[ ROM ] Cube U30GT2 Android 4.4.2 KitKat custom root firmware (2014/02/19)
maikal
Jacksonville, Florida
Forum Posts: 394
Thanks Received: 51
61
2014/03/25 - 14:09
twart said
Can anyone provide confirmation on the following:
  • Does this ROM support multi-window?
  • Any confirmation on whether the latest version of the Netflix app (from Play, v3.3.1429, dated 21 Mar 2014) works properly, as this version just stopped working on v2.06 (with Xposed)?
  • Is the Xposed framework required/available on this ROM?
Thanks in advance - getting ready to jump ship from 2.06 - I can back everything up with Titanium, but the most important aspects for me are:
  • Battery life (seems OK)
  • Wi-Fi connectivity (improved!)
  • Lag when updating (improved - amazing!)
  • Netflix
  • Flixter/Ultraviolet
  • Chromecast support (just got one and I LOVE it! Maybe a Roku next...)
As always, any answers are gratefully appreciated (and always get a Thanks from me!)
No on multi-window as far as I know, yes on xposed, I have it on, had it with both versions although I think my DarthJabba rom version also loaded it on. Working fine too. I do have a different kernnel from one that kasty brought us! Don't know about netflix, don't have it in use.
twart
ian
United Kingdom
Forum Posts: 30
62
2014/03/25 - 14:23
  • Netflix
Have you managed to get Flixster/Ultraviolet working?  If so, which ROM and how?  I keep getting the message that streaming isn't supported (even if the tablet is unrooted)
twart
Liverpool
Forum Posts: 24
Thanks Received: 17
63
2014/03/25 - 15:23
Getting Flixter/UV:
For 2.06 ROM:
  • Installed Xposed and Rootcloak module, added flixter to the cloaked apps.
  • Disabled SuperSU (from the app, go to Settings and uncheck Enable Superuser).
Of course, now I have put these steps down on paper, I realise I've enabled SuperSu since, so god knows why this is still working. Sigh... I'll update if I prove/disprove any theories, but for now try the above. I'm on the latest version of Flixter. Perhaps, once it becomes enabled (with SuperSu disabled) it simply remembers this - I dunno.
On Xposed:
Thanks - found the references on DJs CWM version, so I know it will work.
On multi-window:
Seems this was enabled in /system/build.prop as the key/value pair:
ro.rk.multi_window=true.
Now, I know this was enabled through the kernel, which I'm assuming is what similar to the kernel used in KitKat . If so, adding this pair could enable it? Any thoughts/pioneers willing to check or test?
Thanks all.
The following users say thank you to twart for this useful post:
ian
"If I wanted your opinion, I'd give it to you"
t.w@ - Battling whinge-bags since '71
Thegrif
64
2014/03/26 - 00:24
Just loaded this rom and am very pleased of it.
One problem is that not a single browser can play flash player. Is it normal, have i missed something ?
Thanks.
maikal
Forum Posts: 394
Thanks Received: 51
65
2014/03/26 - 01:06
Thegrif said
Thanks.
Didn't android stop supporting flash player?  I read about a mod for dolphin but it failed on me.
mack123
Forum Posts: 15
66
2014/03/26 - 05:20
try flashfox browser for flash video
The following users say thank you to mack123 for this useful post:
maikal, YS Tang
Thegrif
67
2014/03/26 - 08:29
Ok, thanks for the info.
Uznamer
Poland
Forum Posts: 42
Thanks Received: 12
68
2014/03/26 - 11:10
maikal said
Thegrif said
Thanks.
I am using Maxthon browser and no problem with flash player at all.
The following users say thank you to Uznamer for this useful post:
maikal, YS Tang
jnavaizq
69
2014/03/26 - 20:44
First, thanks for your hard work!
One question, someone have the uinput.ko file for the kernel of this rom?
I need it for Doridmote app.
ian
United Kingdom
Forum Posts: 30
70
2014/03/27 - 14:44
I have now installed this rom (I was previously on 2.06), then CWM, the DJ's rom and I am impressed.  The tablet feels slick and I no longer seem to have crashes or hangs (although still early days).  The only downside was the flicker which is fixed by disabling hw overlays.  And thanks to Twart, I now have my Flixster/Ultraviolet movies playing.
It will take something spectacular to make me move from this rom.
The following users say thank you to ian for this useful post:
twart
yoavst
Forum Posts: 51
71
2014/03/27 - 17:27
Am i the only one here that his HDMI is opposite and its battery life is awful?!?
jesmail
usa
Forum Posts: 26
Thanks Received: 5
72
2014/03/27 - 17:42
@ yoavst
Could be, my HDMI is fine and so is the battery life.
Not trying to be smart.....
yoavst
Forum Posts: 51
73
2014/03/27 - 17:58
@ yoavst
Demn :|
Anyone have any suggestion what to do?
aidieb
74
2014/03/27 - 18:06
Well I've been asking about a HDMI problem for a little while, mine gives a flicker/flashes off/on every 5 to 10 seconds on the screen connected to the HDMI but the tablet screen continues side by side without this flicker/flash. has done it since I got it!.on all the ROMs, at every overclocked/std kernels. Different cables & tvs still the same.
I'd love a solution to that!!
I got the same flickering as others with this ROM but the HW overlay disable worked for that.
I still get a red border flash up around changing webpages etc I think it did that on first 4.4 rom too.
Battery seems OK though.
maikal
Forum Posts: 394
Thanks Received: 51
75
2014/03/27 - 19:16
Neither problem so far after going down to the kasty kernel level with the DJ rom. But I missed the flickering red frame so much I went back up to the 768/720 kernel...kidding about missing it, but I like the rest of the kernel advantage and I dont mind the red frame so much. I use mine for reading and tinkering mostly.
Currently Online: kralizec
69 Guest(s)
Devices in use: Desktop (64), Phone (6)
chimo014
vishu bhatnagar
djwood1014
4ipolino
thomashansmuller11
abro
