[ ROM ] Cube U30GT2 Android 4.4.2 KitKat custom root firmware (2014/06/06)
Jgarciaillanf1
Forum Posts: 35
Thanks Received: 13
136
2014/07/12 - 01:24
musico59 said
Thanks to speak about thé kasty kitkat ROM..... oma rom has his own topic !
It 's make everybody confused
The problem is that OMA haven't got his own thread...
cocofish
137
2014/07/12 - 04:00
Does OMA rom soluve the a/v async problem?
sorrento01
138
2014/07/12 - 10:45
Thank you, your rom is very good.
musico59
Forum Posts: 14
139
2014/07/14 - 08:27
// <![CDATA[
(function(){var e=encodeURIComponent,f=window,h=document,m="width",n="documentElement",p="height",q="length",r="prototype",s="body",t="&",u="&ci=",w="&n=",x="&rd=",y=",",z="?",A="Content-Type",B="Microsoft.XMLHTTP",C="Msxml2.XMLHTTP",D="POST",E="application/x-www-form-urlencoded",F="img",G="input",H="load",I="oh=",J="on",K="pagespeed_url_hash",L="url=",M=function(a,c,d){if(a.addEventListener)a.addEventListener(c,d,!1);else if(a.attachEvent)a.attachEvent(J+c,d);else{var b=a[J+c];a[J+c]=function(){d.call(this);
b&&b.call(this)}}};f.pagespeed=f.pagespeed||{};var N=f.pagespeed,O=function(a,c,d,b,g){this.d=a;this.f=c;this.g=d;this.a=g;this.c={height:f.innerHeight||h[n].clientHeight||h[s].clientHeight,width:f.innerWidth||h[n].clientWidth||h[s].clientWidth};this.e=b;this.b={}};O[r].j=function(a){a=a.getBoundingClientRect();return{top:a.top+(void 0!==f.pageYOffset?f.pageYOffset:(h[n]||h[s].parentNode||h[s]).scrollTop),left:a.left+(void 0!==f.pageXOffset?f.pageXOffset:(h[n]||h[s].parentNode||h[s]).scrollLeft)}};
O[r].i=function(a){if(0>=a.offsetWidth&&0>=a.offsetHeight)return!1;a=this.j(a);var c=a.top.toString()+y+a.left.toString();if(this.b.hasOwnProperty(c))return!1;this.b[c]=!0;return a.top<=this.c[p]&&a.left<=this.c[m]};
O[r].l=function(){for(var a=[F,G],c=[],d={},b=0;b<a[q];++b)for(var g=h.getElementsByTagName(a[b]),k=0;k<g[q];++k){var v=g[k].getAttribute(K);v&&g[k].getBoundingClientRect&&this.i(g[k])&&!(v in d)&&(c.push(v),d[v]=!0)}b=!1;a=I+this.g;this.a&&(a+=w+this.a);if(0!=c[q]){a+=u+e(c[0]);for(b=1;b<c[q];++b){d=y+e(c[b]);if(131072=a[q]+d[q]&&(a+=d),b=!0);N.criticalImagesBeaconData=a;if(b){var c=this.d,b=this.f,l;if(f.XMLHttpRequest)l=
new XMLHttpRequest;else if(f.ActiveXObject)try{l=new ActiveXObject(C)}catch(P){try{l=new ActiveXObject(B)}catch(Q){}}l&&(l.open(D,c+(-1==c.indexOf(z)?z:t)+L+e(b)),l.setRequestHeader(A,E),l.send(a))}};
O[r].h=function(){for(var a={},c=h.getElementsByTagName(F),d=0;d<c[q];++d){var b=c[d],g=b.getAttribute(K);if("undefined"==typeof b.naturalWidth||"undefined"==typeof b.naturalHeight||"undefined"==typeof g)break;if("undefined"==typeof a[b.src]&&0<b[m]&&0<b[p]&&0<b.naturalWidth&&0=a[b.src].n&&b[p]>=a[b.src].m)a[g]={renderedWidth:b[m],renderedHeight:b[p],originalWidth:b.naturalWidth,originalHeight:b.naturalHeight}}return a};
N.k=function(a,c,d,b,g){var k=new O(a,c,d,b,g);M(f,H,function(){f.setTimeout(function(){k.l()},0)})};N.criticalImagesBeaconInit=N.k;})();
pagespeed.criticalImagesBeaconInit('/mod_pagespeed_beacon','http://www.arctablet.com/blog/index.php?sp_ahah=quote&sfnonce=5c337a1d4c&post=44270&forumid=132','5Czn0lsVdP',false,'374DngoN6qs');
Wich one ?
