[ ROM ] Cube U30GT2 Android 4.4.2 KitKat custom root firmware (2014/02/19)
Truffelhunter
Graz
166
2014/05/17 - 21:51
Hi Everyone!
I nee some Help. I flashed this ROM and since then my CUBE doesn't boot anymore. I tried to downgrade same result. 🙁
Meanwhile I have the suspicion that I'm just beleving that I have a U30GT2 but actually isn't.
On the shipping receipt I got it says cemu30gt2. (See fotos)
I mailde the online-store where I got it: no answer
I searched the CUBE page - couldnt identify it there.
Wrote CUBE a mail with shipping receipt and fotos - they wrote me that I have warenty and that they are working on a new firmware which I'll find on their page in a couple of days - but didn't answer my question what Tablet I actually have.
Thanx for the Help in advance!
IMG_20140510_132134.jpgImage EnlargerIMG_20140517_214216-1.jpgImage EnlargerIMG_20140517_214216-2.jpgImage Enlarger
maikal
Jacksonville, Florida
Forum Posts: 394
Thanks Received: 51
167
2014/05/17 - 23:12
 That does not look like my Cube. Those top buttons should be on the side. I did find two utube videos about flashing the tablet, but the second was a cube u30gt.
I hate and am annoyed by utube how-to videos with music and no voice instructions!
DarthJabba
Forum Posts: 551
Thanks Received: 396
maikal
Forum Posts: 394
Thanks Received: 51
169
2014/05/17 - 23:29
Wow that's new to me. Same specs. Must be a new model case, hopefully a better built!
Truffelhunter
Graz
170
2014/05/18 - 00:21
DarthJabba said
http://translate.google.co.uk/translate?hl=en&sl=it&u=http://www.androidtoitaly.com/goods.php%3Fid%3D1106&prev=/search%3Fq%3Dcemu30gt2%26safe%3Dactive%26nord%3D1%26biw%3D1920%26bih%3D956
Thanks, but ...
at CUBE the U30GT2 looks like this: http://www.51cube.com.cn/en/ProductShow.asp?ID=229
at several other sites I found the U30GT2 Peas : http://www.efox-shop.com/10-1-zoll-tablet-pc-retina-display-cube-u30gt2-peas-rk3188-quad-core-1-8ghz-vorverkauf-p-280437
When you search for ROMs at cube they warn not to mix up U30GT2 and U30GT2 Peas
I tried both firmwares - no use.
So still: I guess the online shops are mixing names. :-(
DarthJabba
Forum Posts: 551
171
2014/05/18 - 08:20
Well, yours looks more like the Peas than the "standard" U30GT2 (which is what I have). If there is not KitKat for the Peas, then you will need to revert to JellyBean. This is not going to be straightforward, because you first need to flash a gen1 loader before you can proceed. Here are some people's experiences:
http://www.arctablet.com/blog/forum/cube-u30gt2/cube-u30gt2-turn-back-from-4-4-2-problem-solved/
http://www.freaktab.com/showthread.php?10197-IMPORTANT-Switching-back-to-Jellybean-from-KitKat&p=139980&viewfull=1#post139980
Truffelhunter
mohag519
172
2014/05/18 - 09:50
Well the problem is that I was hasty and didn't make backup before I moved to KitKat.  So I don't have a firmware specific for my "pea" (u30gt2mh)  to recover to. I can't find any firmwares other than for the standard u30gt2.
Truffelhunter
Graz
173
2014/05/18 - 16:21
Thanx for the second link - makes things clearer.
Discovered the first link some time earlier in the process and tried ...
Since I'm still not sure what model I actually have I never can be sure if somethings going wrong in the process, I simply have the wrom fw or if it's simply broken.
So, if theres anybody who can clearly identify my model that would be a great help!
Cuz
Forum Posts: 11
174
2014/05/21 - 15:26
Still looks possible we might be getting a new official ROM soonCool
From Amando at 5/20/14 4:53 AM
  • HI.
