[ ROM ] Cube U30GT2 Android 4.4.2 KitKat custom root firmware (2014/02/19)
DarthJabba
Forum Posts: 551
Thanks Received: 396
91
2014/04/05 - 15:24
MikeyB10001 said
No, the mic's fine on mine. I'm running DJ's overclocked ROM rather than the Kasty, if that makes any difference.
No, it would not make any difference. The kernel is the same - just overclocked.
YS Tang
92
2014/04/07 - 15:09
jwalkdad said
Hi - just bought a cube U30gt2 and have applied this firmware.  Thanks to all that has produced or contributed on this thread.
Only had the device for 3 days and the first thing I did was replace the stock rom with this.  Noticed now that the microphone is not working.
I think that this is a device issue rather than related to the firmware but would be interested to know if anyone else has noticed this.
Thanks in advance
jwalk
Mic is working OK on mine.
jwalkdad
93
2014/04/07 - 20:23
Thanks for the replies.  Have contacted them and arranging return.  Dodgy mic.
Cheers
Blochni
94
2014/04/08 - 09:52
I have installed this ROM and I can't manage Google contacts : no Google Contacts app icon found and no apk found on the web.
Could you help me ?
How can I turn off all the GSM services and app ?
Best regards
validatus
Advanced Member
Forum Posts: 180
Thanks Received: 18
95
2014/04/08 - 17:09
@Blochni
have a look at gapps
regards
bzzt
96
2014/04/08 - 23:41
This is the best ROM I've ever tried. It has made my Cube smooth, stable, and very pleasant to use. I cannot tell with certainty about battery level since I've just replaced it, however it seems that it lasts A LOT. Wifi very improved.
This ROM surely deserves a donation, as it has made the use value of the table 50% more. Thanks guys.
tsamikos
97
2014/04/09 - 16:40
Hi everyone,
First of all I would also like to thank everyone contributing in this thread, very helpful, especially for a new Cube owner and Android user like me.
This ROM is by far the best I have used so far (stock and custom 4.2.2) and solved many problems like, very bad and sudden loss of the Wifi signal, random reboots, flickering with hdmi connection.
The only problems I came up with so far with the 4.4.2 are:
- Cant play videos properly in Chrome
- Cant adjust resolution (HD) in display options. Is this just me?
I would like also to ask, since I have absolutely no idea how to overclock (using dj mod, clockworkmod etc), are the benefits that good in order to learn how to do it?
Thank you.
By the way, as the guy above me mentioned, they totally deserve a donation
MikeyB10001
98
2014/04/09 - 16:56
Check out ArcTools (already installed) - there's a fix in there which you can d/l and install to get the People app going
Blochni
99
2014/04/09 - 17:31
Thank you MikeyB10001 for your answer.
It's right now !
gseroul
100
2014/04/09 - 19:01
I also need to remove gsm app : it drains half of my battery when sleeping. What does gapps can do for this (see gapps just above but don't think there is anything to help in).
I remember in ArcTools in previous rom something to remove or unactivated gsm related apk, does anyone try this on this rom ?
JuLePe
101
2014/04/10 - 12:34
I have a problem with immersive navigation bar kit kat. Causes malfunction clash of clans and can not find the way that works. Somebody give me some idea, modifying the build.prop or something? The game freezes when the bar is hidden, but when you slide your finger to work it out until one is hiding. Pardon my English translator of google. Greetings.
osoyogi
102
2014/04/11 - 18:57
Disabling Hw overlays makes flickering disappear but games run slower and "bumpy" Sorry, I'm not good at english, I can't find the word for not smooth. (tested with the game badland)
Has anyone tried a game with high requirements?
dziubek
103
2014/04/12 - 12:25
Is planned to release a new version in April? Have you heard someone something ..?
salmerino70
104
2014/04/12 - 14:13
Very good rom, I 'm very pleased about it except for the SD card issue on booting. The tablet doesn't recognise and mount automatically the external SD. With android 4.2.2 the same sd card was always seen. Now I have always to pull it out and put it again in to let it be recognized. I tried various apps but wasn't able to fix the problem. Has anyone had the same issue? Thanks
lsdove
portugal
105
2014/04/12 - 14:51
Same problem about the external sd. Only automount if i reboot the tablet, im tired to search a solution.
Currently Online: run2droi
88 Guest(s)
Devices in use: Desktop (58), Phone (31)
roro17920
anbague
run2droi
iceman14
AnyFox
BAMHAB82
