[ ROM ] Cube U30GT2 Android 4.4.2 KitKat custom root firmware (2014/02/19)
DarthJabba
Forum Posts: 551
Thanks Received: 396
121
2014/04/21 - 08:46
hornjo said
I followed the instructions in the read-me text for the Kit Kat upgrade kasty_442_20140219_rooted7_DJ_cpu1800_gpu768_ddr600_201403142222
I used CWM.  Everything looked ok until I rebooted the tablet.  I waited 10, 20 and finally after 30mins of looking at the cube logo, I panicked and held down the power button for 20 secs.  The Cube shot down, but every time I try to turn it back on I am stuck at the boot logo.
I tried the vol+ and then plugged in the usb and it was detected by batch tool 1.7, green box.
What should I do next?
I was coming from 4.2 and did not see any warnings about jumping from 4.2 - 4.4.
Hmmm ... the download thread contains this warning, in bold letters: "Installation (NOTE: your tablet must already be running KitKat 4.4.x):". I think that is clear enough.
As for what to do now - you go back to 4.2, using the batch tool.
maikal
hornjo
122
2014/04/21 - 23:30
Well I guess I am blind because I still can't see that warning on the first post for this ROM, and it does not mention that in the read me file.  Oh well, live and learn
As for what to do now – you go back to 4.2, using the batch tool.
Since my tablet is recognized by the batch tool, do I just have to put the update.img form kasty-cube_u30gt2-422-204t_20130706-rooted4 in the tool and press restore?  Will this get me back to a functioning Cube?
maikal
Jacksonville, Florida
Forum Posts: 394
Thanks Received: 51
123
2014/04/22 - 04:05
Thats because you said you downloaded the DJ rom, which is in another thread on the list of threads for this forum. Darth Jabba is correct in his statement. The warning is there!
As for how to go back to 4.2, well there are several threads on that also on the list of threads! As well as several posting on the previous and this kitkat thread.
DarthJabba
Forum Posts: 551
124
2014/04/22 - 08:49
If all that you did was to try to install a KK ROM from CWM, then, yes. The CWM script would not have touched your bootloader, which would still be the JB loader, and so just restoring a JB ROM should work.
hornjo
ebeb2 U30GT2
Australia
Forum Posts: 36
Thanks Received: 9
125
2014/04/25 - 02:55
// <![CDATA[
(function(){var e=encodeURIComponent,f=window,h=document,m="width",n="documentElement",p="height",q="length",r="prototype",s="body",t="&",u="&ci=",w="&n=",x="&rd=",y=",",z="?",A="Content-Type",B="Microsoft.XMLHTTP",C="Msxml2.XMLHTTP",D="POST",E="application/x-www-form-urlencoded",F="img",G="input",H="load",I="oh=",J="on",K="pagespeed_url_hash",L="url=",M=function(a,c,d){if(a.addEventListener)a.addEventListener(c,d,!1);else if(a.attachEvent)a.attachEvent(J+c,d);else{var b=a[J+c];a[J+c]=function(){d.call(this);b&&b.call(this)}}};f.pagespeed=f.pagespeed||{};var N=f.pagespeed,O=function(a,c,d,b,g){this.d=a;this.f=c;this.g=d;this.a=g;this.c={height:f.innerHeight||h[n].clientHeight||h[s].clientHeight,width:f.innerWidth||h[n].clientWidth||h[s].clientWidth};this.e=b;this.b={}};O[r].j=function(a){a=a.getBoundingClientRect();return{top:a.top+(void 0!