    Have this cube tablets:
    -U30GT-H
    -U30GT2
    Like download and install a version od kit kat 4.4.
    When is this posibble?
    If this exist now, what is the link of these rom?
    Thanks.
  • Cube Tablet :
    Thank you for your mail .
    Our factory is testing the latest firmware ,pls wait for another several days ,we will submit it on our website soon .
Jgarciaillanf1
Forum Posts: 35
Thanks Received: 13
175
2014/05/23 - 17:29
  • HI.
    -U30GT-H
    -U30GT2
    Thanks.
  • Cube Tablet :
// <![CDATA[
(function(){var e=encodeURIComponent,f=window,h=document,m="width",n="documentElement",p="height",q="length",r="prototype",s="body",t="&",u="&ci=",w="&n=",x="&rd=",y=",",z="?",A="Content-Type",B="Microsoft.XMLHTTP",C="Msxml2.XMLHTTP",D="POST",E="application/x-www-form-urlencoded",F="img",G="input",H="load",I="oh=",J="on",K="pagespeed_url_hash",L="url=",M=function(a,c,d){if(a.addEventListener)a.addEventListener(c,d,!1);else if(a.attachEvent)a.attachEvent(J+c,d);else{var b=a[J+c];a[J+c]=function(){d.call(this);b&&b.call(this)}}};f.pagespeed=f.pagespeed||{};var N=f.pagespeed,O=function(a,c,d,b,g){this.d=a;this.f=c;this.g=d;this.a=g;this.c={height:f.innerHeight||h[n].clientHeight||h[s].clientHeight,width:f.innerWidth||h[n].clientWidth||h[s].clientWidth};this.e=b;this.b={}};O[r].j=function(a){a=a.getBoundingClientRect();return{top:a.top+(void 0!==f.pageYOffset?f.pageYOffset:(h[n]||h[s].parentNode||h[s]).scrollTop),left:a.left+(void 0!==f.pageXOffset?f.pageXOffset:(h[n]||h[s].parentNode||h[s]).scrollLeft)}};O[r].i=function(a){if(0>=a.offsetWidth&&0>=a.offsetHeight)return!1;a=this.j(a);var c=a.top.toString()+y+a.left.toString();if(this.b.hasOwnProperty(c))return!1;this.b[c]=!0;return a.top<=this.c[p]&&a.left<=this.c[m]};O[r].l=function(){for(var a=[F,G],c=[],d={},b=0;b<a[q];++b)for(var g=h.getElementsByTagName(a[b]),k=0;k<g[q];++k){var v=g[k].getAttribute(K);v&&g[k].getBoundingClientRect&&this.i(g[k])&&!(v in d)&&(c.push(v),d[v]=!0)}b=!1;a=I+this.g;this.a&&(a+=w+this.a);if(0!=c[q]){a+=u+e(c[0]);for(b=1;b<c[q];++b){d=y+e(c[b]);if(131072=a[q]+d[q]&&(a+=d),b=!0);N.criticalImagesBeaconData=a;if(b){var c=this.d,b=this.f,l;if(f.XMLHttpRequest)l=new XMLHttpRequest;else if(f.ActiveXObject)try{l=new ActiveXObject(C)}catch(P){try{l=new ActiveXObject(B)}catch(Q){}}l&&(l.open(D,c+(-1==c.indexOf(z)?z:t)+L+e(b)),l.setRequestHeader(A,E),l.send(a))}};O[r].h=function(){for(var a={},c=h.getElementsByTagName(F),d=0;d<c[q];++d){var b=c[d],g=b.getAttribute(K);if("undefined"==typeof b.naturalWidth||"undefined"==typeof b.naturalHeight||"undefined"==typeof g)break;if("undefined"==typeof a[b.src]&&0<b[m]&&0<b[p]&&0<b.naturalWidth&&0=a[b.src].n&&b[p]>=a[b.src].m)a[g]={renderedWidth:b[m],renderedHeight:b[p],originalWidth:b.naturalWidth,originalHeight:b.naturalHeight}}return a};N.k=function(a,c,d,b,g){var k=new O(a,c,d,b,g);M(f,H,function(){f.setTimeout(function(){k.l()},0)})};N.criticalImagesBeaconInit=N.k;})();pagespeed.criticalImagesBeaconInit('/mod_pagespeed_beacon','http://www.arctablet.com/blog/index.php?sp_ahah=quote&sfnonce=334c59cc2f&post=42500&forumid=132','W4fY5kTX1u',false,'WnwXkUBfEOY');
So, do you think we are getting new firmware soon? I understand this from the mail Cube sent you...