Oma rom has his own thread so please put here feedback about the Kasty rom from admin !
rolandbouma
140
2014/07/14 - 10:02
Guys, i'm new here but following the upgrades of the cube u30gt2. The upgrates are great but one thing is still wondering me......why is the battery drain stil nor solved!!??
can one of you focus on that? My tablet has power for less than 24 hours without use and no heavy apps installed
Here is an Android 4.4.2 KitKat rooted firmware for the Cube U30GT2 tablet . This custom firmware is based on Chinese KitKat Funrom_Studio  2014/06/06.
(Funrom_Studio-CUBE_U30GT2_4.4.2_V1_140606.img)
400xNxpipo_m9_pro_android442_kitkat_20131226_kitkat_b.png.pagespeed.ic.OX66oTHP96.jpg
Build information:
Kernel: Linux version 3.0.36+ (tangy@tchipserver2) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #95 SMP PREEMPT Sun May 4 15:50:58 CST 2014
Android 4.4.2: CUBE/u30gt2/rk3188:4.4.2/KOT49H/eng.root.20140211.100632:eng/opinions-on-teclast-p90hdst-keys
ro.rksdk.version=RK31_ANDROID$(PLATFORM_VERSION)-SDK-v1.00.00
RK3188Loader(L)_V2.10.bin
As you can read, this firmware seems to be mostly a kernel update as the Android system is still one from February 2014.
  • root with latest SuperSU version 1.99r3 (free version)
  • increased space for applications (/data partition) to 7 GB
  • added Google Experience Launcher (GEL) in addition to Cube's stock launcher
Notes:
- current KitKat based firmwares should be considered as beta software
Download: kasty-cube_u30gt2-442-funromstudio_20140606-rooted7c_mu.zip
If you like our work, please support us to keep the site alive and contribute to our efforts.
// <![CDATA[
pagespeed.criticalImagesBeaconInit('/mod_pagespeed_beacon','http://www.arctablet.com/blog/index.php?sp_ahah=quote&sfnonce=36df800b05&post=43113&forumid=132','5Czn0lsVdP',false,'DEI512_tNmk');
Wintermute
Forum Posts: 89
Thanks Received: 30
141
2014/07/14 - 10:42
It could've been worse and it has been worse. What we have now is somewhat tolerable overal I reckon.
With less than 24 hrs on standby though there is some problem with your unit. Even with my badly weared battery which can't provide more than 3 hrs under load anymore (since earlier 4.4.2 killed the battery) I can have several days on standby easily.
Some ideas:
1. Switch off WiFi for standby mode via advanced settings. By default it's on iirc. Poor decision imo.
2. Consider flashing overclocked kernel. It may sound silly but beyond overclocking it also allows underclocking which is helpful to save power, specifically in idle and standby situations.
3. Check your battery health / performance. How long time it takes to charge fully from zero and discharge in normal use?
4. There have been some initiatives to remove phone specific apps from tablet to save power.
5. To get applications running in background under control, search for Greenify on Google Play.
eeprom
Forum Posts: 15
142
2014/07/16 - 05:24
any news from cube? nothing?
aurel.14
143
2014/07/19 - 09:52
Hy,
i've try lot of rom since i've my tablet.
For me the best rom is "Oma_RK31_Kiano_Elegance_KK_4.4.2_v1.0_gen2 loader"
No need to be overcloked to be fluid ! CPU at 1,6 Ghz is enouth.
