Build information:
Kernel: Linux version 3.0.36+ (tangy@tchipserver2) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #352 SMP PREEMPT Tue Feb 18 17:11:25 CST 2014
Android 4.4.2: rockchip/u30gt2/rk3188:4.4.2/KOT49H/eng.tangy.20140218.164222:eng/opinions-on-teclast-p90hdst-keys
- root with latest SuperSU version 1.93 (free version)
- increased space for applications (/data partition) to 7 GB
- added Google Experience Launcher (GEL) in addition to Cube's stock launcher
- optional ClockworkMod (CWM) Recovery easy install package (apparently reported to be not compatible with this firmware)
- multi-user support thanks to didierm contribution
Notes:
- current KitKat based firmwares should be considered as beta software
Download: kasty-cube_u30gt2-442-20140219-rooted7_mu.zip
Burs, dziubek, maikal, DarthJabba, YS Tang, Wintermute, Riederan, kampfturtle, Iemand, sipdude, Uznamer, arthurcube, solyfugo, aLDime, zaqx, drhaze, BigMihca If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
We had a lot of user requests for increased apps storage space, having 7 GB for apps out of 16 or 32 GB total storage space makes sense.
maikal If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
2013/04/23
DarthJabba mod in CWM format available here: http://www.arctablet.com/blog/forum/cube-u30gt2/cube-u30gt2-android-4-4-2-kitkat-20140219-firmware-darthjabba-mod-in-cwm-upgrade-format/#p40168
rAWbDarth Jabba, the Dark Jedi from Nal Hutta
2013/04/23
Sethi said
i had 18k with previous antutu score, now its 17.475 :X
I got 21870 with the CWM overclocked package ...
You also need to note that, with Antutu, much can depend on what you've done with the tablet before running Antutu. The results can be hugely different when certain things are already cached (particularly on the disk I/O side of things). If you want to compare like with like, you always need to run it only immediately after rebooting.
2013/07/07
heh
And can´t find the overclocked options on arctook like it had on previous one either :X
couldn´t install the cwm one beucase sdcard was not mounting, no idea why.
Hi Sethi,
I used manual from http://wiki.cyanogenmod.org/w/Template:Recovery_install_flash_image
2013/04/12
@Admin
The Clockwork mod from the ManuPC does not show up in the arctools. I had a similar problem in 4.4 beta 1, but it eventually showed up. Is there something I am doing wrong or should it be there?
Want to put in the over clock mods.
So far this version seems to be better on battery then beta 1. They still have not installed the drivers for the hall effect device so apps like Compass still do not work. But we can finally use a Hub on the usb port and plug in multi devices. So good progress is being made.
Thanks again
2013/12/16
Sethi said
Location (GPS with with on google maps, for example) is not activating.. anyone with similiar problem?
Although our Cubes don't have GPS, you have to enable it from action bar anyway in order to use location feature in other apps. Just swipe down top of the screen where the clock is, enable GPS, end then configure the location options in Settings (it won't be grayed out anymore). That should be it.
2013/04/26
Thats what im saying, mine is not "clickable" to active... i can´t turn it on.. :/
2013/04/23
It seems so. Even with my overclocked kernel, standby battery drain is currently 2% in 15 hours (note that the ringer is set to "silent") - but these are early days yet. We shall see how it all goes.
2013/12/16
Where did you say that?
Most people go directly to settings trying to enable it there (and indeed, there it behaves as "unclickable") until the GPS tile on action bar is tapped on. Then the location in settings becomes clickable. If that don't work for you, then I don't really know. Others have succesfully enabled it on both JB and KitKat.
97 Guest(s)
Devices in use: Desktop (94), Phone (3)
JEssicannn: 279
AnnaStockm
IAmTheOne86
tkowalski
Devlin
gitidi3813
goliad
Topics: 6129
Members: 266802