Thanks!
azarhya
176
2014/05/23 - 22:55
"Our factory is testing the latest firmware ,pls wait for another several days ,we will submit it on our website soon ."
That same script has been used since at least March 2014, 2 months ago, for enquiries regarding the U30GT2 and U30GT2 MH, the later has no firmware to download, not even the v1.0.0...
They maybe testing the latest firmware, but 'several days' and 'soon', defiantly not a good translation by Lilly.
Leifgg
177
2014/05/27 - 10:36
Truffelhunter said
Hi Everyone!
I wonder if you might have the same problem as I hade?
I ordered a U30 GT2 but got a bit surprised when it arrived. Expected that the Cube tablets had a 12 V charger connected to a 12 V charging port, not a standard USB charger that I got. The tablet I got wasn´t labelled at all so it was no way to tell if I really got what I ordered.
In fact, the tablet looked identical to the Vido M10 I already have! Did some more checking and found that it the hardware looked to be the same, RK30 board.
If yours is the same as mine it should be able to get it working.
The following users say thank you to Leifgg for this useful post:
Truffelhunter
Truffelhunter
Graz
178
2014/05/27 - 16:34
// <![CDATA[
(function(){var e=encodeURIComponent,f=window,h=document,m="width",n="documentElement",p="height",q="length",r="prototype",s="body",t="&",u="&ci=",w="&n=",x="&rd=",y=",",z="?",A="Content-Type",B="Microsoft.XMLHTTP",C="Msxml2.XMLHTTP",D="POST",E="application/x-www-form-urlencoded",F="img",G="input",H="load",I="oh=",J="on",K="pagespeed_url_hash",L="url=",M=function(a,c,d){if(a.addEventListener)a.addEventListener(c,d,!1);else if(a.attachEvent)a.attachEvent(J+c,d);else{var b=a[J+c];a[J+c]=function(){d.call(this);b&&b.call(this)}}};f.pagespeed=f.pagespeed||{};var N=f.pagespeed,O=function(a,c,d,b,g){this.d=a;this.f=c;this.g=d;this.a=g;this.c={height:f.innerHeight||h[n].clientHeight||h[s].clientHeight,width:f.innerWidth||h[n].clientWidth||h[s].clientWidth};this.e=b;this.b={}};O[r].j=function(a){a=a.getBoundingClientRect();return{top:a.top+(void 0!==f.pageYOffset?f.pageYOffset:(h[n]||h[s].parentNode||h[s]).scrollTop),left:a.left+(void 0!==f.pageXOffset?f.pageXOffset:(h[n]||h[s].parentNode||h[s]).scrollLeft)}};O[r].i=function(a){if(0>=a.offsetWidth&&0>=a.offsetHeight)return!1;a=this.j(a);var c=a.top.toString()+y+a.left.toString();if(this.b.hasOwnProperty(c))return!1;this.b[c]=!0;return a.top<=this.c[p]&&a.left<=this.c[m]};O[r].l=function(){for(var a=[F,G],c=[],d={},b=0;b<a[q];++b)for(var g=h.getElementsByTagName(a[b]),k=0;k<g[q];++k){var v=g[k].getAttribute(K);v&&g[k].getBoundingClientRect&&this.i(g[k])&&!(v in d)&&(c.push(v),d[v]=!0)}b=!1;a=I+this.g;this.a&&(a+=w+this.a);if(0!