[ ROM ] Cube U30GT2 Android 4.4.2 KitKat custom root firmware (2014/06/06)
trex33
211
2015/09/06 - 13:35
I wasted 5 hours from my life trying to install these drivers on Windows 8.1 64-bit.
I tried 4 differente versions without sucess, pls. provide step-by-step instructions howto install the drivers.
Mark06
Forum Posts: 222
Thanks Received: 41
212
2015/09/07 - 15:11
guess you just need the windows 7 64 bit drivers included with the rockchip batch tool. Then put the tab off, hold volume down in, put the tab on and insert usb cable in tab. The rockbatch tool should now lighten up green.
maikal
Cube u30gt2 tab
maikal
Jacksonville, Florida
Forum Posts: 394
Thanks Received: 51
213
2015/09/07 - 21:07
franklin84 said
This Rom is the best one i found. There was another one which has sound failtures.
I have only a little problem which the touchscreen when the Tab is connected to the charger but the compatibility is the most important for me. 🙂
I used the Rockchip Batch Tool like the picture in post 205.
- install USB Driver
- with tablet OFF, I connect the Tablet to PC
- run rookchip batchtool 1.6
- press VOLUME UP + POWER, then release buttons to make the tablet to be detected by the batchtool
- flash the image by pressing Upgrade
It's also important that you have the right Bootloader installed.
But i dont know exactly what Version is the best one 🙁
If something is needed, i have all files on my PC 🙂
Thank you. Yes I want to try it on a cube I picked up last year, It's still on the last 4.2.2 Kasty before the kit kat Kasty came out. So it should have the non-kitkat bootloader. I still have my orogonal Cube, but it's inner screen is failing (bloated battery). I pull it out once in a while to see if it's still working, hoping to someday try out the Lollipop rom Oma and his team have or had been working on. So I may look into this rom and try out in my older tablet first. Once I figure which booloader it needs.
maikal
Forum Posts: 394
Thanks Received: 51
214
2015/09/07 - 21:10
Good to see you still lurking around. I keep an older Toshiba laptop on hand for flashing since it appears these flashing tool are not being upgraded or newer tools are being developed for newer tablets. Sad, this tablet is still pretty strong for my needs.
Mark06
Forum Posts: 222
Thanks Received: 41
215
2015/09/07 - 21:16
i also have the cube u65gt, but although it's a newer tab, people aren't really busy with the software i think. Maybe the t9 has more people working on it. It's the first cube 64 bit cpu tab.
Cube u30gt2 tab
maikal
Forum Posts: 394
Thanks Received: 51
216
2015/09/07 - 21:29
Admin if you stop by perhaps you can tell us which bootloader this rom needs? referring to the funron in that Franklyn refers to?
Mark06
Forum Posts: 222
Thanks Received: 41
217
2015/09/07 - 21:35
it's the kernel (maybe with bootloader in it), like jelly bean kernel: 4.1, 4.2, 5.0 and kitkat kernel:4.4.
Only with switching between android previous to 5 to 5 you need to be more alert with the kernel, otherways you get flash problems, which will definately take more time to fix. So you can just select the .img file in rockbatch tool and flash it to the cube in 'download mode' (volume up while pressing power button, hold volume button up pressed while inserting the usb cable to pc).
maikal
Cube u30gt2 tab
maikal
Forum Posts: 394
Thanks Received: 51
218
2015/09/07 - 21:36
Mark I picked up a Vido M10 also earlier this year very cheap on ebay, for less than $100US, pretty much same specs as the u30gt2 but w/16gb. That one is on Kasty kit kat. Looks and behaves great, I would say even better than the U30gt2 on the Kasty rom. As to the U65gt, I just looked at it on ebay, very nice but I'm stuck on the 10 inch tablets. I also picked up a Surface RT and it's my daily use, though I'm trying to sell it to finance a newer Surface tablet. But all in all I love my Cube and Vido tabs.
maikal
Forum Posts: 394
Thanks Received: 51
219
2015/09/07 - 21:38
I will try that. Thanks again for sticking around.