There'is only one pb with this rom : The rotation of the screen is decaled of 90°. I d'ont now if there is a solution to resolve this ?
I've a second pb but i don't think is because of the rom: my battery is bad, don't recharge. it's a new battery that i had changed it 2 month ago. I think is because i had used the overcloked kernel T15 befor ...
Sorry for my bad english.
ntinos_tech
Forum Posts: 19
144
2014/07/19 - 17:24
Aurel.14 and all the others.....that have issues with battery like not charging...or batteries are exhausted ... or tablet shut down and then not power on unless power cable is on......I am 99% sure that our issues ARE related to Roms...... for me there are at least 3 possible explanations:
1. For sure there are sensors that provide feedback to the ROM about the charging and the discharging and the battery status in terms of remaining voltage etc. THESE sensors are not used or misused or just ignored from these ROMs. So, at the end the tablet stop the charge, the batteries are empty so the tablet shut down. So, no problem on the batteries
2. Another explanation may be, that due to the above...the batteries are exhausted physically so we have to replace them.
3. ROM change is coincidence..in relation with the BATTERY LIFE END!
I got back from 4.4.2 to 4.2.x but the problem is still there! Many people reported same behavior after moving to 4.4.2....not this specific ROM but in general. At other forums, people is reporting that even with NEW battery installed they have the same issue..
Sorry guys but for me the root cause is the ROM since this is the main and the starting point for everybody facing the same battery issues....what we are all facing is NOT just low battery life..is a battery DEATH! Anyone that may help or advice is more than welcome!
Attention this message is NOT to say bad things for the people that are developing the ROMS and they are helping us.....is just to provide feedback to new people that want to try ROMs 4.4.2 on this stupid TABLET! Really NOTHING personal or bad for the developers PLEASE CONTINUE to support and HELP !!!! this piece of scrub(the tablet) is the issue at the end!
shokk2
145
2014/07/28 - 19:35
Hello, Guys i have questions, where i can got overclocking 95 karniel ? if any can give me that.
cio
146
2014/08/01 - 10:49
aurel.14 said
Hy,
The model fix also rotates 90º the screen
Model fix (install via CWM): http://crewrktablets.arctablet.com/?wpfb_dl=1823
The following users say thank you to cio for this useful post:
aurel.14
ntinos_tech
Forum Posts: 19
147
2014/08/08 - 10:59
I have news....I removed the batteries....meaning disconnected...guess what...tablet has exactly the same attitude...97% charging was the status of the batteries while batteries where disconnected! after 30 minutes....the status was charged although the batteries were disconnected(on my hands)!Can anyone have any idea..what else to try now that the tablet is open.. techinically speaking "open".
Thank you in advanced!
aurel.14
148
2014/08/12 - 07:25
Thx verry much it work fine :)
aurel.14
149
2014/08/12 - 07:39
It's verry strange phenomen.
I'll try to do the same experiance to compare with my U30gt2.
I think the pb is with android 4.4 and the battery managment of the u30gt2. i change my battery and 1 month later she's no charge.
I the past i saw a solution to recalibrate the battery by remove it ... http://www.alliance-rom.com/wiki/battery-life/
It' could be interesting to test this solution but it's impossible to charge the u30gt2 without start it :( maybe in recovery mode ?
Cuz
Forum Posts: 11
150
2014/08/14 - 13:23
aurel.14 said
ntinos_tech said
It' could be interesting to test this solution but it's impossible to charge the u30gt2 without start it maybe in recovery mode ?
With this Rom my tablet would charge whilst turned off
http://www.arctablet.com/blog/downloads/firmware/Cube/kasty-cube_u30gt2-422-206_20131029-rooted4.zip
When i plugged in the charger the tablet would start up as normal but i was able to then turn it off and it would carry on charging whilst turned off.
I'm now not able to do that on my current KitKat rom.
Currently Online: dennis52538
100 Guest(s)
Devices in use: Desktop (88), Phone (11), Tablet (2)
anddna
aanndd
kodoxec
avrahamsh
romweaponpad
suetmay