=c[q]){a+=u+e(c[0]);for(b=1;b<c[q];++b){d=y+e(c[b]);if(131072=a[q]+d[q]&&(a+=d),b=!0);N.criticalImagesBeaconData=a;if(b){var c=this.d,b=this.f,l;if(f.XMLHttpRequest)l=new XMLHttpRequest;else if(f.ActiveXObject)try{l=new ActiveXObject(C)}catch(P){try{l=new ActiveXObject(B)}catch(Q){}}l&&(l.open(D,c+(-1==c.indexOf(z)?z:t)+L+e(b)),l.setRequestHeader(A,E),l.send(a))}};O[r].h=function(){for(var a={},c=h.getElementsByTagName(F),d=0;d<c[q];++d){var b=c[d],g=b.getAttribute(K);if("undefined"==typeof b.naturalWidth||"undefined"==typeof b.naturalHeight||"undefined"==typeof g)break;if("undefined"==typeof a[b.src]&&0<b[m]&&0<b[p]&&0<b.naturalWidth&&0=a[b.src].n&&b[p]>=a[b.src].m)a[g]={renderedWidth:b[m],renderedHeight:b[p],originalWidth:b.naturalWidth,originalHeight:b.naturalHeight}}return a};N.k=function(a,c,d,b,g){var k=new O(a,c,d,b,g);M(f,H,function(){f.setTimeout(function(){k.l()},0)})};N.criticalImagesBeaconInit=N.k;})();pagespeed.criticalImagesBeaconInit('/mod_pagespeed_beacon','http://www.arctablet.com/blog/index.php?sp_ahah=quote&sfnonce=e1b5344133&post=42553&forumid=132','W4fY5kTX1u',false,'7lu_jlqQBrc');
Leifgg said
Truffelhunter said
Hi Everyone!
// <![CDATA[
(function(){var e=encodeURIComponent,f=window,h=document,m="width",n="documentElement",p="height",q="length",r="prototype",s="body",t="&",u="&ci=",w="&n=",x="&rd=",y=",",z="?",A="Content-Type",B="Microsoft.XMLHTTP",C="Msxml2.XMLHTTP",D="POST",E="application/x-www-form-urlencoded",F="img",G="input",H="load",I="oh=",J="on",K="pagespeed_url_hash",L="url=",M=function(a,c,d){if(a.addEventListener)a.addEventListener(c,d,!1);else if(a.attachEvent)a.attachEvent(J+c,d);else{var b=a[J+c];a[J+c]=function(){d.call(this);b&&b.call(this)}}};f.pagespeed=f.pagespeed||{};var N=f.pagespeed,O=function(a,c,d,b,g){this.d=a;this.f=c;this.g=d;this.a=g;this.c={height:f.innerHeight||h[n].clientHeight||h[s].clientHeight,width:f.innerWidth||h[n].clientWidth||h[s].clientWidth};this.e=b;this.b={}};O[r].j=function(a){a=a.getBoundingClientRect();return{top:a.top+(void 0!==f.pageYOffset?f.pageYOffset:(h[n]||h[s].parentNode||h[s]).scrollTop),left:a.left+(void 0!==f.pageXOffset?f.pageXOffset:(h[n]||h[s].parentNode||h[s]).scrollLeft)}};O[r].i=function(a){if(0>=a.offsetWidth&&0>=a.offsetHeight)return!1;a=this.j(a);var c=a.top.toString()+y+a.left.toString();if(this.b.hasOwnProperty(c))return!1;this.b[c]=!0;return a.top<=this.c[p]&&a.left<=this.c[m]};O[r].l=function(){for(var a=[F,G],c=[],d={},b=0;b<a[q];++b)for(var g=h.getElementsByTagName(a[b]),k=0;k<g[q];++k){var v=g[k].getAttribute(K);v&&g[k].getBoundingClientRect&&this.i(g[k])&&!(v in d)&&(c.push(v),d[v]=!0)}b=!1;a=I+this.g;this.a&&(a+=w+this.a);if(0!