2013/06/15
CORRECTIVE
Hi guys
May 20132 I bought a U30GT2 CUBE by Hongkongeek
interesting caracteristics
excellent use
February 2014 battery hs
then I received a nonfirmware battery (11000 ma, 7,4 v)
I open the cube
it is a badly recycled one
all the screws are maintained with compound cement
all screws screwed on soft plastic parts
all flat cables are not yet welded but scotched
battery connectors and screen flat cable are scotched with the same scotch
it is impossible to re screws the cube parts
two centring pins of the alu belt re welded
I open a 49 € tablet
no scoth
connectors everywhere
all screws on metalic parts
the cube caracteristics paper is excellent
the cube itself is an obscene material
All problems on the cube come from the very bad quality of the material
A GOOD ADVICE I DON'T BUY ANY CUBE MATERIAL, CUBE IS NOT A FIRM FOR ME
my job research, development, quality, validation engineer
bests
2013/07/09
Seriously Val, You posted this twice! was there something you forgot to mention in the previous post! You are just adding more panels to a friendly discussion of issues we are trying to fix/share within the group!
Admin feel free to erase this post and my previous post as I believe I have said my piece!
DarthJabba, hasanpb, bender83, cmbarreto
2014/03/17
This may be a stupid question, but does this update include the CWM recovery or do you have to install the CWM recovery separate?
And if so, should you install the CWM rocovery first or after you install this firmware.
I'm also a little confused as to why this is being called a firmware, is this a new custom ROM or just a firmware or is it both?
Thanks!
2013/12/16
No, unfortunately CWM recovery is not included.
This rom can't be flashed through CWM recovery, so it's not a prerequisite. If you want (and have a need for it), you can install it after you flashed the rom.
It's both Firmware or rom, it's the same thing. These terms are used interchangeably and mean the same thing.
2013/12/16
custm-1 said
So does that mean these are already rooted? No rooting required?
As the first post is saying...
- root with latest SuperSU version 1.93 (free version)
custm-1 said
I just ordered mine yesterday so I'm anxious to put the latest and greatest on it. I'm assuming thats the firmare/ROM in the first post of this forum?
Well, congrats! I bought mine not so long ago (in January), and I've been on stock for 2 hours before I flashed to first KitKat beta Just use the rom from the first post, it's very close in almost every aspect to the Jellybean flavors, but still you'll have the latest and greatest. You can also check out the other thread and DarthJabba version (changelog included in the first post).
2014/01/05
Nice Rom : installed 2hours ago.... till now 1prob discovered : flickering screen (when playing hill climb racing) and let this be the game my son is playing at the moment. ( i tested it is not the game tha gives prob) I went back to first Rom on this site and than the game works well..... I'll gently wait on an fix
2013/12/18
Mine too had the flickering videos and little pockets of flickering pixels around the lower edge of the screen when scrolling through the GUI and disabling DW overlays did the trick, Thanks dj, great,
On my cube i can´t run any of the 1800 Mhz overclocked kernels. but can run the faster ram etc.
Antutu score 20400
First impressions the gui seems to be fast enough on Apex launcher but seems a bit slower to open up chrome, facebook & keyboard. On Facebook it is much notchier than before when scrolling.
I have a different problem though, when my tablet is connected to my tv, the picture on the tv flashes off and on very quickly once every 10 seconds or so, any clues? It might have done this on previous ROMs too though but I've only just started to try & use it like this but it´s V annoying!
What´s happened to the Dual resolution option?
2013/08/26
Hi there!
Thanks for everybody by this useful site.
I need some help.
I really want change my battery, my tablet's charge life is over in 3 or 4 hours.
Have you ever changed your battery?
Could you show me a link to buy a good battery in the Aliexpress?
Is it easy change the battery? And will it really solve the problem?
2013/07/09
luterio said
Hi there!
I need some help.
There are several threads on that. If you scroll down the thread forum list there is one at least on the first list page.
60 Guest(s)
Devices in use: Desktop (49), Phone (11)
cutierogue