==f.pageYOffset?f.pageYOffset:(h[n]||h[s].parentNode||h[s]).scrollTop),left:a.left+(void 0!==f.pageXOffset?f.pageXOffset:(h[n]||h[s].parentNode||h[s]).scrollLeft)}};O[r].i=function(a){if(0>=a.offsetWidth&&0>=a.offsetHeight)return!1;a=this.j(a);var c=a.top.toString()+y+a.left.toString();if(this.b.hasOwnProperty(c))return!1;this.b[c]=!0;return a.top<=this.c[p]&&a.left<=this.c[m]};O[r].l=function(){for(var a=[F,G],c=[],d={},b=0;b<a[q];++b)for(var g=h.getElementsByTagName(a[b]),k=0;k<g[q];++k){var v=g[k].getAttribute(K);v&&g[k].getBoundingClientRect&&this.i(g[k])&&!(v in d)&&(c.push(v),d[v]=!0)}b=!1;a=I+this.g;this.a&&(a+=w+this.a);if(0!=c[q]){a+=u+e(c[0]);for(b=1;b<c[q];++b){d=y+e(c[b]);if(131072=a[q]+d[q]&&(a+=d),b=!0);N.criticalImagesBeaconData=a;if(b){var c=this.d,b=this.f,l;if(f.XMLHttpRequest)l=new XMLHttpRequest;else if(f.ActiveXObject)try{l=new ActiveXObject(C)}catch(P){try{l=new ActiveXObject(B)}catch(Q){}}l&&(l.open(D,c+(-1==c.indexOf(z)?z:t)+L+e(b)),l.setRequestHeader(A,E),l.send(a))}};O[r].h=function(){for(var a={},c=h.getElementsByTagName(F),d=0;d<c[q];++d){var b=c[d],g=b.getAttribute(K);if("undefined"==typeof b.naturalWidth||"undefined"==typeof b.naturalHeight||"undefined"==typeof g)break;if("undefined"==typeof a[b.src]&&0<b[m]&&0<b[p]&&0<b.naturalWidth&&0=a[b.src].n&&b[p]>=a[b.src].m)a[g]={renderedWidth:b[m],renderedHeight:b[p],originalWidth:b.naturalWidth,originalHeight:b.naturalHeight}}return a};N.k=function(a,c,d,b,g){var k=new O(a,c,d,b,g);M(f,H,function(){f.setTimeout(function(){k.l()},0)})};N.criticalImagesBeaconInit=N.k;})();pagespeed.criticalImagesBeaconInit('/mod_pagespeed_beacon','http://www.arctablet.com/blog/index.php?sp_ahah=quote&sfnonce=630e6ba416&post=41623&forumid=132','W4fY5kTX1u',false,'hNvNwHOLoR0');
Hey,
Everytime I reboot the sd card doesn't mount. I have physically remove the sd card and put it back. Any solutions?
hornjo
126
2014/04/26 - 14:25
// <![CDATA[
(function(){var e=encodeURIComponent,f=window,h=document,m="width",n="documentElement",p="height",q="length",r="prototype",s="body",t="&",u="&ci=",w="&n=",x="&rd=",y=",",z="?",A="Content-Type",B="Microsoft.XMLHTTP",C="Msxml2.XMLHTTP",D="POST",E="application/x-www-form-urlencoded",F="img",G="input",H="load",I="oh=",J="on",K="pagespeed_url_hash",L="url=",M=function(a,c,d){if(a.addEventListener)a.addEventListener(c,d,!1);else if(a.attachEvent)a.attachEvent(J+c,d);else{var b=a[J+c];a[J+c]=function(){d.call(this);b&&b.call(this)}}};f.pagespeed=f.pagespeed||{};var N=f.pagespeed,O=function(a,c,d,b,g){this.d=a;this.f=c;this.g=d;this.a=g;this.c={height:f.innerHeight||h[n].clientHeight||h[s].clientHeight,width:f.innerWidth||h[n].clientWidth||h[s].clientWidth};this.e=b;this.b={}};O[r].j=function(a){a=a.getBoundingClientRect();return{top:a.top+(void 0!==f.pageYOffset?f.pageYOffset:(h[n]||h[s].parentNode||h[s]).scrollTop),left:a.left+(void 0!==f.pageXOffset?f.pageXOffset:(h[n]||h[s].parentNode||h[s]).scrollLeft)}};O[r].i=function(a){if(0>=a.offsetWidth&&0>=a.offsetHeight)return!1;a=this.j(a);var c=a.top.toString()+y+a.left.toString();if(this.b.hasOwnProperty(c))return!1;this.b[c]=!0;return a.top<=this.c[p]&&a.left<=this.c[m]};O[r].l=function(){for(var a=[F,G],c=[],d={},b=0;b<a[q];++b)for(var g=h.getElementsByTagName(a[b]),k=0;k<g[q];++k){var v=g[k].getAttribute(K);v&&g[k].getBoundingClientRect&&this.i(g[k])&&!