[ ROM ] Cube U30GT2 Android 4.4.2 KitKat custom root firmware (2014/06/06)
Mark06
Forum Posts: 222
Thanks Received: 41
196
2015/03/29 - 15:32
system icon voice or something like that, also with build prop editor.
Cube u30gt2 tab
franklin84
Forum Posts: 14
197
2015/03/29 - 17:48
Hello!
I have no problems with the brightness but the automatic function works not good, it's allways to dark and no settings to adjust it :-(
But there is another little problem:
The touchscreen doesn'T work probably if the tab charges!
How can I fix it?
Best regards,
Frank
Mark06
Forum Posts: 222
Thanks Received: 41
198
2015/03/29 - 18:57
franklin84 said
Hello!
How can I fix it?
Best regards,
Frank
What rom did you install?
Cube u30gt2 tab
Mark06
Forum Posts: 222
Thanks Received: 41
199
2015/03/29 - 19:53
Gamelyn said
As a badge-holding forum lurker it's not often I poke my head above the parapet and blink in the daylight.
I'm not sure if posting thanks is OK, but the ROM in the OP fixed my Cube.
It was sluggish, slow and virtually unusable - so much so that it drove me to try this, and I'm glad I did.
Battery drain is still a problem, but apart from that, my Cube shines in all it does.
Sanity (and Cube love) restored
Thankyou
What OP do you mean and what rom? For the battery use, when in sleep a lot you can use cpusleeper 4.0. It works very good on my tab, like 93 percent and 17 hours runtime.
Cube u30gt2 tab
franklin84
Forum Posts: 14
200
2015/04/04 - 20:06
Mark06 said
franklin84 said
Hello!
How can I fix it?
Best regards,
Frank
Hello!
I used the "Funrom Studio U30GT2_4.4.2_V!!140606"
Stock Rom makes more trouble with sound in games.
Best regards
Frank
Herb
201
2015/07/25 - 08:43
So I flashed this rom 2 days ago and I must say WOW. It is like everyone mentioned. It is a huge improvement.
I have the MH version and every thing seems to be working fine.
Thank you so much for the work that you did with this rom.
cooljsn
202
2015/08/02 - 17:48
Hello Friends.
I have Cube U30GT2 unflashed. I threw it in a corner when I noticed chinese application and few issue. My other tablet stopped working so thought of fixing my cube tablet.
My tablet is still in original rom etc (not rooted / flashed or anything) with android vs 4.2.2
I tried flashing the zip file in post 1 using rockchip batch tool 1.7 but my win 8.1 tablt is not recognising the drivers.
Any help is much appreciated.
Regards
SN
franklin84
Forum Posts: 14
203
2015/08/02 - 22:17
I had also big problems on Win7.
Still use another USB Port or simply push the "Switch" Button and voilá the device will be recognized! 🙂
cooljsn
204
2015/08/02 - 22:46
Hi Franklin what does it mean by
Is this  switch button  in Cube tablet?
SN
franklin84
Forum Posts: 14
205
2015/08/04 - 16:33
See the attachment 🙂
Unbenannt.JPGImage Enlarger
Shoshi
206
2015/08/31 - 22:25
I am unable to fully download the rom. I have have tried in Chrome and using uGet (in single threaded mode).
carmaster
207
2015/09/02 - 22:09
I am unable to fully download the rom. Does anyone have a new download link ???
Thank's Heinz
franklin84
Forum Posts: 14
208
2015/09/05 - 10:27
Hello!
Here a new upload from me. I hope it will work 🙂
kasty-cube-u30gt2-442-funromstudio-20140606-rooted7c-mu-img
Best Regards
maikal
Jacksonville, Florida
Forum Posts: 394
Thanks Received: 51
209
2015/09/06 - 03:38
franklin84 said
Hello!
Best Regards
Frank do you mean this is a different rom, a different link to the OP rom. Can you provide your flashing instructions? I have a another cube I can try this on if it's different than the kasty! Also how is it running if different than kasty! What tool did you use?
franklin84
Forum Posts: 14
210
2015/09/06 - 11:26
This Rom is the best one i found. There was another one which has sound failtures.
I have only a little problem which the touchscreen when the Tab is connected to the charger but the compatibility is the most important for me. 🙂
I used the Rockchip Batch Tool like the picture in post 205.
- install USB Driver
- with tablet OFF, I connect the Tablet to PC
- run rookchip batchtool 1.6
- press VOLUME UP + POWER, then release buttons to make the tablet to be detected by the batchtool
- flash the image by pressing Upgrade
It's also important that you have the right Bootloader installed.
But i dont know exactly what Version is the best one 🙁
If something is needed, i have all files on my PC 🙂
The following users say thank you to franklin84 for this useful post:
maikal
113 Guest(s)
Devices in use: Desktop (104), Phone (9)
anonymunbekannter14
dimas6086
JiotaCe
Oboronprom
vlk88
JozekPL