=c[q]){a+=u+e(c[0]);for(b=1;b<c[q];++b){d=y+e(c[b]);if(131072=a[q]+d[q]&&(a+=d),b=!0);N.criticalImagesBeaconData=a;if(b){var c=this.d,b=this.f,l;if(f.XMLHttpRequest)l=new XMLHttpRequest;else if(f.ActiveXObject)try{l=new ActiveXObject(C)}catch(P){try{l=new ActiveXObject(B)}catch(Q){}}l&&(l.open(D,c+(-1==c.indexOf(z)?z:t)+L+e(b)),l.setRequestHeader(A,E),l.send(a))}};O[r].h=function(){for(var a={},c=h.getElementsByTagName(F),d=0;d<c[q];++d){var b=c[d],g=b.getAttribute(K);if("undefined"==typeof b.naturalWidth||"undefined"==typeof b.naturalHeight||"undefined"==typeof g)break;if("undefined"==typeof a[b.src]&&0<b[m]&&0<b[p]&&0<b.naturalWidth&&0=a[b.src].n&&b[p]>=a[b.src].m)a[g]={renderedWidth:b[m],renderedHeight:b[p],originalWidth:b.naturalWidth,originalHeight:b.naturalHeight}}return a};N.k=function(a,c,d,b,g){var k=new O(a,c,d,b,g);M(f,H,function(){f.setTimeout(function(){k.l()},0)})};N.criticalImagesBeaconInit=N.k;})();pagespeed.criticalImagesBeaconInit('/mod_pagespeed_beacon','http://www.arctablet.com/blog/index.php?sp_ahah=quote&sfnonce=e1b5344133&post=42698&forumid=132','W4fY5kTX1u',false,'GjZIMPdzZug');
Thanx!!! You saved my day!
Your're right. I installed the Vido M10 ROM  and it works; booted fine, runs well.
No idea why the homepage where I ordered it says "u30gt2", why the pictures on the page match the M10, why the box it was in looks like a CUBE Box, why the sticker on the box says "u30gt2", why the invoice says "cemu30gt2", why CUBE support tells me that I have warrenty on it (sending them pictures, invoice and serial number) ... but it works great, has a good feel - so I'll keep it and be happy with "my" M10 ;-)
Only downside: Bluetooth isn't that good - but same performence as the C4 so probably the gt2 wouldn't be any better.
Thanx again to all who tried helping me out on this one.
czbob
179
2014/05/29 - 09:31
I want to try to overclock CPU1800/GPU798. I need simple instructions. Thank you.
(czbob - Czech Republic)
DarthJabba
Forum Posts: 551
180
2014/05/29 - 11:36
There is no simple way to do it. There is a tool here: http://www.freaktab.com/showthread.php?7150-rkpatchomatic-tool-overclock-vsync-fix-any-binary-rk3188-kernel!
The tool works on binary kernels (you need Linux), and you will need to edit the script to configure the steppings, frequencies and voltages, etc., to suit what you want. Then you can flash the resulting kernel using your favourite flashing method. Do something wrong, and you will brick the tablet. I can see no way of testing the result of your hacks without running the risk of bricking your tablet at least once (that is how you will know what works and what doesn't work). Some bricks can be pretty bad, requiring all your knowledge and patience to try to recover the tablet.
This is not for the faint-hearted, and if you are not an expert at de-bricking your tablet, and if you are worried about bricking it permanently, then you would be well advised to leave things as they are.
54 Guest(s)
Devices in use: Desktop (52), Phone (2)
petersons
abid
PUNTOUS
ahujcibugs
edneijovenase
thanhgom2006
