to date for a few more years I'm willing to invest in keeping it going!
Just a thought!
I agree that the Cube, if well assembled, represents excellent value - as long as one doesn't mind having to flash new ROMs.
I am happy to continue to work on Cube ROMs if I have a functional one (it doesn't even have to be new) ...
2014/06/11 - 19:32
Ok, let's do some quick testing ;-)
Cube U30GT2 has RK903 wifi.
Just finished an aproach for a generic KK build, which is here: http://www.arctablet.com/blog/forum/crewrktablets-rk3188-entwicklung-customroms-development-croms/rom-kiano-elegance-android-4-4-2-kitkat-custom-root-firmware-20140610/#p43136
Before flash just replace the kernel in folder rockdev/Images: http://crewrktablets.arctablet.com/?wpfb_dl=1817
Model fix (install via CWM): http://crewrktablets.arctablet.com/?wpfb_dl=1823
Wintermute, postbode, maikal, Jgarciaillanf1, admin, jmiat1100, vlevi, tomtom12
targa
Forum Posts: 14
2014/06/11 - 19:48
Couldnt find any reference to this fw, just in conjunction with some neo tablet, but first thing I did was rooting, thus kernel is probably different anyway.
Screenshot_2014-06-11-19-23-47.pngImage Enlarger
postbode
2014/06/11 - 21:00
hello peeps,
my cube30gt2 tablet keeps getting slower.
Afther a factory reset its fine for a period of weeks (i dont use it every day) but in the end it drivin me mad.
Is anyone familiar with this problem?
I want to flash the new KK firmware in post1, hopin this will solve my problem.
Iflashed the tablet many times before (thx to this forumKiss) so that wont be a problem, i just want my tablet to work fine for a longer time without becoming slow
btw:Do i need to flash the KK build from post 20 ?, or is the version in post1 fine ?
(sorry for the bad english Embarassed)
edit:flashed it, works fine for now, hope it stays this way.
will report back
maikal
Jacksonville, Florida
Forum Posts: 394
Thanks Received: 51
2014/06/12 - 03:58
Pardon me Oma, so this is the new edition of the same rom Admin put together from the Chinese developer? I downloaded the rom but I want to make sure before flashing my cube. Any special instructions if we already have the last kitkat by kasty. Do we have to do the instructions as posted with your creation?
Thanks for all your effort by the way!
Folks any other thoughts regarding putting together a funding for getting a Cube to DarthJabba to help continue the update and rom effort? I know Admin made some good points regarding the upcoming release of 3288, but I wont be able to buy a new tablet with a RK3288 chip until its at least a year old or unless there is some significant upgrades that outclass the current packets found in the RK3188 Cube we currently own. Especially with the love affair I'm committed to with my Cube...lol
Also, I know I'm ahead here, but Admin would Arctablets be willing to host the fundraising and get the money to DarthJabba? I can say I sincerely have confidence that you folks are not going to run off to Amsterdam with the funds :-)
2014/06/12 - 07:31
The build is not from cube. And that's what I'd like to see how good it works on the U30GT2.
The postet kernel is from the kasty build in post #1.
If you are on the kasty build you already have the v2.10 loader running. It's only mandatory to change the loader first if you are switching between JB and KK builds.
2014/06/12 - 09:58
Maikal,
Sure, we'll keep improving the U30GT2 firmwares as we can. Basing our (kasty) custom firmwares over the manufacturer give us limited possibilities of improvement and Cube won't probably update their U30GT2 anymore...
On the other hand, the custom firmware that Oma has just published is something totally fresh and is not based on stock firmware by Cube. So it's done for evaluation as Oma said, given time and some tweaking it may even work better than Cube's releases... I think it's hard to be certain of the result so we shall see how this evolves.
While we still need support to continue running our site here (we have hosting and other costs everything month) it is totally fine to distribute the donations of those willing to help DarthJabba and/or Oma to acquire a CubeU30GT2, helping both was already done once with transferring some small donations we received.
Let's first check interest from forum members on this project here then we can work out the details.
Jgarciaillanf1
jmiat1100
Thanks Received: 5
2014/06/12 - 10:07
testing
works correctly
wifi
bluetooth
sound
dont work
without automatic brightness option
May 4 kernel with auto rotate changed
February 18 kernel with auto rotate works correctly
The following users say thank you to jmiat1100 for this useful post:
targa
Forum Posts: 14
2014/06/12 - 11:26
...and Cube won't probably update their U30GT2 anymore...
I found references somewhere on the internet that Cube is currently testing KK on the GT2. Would it make send to wait for that and ease developer's life ?
2014/06/12 - 11:32
If I am not mistaking, Cube has already produced 2 KitKat firmwares for the U30GT2.
Given the product age, it's expected Cube will stop making updates and focus on newer tablets, that's sad but it seems to be how it works with planned obsolescence in the electronics businessesConfused
Cuz
Forum Posts: 11
2014/06/12 - 12:21
"Please report any problem with this firmware, I can't verify this custom firmware works as I don't have anymore a Cube U30GT2 tablet to test the custom firmware."
kasty-cube_u30gt2-442-funromstudio_20140606-rooted7c
This one is working great for me:-)....
On test at the moment but all seems fine and the keyboard fix seems to OK...
                 Thanks....:-)
The following users say thank you to Cuz for this useful post:
admin, NekCube
146 Guest(s)
Devices in use: Desktop (141), Phone (4), Tablet (1)
printerr724
KarlCharlson
Ser1111
tjkjrukgesibuq
erervervr
lukluk91
