[ ROM ] Cube U30GT2 Android 4.4.2 KitKat custom root firmware (2014/02/19)
ian
United Kingdom
Forum Posts: 30
151
2014/05/08 - 09:23
DJ - When you say the cube is still (just about) alive are you referring to your own machine or generally?  I have noticed we haven't had a firmware update for some time - does anyone know if they are still working on a final kitkat version?  My Cube is moribund, I am awaiting a new battery to hopefully give some new life.  I have since bought a Hudl which is working really well (also RK3188) and battery life is really good.
DarthJabba said
maikal said
Just wondered since all these folks have been having problems going back from kitkat to previous roms why not just do a regular old factory reset and then flash the rom they wanted to go back to. It would be the same amount of work pretty much, apps would have to be reloaded anyway.
But hey glad to see we did not loose your sage advice and knowledge to the cube mishap!
Just doing a factory reset will not solve the KitKat-to-JellyBean downgrade problem. That problem arises because of the new 2.x loader (and extra partition stuff) used by KitKat. A factory reset will not touch the loader or change the partition information.
The Cube is still (just about) alive. I'll eventually have to dump it.
In the meantime, I got myself a Ceros Revolution at a very cheap price - also RK3188, but with 2048x1536 resolution, and a number of reported issues (so I bought with my eyes wide open). I've managed to overcome all the issues that are being reported about it (very easy, really). The kernel can't be overclocked stably beyond cpu1700/gpu768/ddr600 (with 18.5k Antutu score), but it is actually quite smooth, and the display is miles ahead of the Cube. We shall see how long my optimism lasts!
// <![CDATA[
(function(){var e=encodeURIComponent,f=window,h=document,m="width",n="documentElement",p="height",q="length",r="prototype",s="body",t="&",u="&ci=",w="&n=",x="&rd=",y=",",z="?",A="Content-Type",B="Microsoft.XMLHTTP",C="Msxml2.XMLHTTP",D="POST",E="application/x-www-form-urlencoded",F="img",G="input",H="load",I="oh=",J="on",K="pagespeed_url_hash",L="url=",M=function(a,c,d){if(a.addEventListener)a.addEventListener(c,d,!1);else if(a.attachEvent)a.attachEvent(J+c,d);else{var b=a[J+c];a[J+c]=function(){d.call(this);b&&b.call(this)}}};f.pagespeed=f.pagespeed||{};var N=f.pagespeed,O=function(a,c,d,b,g){this.d=a;this.f=c;this.g=d;this.a=g;this.c={height:f.innerHeight||h[n].clientHeight||h[s].clientHeight,width:f.innerWidth||h[n].clientWidth||h[s].clientWidth};this.e=b;this.b={}};O[r].j=function(a){a=a.getBoundingClientRect();return{top:a.top+(void 0!==f.pageYOffset?f.pageYOffset:(h[n]||h[s].parentNode||h[s]).scrollTop),left:a.left+(void 0!==f.pageXOffset?f.pageXOffset:(h[n]||h[s].parentNode||h[s]).scrollLeft)}};O[r].i=function(a){if(0>=a.offsetWidth&&0>=a.offsetHeight)return!1;a=this.j(a);var c=a.top.toString()+y+a.left.toString();if(this.b.hasOwnProperty(c))return!1;this.b[c]=!0;return a.top<=this.c[p]&&a.left<=this.c[m]};O[r].l=function(){for(var a=[F,G],c=[],d={},b=0;b<a[q];++b)for(var g=h.getElementsByTagName(a[b]),k=0;k<g[q];++k){var v=g[k].getAttribute(K);v&&g[k].getBoundingClientRect&&this.i(g[k])&&!(v in d)&&(c.push(v),d[v]=!0)}b=!1;a=I+this.g;this.a&&(a+=w+this.a);if(0!=c[q]){a+=u+e(c[0]);for(b=1;b<c[q];++b){d=y+e(c[b]);if(131072=a[q]+d[q]&&(a+=d),b=!0);N.criticalImagesBeaconData=a;if(b){var c=this.d,b=this.f,l;if(f.XMLHttpRequest)l=new XMLHttpRequest;else if(f.ActiveXObject)try{l=new ActiveXObject(C)}catch(P){try{l=new ActiveXObject(B)}catch(Q){}}l&&(l.open(D,c+(-1==c.indexOf(z)?z:t)+L+e(b)),l.setRequestHeader(A,E),l.send(a))}};O[r].h=function(){for(var a={},c=h.getElementsByTagName(F),d=0;d<c[q];++d){var b=c[d],g=b.getAttribute(K);if("undefined"==typeof b.naturalWidth||"undefined"==typeof b.naturalHeight||"undefined"==typeof g)break;if("undefined"==typeof a[b.src]&&0<b[m]&&0<b[p]&&0<b.naturalWidth&&0=a[b.src].n&&b[p]>=a[b.src].m)a[g]={renderedWidth:b[m],renderedHeight:b[p],originalWidth:b.naturalWidth,originalHeight:b.naturalHeight}}return a};N.k=function(a,c,d,b,g){var k=new O(a,c,d,b,g);M(f,H,function(){f.setTimeout(function(){k.l()},0)})};N.criticalImagesBeaconInit=N.k;})();pagespeed.criticalImagesBeaconInit('/mod_pagespeed_beacon','http://www.arctablet.com/blog/index.php?sp_ahah=quote&sfnonce=8b5bcd381c&post=42241&forumid=132','W4fY5kTX1u',false,'JCgy1cE7VLU');
DarthJabba
Forum Posts: 551
Thanks Received: 396
152
2014/05/08 - 12:06
I was referring to my own Cube only.