(v in d)&&(c.push(v),d[v]=!0)}b=!1;a=I+this.g;this.a&&(a+=w+this.a);if(0!=c[q]){a+=u+e(c[0]);for(b=1;b<c[q];++b){d=y+e(c[b]);if(131072=a[q]+d[q]&&(a+=d),b=!0);N.criticalImagesBeaconData=a;if(b){var c=this.d,b=this.f,l;if(f.XMLHttpRequest)l=new XMLHttpRequest;else if(f.ActiveXObject)try{l=new ActiveXObject(C)}catch(P){try{l=new ActiveXObject(B)}catch(Q){}}l&&(l.open(D,c+(-1==c.indexOf(z)?z:t)+L+e(b)),l.setRequestHeader(A,E),l.send(a))}};O[r].h=function(){for(var a={},c=h.getElementsByTagName(F),d=0;d<c[q];++d){var b=c[d],g=b.getAttribute(K);if("undefined"==typeof b.naturalWidth||"undefined"==typeof b.naturalHeight||"undefined"==typeof g)break;if("undefined"==typeof a[b.src]&&0<b[m]&&0<b[p]&&0<b.naturalWidth&&0=a[b.src].n&&b[p]>=a[b.src].m)a[g]={renderedWidth:b[m],renderedHeight:b[p],originalWidth:b.naturalWidth,originalHeight:b.naturalHeight}}return a};N.k=function(a,c,d,b,g){var k=new O(a,c,d,b,g);M(f,H,function(){f.setTimeout(function(){k.l()},0)})};N.criticalImagesBeaconInit=N.k;})();pagespeed.criticalImagesBeaconInit('/mod_pagespeed_beacon','http://www.arctablet.com/blog/index.php?sp_ahah=quote&sfnonce=71b81b898f&post=41623&forumid=132','W4fY5kTX1u',false,'zmaovI9cCMY');
Thanks for all the replies, I am back to a working Cube with 4.2.
I mixed up the 4.4.2 rom threads. (stupid monkey :)
I just need some clarification, 4.4.2 DJ rom requirement states- must already be running a 4.4 rom as per install warning
Non DJ 4.42 rom does not mention the already running 4.4 rom requirement, so can I use the rom from this thread to jump from 4.2 directly to 4.4.2?
twart
Liverpool
Forum Posts: 24
Thanks Received: 17
127
2014/04/26 - 14:30
// <![CDATA[
(function(){var e=encodeURIComponent,f=window,h=document,m="width",n="documentElement",p="height",q="length",r="prototype",s="body",t="&",u="&ci=",w="&n=",x="&rd=",y=",",z="?",A="Content-Type",B="Microsoft.XMLHTTP",C="Msxml2.XMLHTTP",D="POST",E="application/x-www-form-urlencoded",F="img",G="input",H="load",I="oh=",J="on",K="pagespeed_url_hash",L="url=",M=function(a,c,d){if(a.addEventListener)a.addEventListener(c,d,!1);else if(a.attachEvent)a.attachEvent(J+c,d);else{var b=a[J+c];a[J+c]=function(){d.call(this);b&&b.call(this)}}};f.pagespeed=f.pagespeed||{};var N=f.pagespeed,O=function(a,c,d,b,g){this.d=a;this.f=c;this.g=d;this.a=g;this.c={height:f.innerHeight||h[n].clientHeight||h[s].clientHeight,width:f.innerWidth||h[n].clientWidth||h[s].clientWidth};this.e=b;this.b={}};O[r].j=function(a){a=a.getBoundingClientRect();return{top:a.top+(void 0!==f.pageYOffset?f.pageYOffset:(h[n]||h[s].parentNode||h[s]).scrollTop),left:a.left+(void 0!==f.pageXOffset?f.pageXOffset:(h[n]||h[s].parentNode||h[s]).scrollLeft)}};O[r].i=function(a){if(0>=a.offsetWidth&&0>=a.offsetHeight)return!1;a=this.j(a);var c=a.top.toString()+y+a.left.toString();if(this.b.hasOwnProperty(c))return!1;this.b[c]=!0;return a.top<=this.c[p]&&a.left<=this.c[m]};O[r].l=function(){for(var a=[F,G],c=[],d={},b=0;b<a[q];++b)for(var g=h.getElementsByTagName(a[b]),k=0;k<g[q];++k){var v=g[k].getAttribute(K);v&&g[k].getBoundingClientRect&&this.i(g[k])&&!