[ ROM ] Cube U30GT2 Android 4.4.2 KitKat custom root firmware (2014/06/06)
stathis1985
Forum Posts: 15
Thanks Received: 6
181
2015/01/07 - 11:23
Hey,
I had the same issue. The easy way to enable them is to add the Power Managment widget on the home screen (the widged that control the WiFi, Bluetooth, Location Services etc.) and activate it from there. Then go into settings and voilà.... the Location services are availble.
The following users say thank you to stathis1985 for this useful post:
SebT, maikal, evesham
stathis1985
Forum Posts: 15
Thanks Received: 6
182
2015/01/07 - 11:25
SebT said
maikal said
SebT said
I have same problem (NeurOSick)
Hi, any way to have the “Location” setting/option working? For now all options are disabled.
Have you downloaded the map apps? I seem to remember with this rom or the other kit Kat rom that there was an issue and it was fixed downloading the Google map or Google earth app.
Also be sure to set up Google + to show location if you haven't in the settings.
I uninstall maps, street view, google earth.
I delete data for these applications
I download maps, street view, google earth.
I download Google+ & Configuration OK
Always the same problem :(
I do not have the button "ON / OFF" near Location.
Hey,
I had the same issue. The easy way to enable them is to add the Power Managment widget on the home screen (the widged that control the WiFi, Bluetooth, Location Services etc.) and activate it from there. Then go into settings and voilà…. the Location services are availble.
maikal
SebT
183
2015/01/07 - 11:26
stathis1985 said
Hey,
OMG thanks
it's ok now ^_^
evesham
184
2015/01/09 - 12:23
hi guys, although i've had the cube u30gt2 for ages now its the first time I've ever flashed it and I used this rom.
How can I get my volume up and down icons on the bottom status bar?
thanks for any help
franklin84
Forum Posts: 14
185
2015/01/10 - 21:20
i spend a lot of time to install this ROM, because my computer makes a lot of trouble and didn't recognize the Tablet! :-(
Now it's installed and I upgrade to OMAs CWM with the Arctools.
But now i have the same problem like the user"ntinos_tech" on page 8 (post 110) and the tablet suddenly shutdown with no reason!
I noticed that the battery is not charged to 100%, it reaches only a maximum of 93% and not more.
So i seached a solution and tried the app "Battery Calibration" witch corrects the battery.stats, but it also has this failure :-(
Anyone an idea? Please help!!
With Charger plugged in, all went OK!
Best regards,
Frank
Gamelyn
186
2015/01/13 - 14:55
As a badge-holding forum lurker it's not often I poke my head above the parapet and blink in the daylight.
I'm not sure if posting thanks is OK, but the ROM in the OP fixed my Cube.
It was sluggish, slow and virtually unusable - so much so that it drove me to try this, and I'm glad I did.
Battery drain is still a problem, but apart from that, my Cube shines in all it does.
Sanity (and Cube love) restored
Thankyou
franklin84
Forum Posts: 14
187
2015/01/13 - 19:24
Here a topic about the battery failure.
Only written in german, but it's fact that the batteries have a poor quality..
http://www.android-hilfe.de/cube-u30gt2-forum/572886-cube-u30gt2-crasht-nach-kurzer-laufzeit.html
Mark06
Forum Posts: 222
Thanks Received: 41
188
2015/01/16 - 13:19
Buy yourself a new battery through alibabba Chinese store for 18 dollars free shipping.
Cube u30gt2 tab
slavrik
189
2015/01/18 - 08:15
On the 4.4.2 firmware freezes the camera in Skype right after the beginning of the call, the picture I have freezes, but the subscriber sees me. What is the matter? (4.2.2 all OK)
Hoed-Jr
190
2015/03/27 - 22:04
I installed the rom (kasty-cube U30GT2-442-funromstudio 20140606 rooted7c mu) after a battery change. Now I'm wondering, how can the brightness be set to a lower value than the minimal value currently available? (Since it feels a bit like having a torch in my hand, wrong side up.) Couldn't find an answer on the forum.
Thanks in advance
jesmail
usa
Forum Posts: 26
Thanks Received: 5
191
2015/03/28 - 01:14
Go to the settings, select display and then Brightness. Adjust to your taste.
Hoed-Jr
192
2015/03/28 - 10:51
Thanks, I know, but what if the lowest setting there is still too bright? (There isn't much difference between the highest and lowest setting.) Is there a way to set the brightness of the lowest setting to even lower?
Mark06
Forum Posts: 222
Thanks Received: 41
193
2015/03/28 - 15:36
Off course, look for an app to adjust your brightness settings. You may very well have to have a rooted device for it.
Hoed-Jr
Cube u30gt2 tab
Mark06
Forum Posts: 222
Thanks Received: 41
194
2015/03/28 - 15:38
I'm not sure, maybe you have to adjust prop. build with the editor. Search for lcd. So build prop editor app to install than search for lcd. The chinese advised a time ago to adjust that setting, i still don't know why.
Cube u30gt2 tab
slavrik
195
2015/03/29 - 15:13
Thanks for reply. I edited build.prop:"ro.sf.lcdc_composer=1" to "ro.sf.lcdc_composer=0" Camera work properly,but have some issue with toolbar as flicker.
96 Guest(s)
Devices in use: Desktop (82), Phone (14)
anonymunbekannter14
dimas6086
JiotaCe
Oboronprom
vlk88
JozekPL