I don't think any new official ROM will come out - but I think that the current Kasty KitKat 4.4.2 ROM (or the DJ mods of it) makes the Cube useful now.
PS: given that I haven't been able to overclock my Ceros up to levels that the Cube could easily cope with, Cube is going up in my estimation (although I think the Ceros is much better built).
maikal
Cuz
Forum Posts: 11
153
2014/05/08 - 20:25
Are these the official Cube guys? Looks like we will be getting a new KitKat ROM if they are?
http://www.cube-tablet.com/cube-u39gt-quad-core-tablet-pc-rk3188-9-0-inch-1920-1280-android-4-2-bluetooth-2gb-questions.html
<EDIT> Moment of madness I'm looking at the wrong tablet;-0
Joey
154
2014/05/09 - 06:04
Anyone can tell me if this ROM is compatible with u30gt 2mh.
Thanks.
Wintermute
Forum Posts: 89
Thanks Received: 30
155
2014/05/09 - 19:40
I am just stopping by to share some first hand experience on freshly released XBMC 13 (Android apk version) on U30GT2 and this ROM with OC kernel.
XBMC works really nice, actually much better than anticipated. Crucial hardware video acceleration works (first time with Android XBMC!), UI is well responsive. All in all best video navigation and playback experience on this device for me, including streaming MKV 720/1080p files via SMB share or from Live Add-Ons. Wonderful.
Tomas
Blochni
156
2014/05/13 - 10:19
Hi
I have battery issue and I want to uninstall "GSM Standby".
Someone knows how to do ?
yewsuck
Forum Posts: 12
157
2014/05/13 - 13:21
Try putting the phone in "Airplane mode" and see if that helps.
Blochni
158
2014/05/13 - 20:19
Unfortantely, no change with the "Airplane Mode"
Another idea to uninstall or to kill "GSM Standby" app ?
luterio
159
2014/05/14 - 04:56
Hi everybody!
Im having problems with this rom. Back camera doesnt work.
Im thinking about downgrade to 4.2 version. Is it possible?
How do I do it? Can someone help me please?
DarthJabba
Forum Posts: 551
160
2014/05/14 - 08:55
luterio
annoluce
Forum Posts: 19
161
2014/05/14 - 10:09
a little more encouragement would have been appreciated: I installed the ROM and indeed it runs very smooth, stable, and the battery life is fine. I think I will definitely settle down with this one.
Max
mohag519
162
2014/05/15 - 11:36
Typically me, I rushed into this and now I have some problems with my tablet.
I think the main problem is that I have the u30gt2mh model and I didn't really think about it much when I installed this ROM. Stupid as I am I didn't even make a backup of the ROM that I had and now I can't find it anywhere.
Now the screen is less bright and also sometimes the graphic glitches, the colors get distorted, it's like it goes down to 256-colors instead of 32-bits.
I can't find the original firmware anywhere. Any ideas? I really didn't think that the screen brightness could be affected by a custom ROM. This means some other set of drivers are installed I guess? I looked into /sys/class/backlight/actual_brigthness and it says 89, even though max_brightness is 255 and brightness is also set to 255. But I don't know much of this.
Any help would be appreciated.
lambo2000
163
2014/05/15 - 14:33
What is the difference between the MH and the "normal" Tablet, I've checked the specification. and can't find any difference. Now that you have LCD issue, could they have changed it?
mohag519
164
2014/05/15 - 19:38
Quite possible that the LCD was different, since I've read about brightness being too low on the U30GT2 and when I received the tablet I noticed I wasn't bothered about the brightness at all.
I couldnt even find the specifications for MH, I had no idea that was what I ordered when I purchased the tablet. This is also why I thought I could flash this rom since the MH didn't seem to be any big difference.
I'm calling out to anyone who might have the u30gt2mh to make a nandroid for me and send it. Would be so much appreciated.
Grenade
165
2014/05/17 - 21:31
Hello everybody
Excuse me for my poor english. I am new android tablet user. I own  cube U30GT2 and have installed 4.4.2 KitKat custom root firmware (20140219). When i try to set user or owner, nothig works but i can read the message "Unfortunately, Satting has stopped".
Please, could someone help me ?
Thanks you
82 Guest(s)
Devices in use: Desktop (58), Phone (24)
Kaka88
Donalbert
halum
BlackCero044
BlackCero04
taylordahmer