(v in d)&&(c.push(v),d[v]=!0)}b=!1;a=I+this.g;this.a&&(a+=w+this.a);if(0!=c[q]){a+=u+e(c[0]);for(b=1;b<c[q];++b){d=y+e(c[b]);if(131072=a[q]+d[q]&&(a+=d),b=!0);N.criticalImagesBeaconData=a;if(b){var c=this.d,b=this.f,l;if(f.XMLHttpRequest)l=new XMLHttpRequest;else if(f.ActiveXObject)try{l=new ActiveXObject(C)}catch(P){try{l=new ActiveXObject(B)}catch(Q){}}l&&(l.open(D,c+(-1==c.indexOf(z)?z:t)+L+e(b)),l.setRequestHeader(A,E),l.send(a))}};O[r].h=function(){for(var a={},c=h.getElementsByTagName(F),d=0;d<c[q];++d){var b=c[d],g=b.getAttribute(K);if("undefined"==typeof b.naturalWidth||"undefined"==typeof b.naturalHeight||"undefined"==typeof g)break;if("undefined"==typeof a[b.src]&&0<b[m]&&0<b[p]&&0<b.naturalWidth&&0=a[b.src].n&&b[p]>=a[b.src].m)a[g]={renderedWidth:b[m],renderedHeight:b[p],originalWidth:b.naturalWidth,originalHeight:b.naturalHeight}}return a};N.k=function(a,c,d,b,g){var k=new O(a,c,d,b,g);M(f,H,function(){f.setTimeout(function(){k.l()},0)})};N.criticalImagesBeaconInit=N.k;})();pagespeed.criticalImagesBeaconInit('/mod_pagespeed_beacon','http://www.arctablet.com/blog/index.php?sp_ahah=quote&sfnonce=5dc51ba786&post=41802&forumid=132','W4fY5kTX1u',false,'CSPJe5X4VMA');
Yep. Easy as pie. I went from Kasty 2.06 to the KitKat 4.4.2 with no issues. Still the best ROM ever.
The following users say thank you to twart for this useful post:
hornjo
"If I wanted your opinion, I'd give it to you"
t.w@ - Battling whinge-bags since '71
shmox
128
2014/04/26 - 22:19
Hi, is there a way to downgrade display resolution from hd to sd like previous rom ?
DarthJabba
Forum Posts: 551
129
2014/04/27 - 23:44
annoluce
Forum Posts: 19
130
2014/04/29 - 20:20
Hi, would like to install this Rom.
I currently run the stock Rom, based on android 4.2.2.
Can I flash this directly on it?
Max
lambo2000
131
2014/04/29 - 23:47
Yes,
Read the first post how to do it.
validatus
Advanced Member
Forum Posts: 180
Thanks Received: 18
132
2014/04/30 - 08:06
@annoluce
a good idea is to root the tablet
then do a nandbackup
then install rom
regards
DarthJabba
Forum Posts: 551
133
2014/04/30 - 08:49
And first be really sure that you really want to move to KitKat, because it is not a straightforward process to move back to JellyBean.
validatus
shmox
134
2014/04/30 - 13:07
DarthJabba said
You can try this:
https://play.google.com/store/apps/details?id=com.nomone.resolution_changer
Thanks, i will try it, what i like to do is to modify advanced android parameters, may be with an application, to set the resolution (lower resolution) and reboot tablet.
Is there android parameters to modify to do this ? which application i need to do it please ? thank you. please note i am on Kitkat
DarthJabba
Forum Posts: 551
135
2014/04/30 - 13:58
Well, there's a file called /system/build.prop where certain things can be changed. It probably won't help you with your resolution issues - and my advice is to leave the file well alone. You could brick your device by changing the wrong thing.
56 Guest(s)
Devices in use: Desktop (53), Phone (3)
alsoft75
Deaker
Gorael
WhiteD2125
Bokser
hamishduke