Mark06
Forum Posts: 222
Thanks Received: 41
220
2015/09/07 - 21:46
you can flash a zip file with the overclocked kernel on the cube. Then it runs at 1.8ghz. Should be bout the same speed as the vido M10 then.
Cube u30gt2 tab
maikal
Forum Posts: 394
Thanks Received: 51
221
2015/09/07 - 21:58
Yes, I did that on the older Cube I got. It was pretty good, but I think that tablet batch could not stand it. I was one of the guinea pigs for DarthJabba's overclocked kernels. Lol tried them all until I did settle on one slightly overclocked. I think trying all those was what damaged my battery in my first cube. I did buy new batteries, there is a few posts on it, But the damage to the screen was already done by the bloated battery. Still no regrets with the experimenting, it's what helped us all get hose kernels and new roms going. Like I said since I still have the older Cube and screen is still usable even with the lines across it, I will use it to experiment a little more with the Kitkat roms, including this funrom. But it has to wait a little, I'm in the middle of a room remodeling and will only have access to my tablets for a little bit of time to peruse these pages.
maikal
Forum Posts: 394
Thanks Received: 51
222
2015/09/07 - 22:02
Yes I got the repository also...lol I remember it well, like I said I was one of the guinea pigs to try them all. To bad Darth Jabba's Cube was destroyed pretty much when he dropped it I think. I certainly was a fan of his and was hoping he would take us to the promise land...lol He did great work for the Cube and for all of us.
Mark06
Forum Posts: 222
Thanks Received: 41
223
2015/09/25 - 18:09
Maikal, there also is a rom from dartjabba from januari 2014 that's really fast. It's just it has got some bugs with the screen watching facebook movies. But it's a real fast rom for the cube, doubt that it's 20 seconds boot time though like the vido m10.
Cube u30gt2 tab
mfmax
224
2015/10/13 - 10:49
Here is an Android 4.4.2 KitKat rooted firmware for the Cube U30GT2 tablet . This custom firmware is based on Chinese KitKat Funrom_Studio firmware dated 2014/06/06.
(Funrom_Studio-CUBE_U30GT2_4.4.2_V1_140606.img)
400xNxpipo_m9_pro_android442_kitkat_20131226_kitkat_b.png.pagespeed.ic.OX66oTHP96.jpg
Build information:
Kernel: Linux version 3.0.36+ (tangy@tchipserver2) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #95 SMP PREEMPT Sun May 4 15:50:58 CST 2014
Android 4.4.2: CUBE/u30gt2/rk3188:4.4.2/KOT49H/eng.root.20140211.100632:eng/opinions-on-teclast-p90hdst-keys
ro.rksdk.version=RK31_ANDROID$(PLATFORM_VERSION)-SDK-v1.00.00
RK3188Loader(L)_V2.10.bin
As you can read, this firmware seems to be mostly a kernel update as the Android system is still one from February 2014.
  • root with latest SuperSU version 1.99r3 (free version)
  • increased space for applications (/data partition) to 7 GB
  • added Google Experience Launcher (GEL) in addition to Cube's stock launcher
Notes:
- current KitKat based firmwares should be considered as beta software
Download: kasty-cube_u30gt2-442-funromstudio_20140606-rooted7c_mu.zip
If you like our work, please support us to keep the site alive and contribute to our efforts.
Dear Members,
Can i flash this rom over JB 4.2.2 supersport ROM v.1.1 ?
Thanx for help
franklin84
Forum Posts: 14
225
2015/10/28 - 20:35
Should be no problem with the "Rockchip Batch Tool"!
I also make several changes to find the best Firmware for me.
Please make a clean Flash and delete all user data and wipe the cache!
The following users say thank you to franklin84 for this useful post:
mfmax
95 Guest(s)
Devices in use: Desktop (85), Phone (9), Tablet (1)
dubsiki
dubsi
vblxcimdwqgcztgrve
billcamp1984
simoxor33
kontra007
