sloed
Forum Posts: 14
106
2014/01/25 - 21:56
Where did you find  RKAndroidTool (v2.1.0.0)
I read these posts every day. Thank you for keeping us informed.
Ohamn
Forum Posts: 16
107
2014/01/25 - 22:17
Where did you find  RKAndroidTool (v2.1.0.0)    I read these posts every day. Thank you for keeping us informed.
Just like Jabba said in post 105 on the previous page:
A download link for the CWM Recovery is given by ManuPC here:
http://www.arctablet.com/blog/forum/fnf-ifive-tablets/rom-fnf-ifive-x2-android-4-4-2-kitkat-custom-rooted-firmware-based-on-v2-0-0-20140108/page-3/
Direct link to CWM:
Download CWMrecovery:
https://app.box.com/s/pk098mmskzoxx4il3vy8
Direct link to OCkernel:
Download OCkernel (cpu1800mhz gpu798mhz):
https://app.box.com/s/5d7r1l3yqi8lowhv6n1k
// Ohamn
DarthJabba
Forum Posts: 551
Thanks Received: 396
108
2014/01/25 - 22:21
You wouldn't want to use that OC kernel - it is not for the Cube.
DarthJabba
Forum Posts: 551
109
2014/01/25 - 22:27
In a download discussed here: http://www.freaktab.com/showthread.php?9395-Neomode-Custom-Rom-U30GT2-Android-4-4-Version-0-9/page3
Burs
Advanced Member
Forum Posts: 144
Thanks Received: 33
110
2014/01/25 - 22:44
DarthJabba said
1. I installed it with RKAndroidTool (deselected everything except the Kasty "parameter" file from the 4.4.2 ROM and the ManuPC "CWM recovery ifiveX2 442" recovery image).
Thanks for the great news! Which RKAndroidTool version did you used, v1.37 or v2.1 (if that matters at all)? I downloaded the recovery image, but would like to ask you if you could be more specific on what you wrote in the brackets? How exactly should I go about it? I wouldn't like to skip some important step and brick my new-born tablet http://www.arctablet.com/blog/wp-includes/images/smilies/icon_smile.gif Thanks a million!
EDIT: how can I get that "parameter" file? Can I unpack it from your custom rom and then flash it together with CWM in RKAndroidTool v2.1?
maikal
Jacksonville, Florida
Forum Posts: 394
Thanks Received: 51
111
2014/01/25 - 23:03
Adding the cwm, will it erase the apps already loaded?
Nightviper
112
2014/01/25 - 23:07
HI I have the Cube U30GT2 and I'm trying to install the Android 4.4.2 on it but for some strange reason when i launch the Rockchip Batch Tool v1.7 and upload the FW Path, the connected devices is color is Purple not Green and it wont Restore to update it. I tried looking at some torturous but unfortunately they got me nowhere, is there a way to you can help me out please.
I have windows 8 btw and i did install the RockusbDriver 64bit and 32Bit.
Nightviper
Burs
Advanced Member
Forum Posts: 144
Thanks Received: 33
113
2014/01/25 - 23:24
No, it will just overwrite the stock recovery. Even if you update your rom through CWM, that won't erase your apps. Unless you're doing CWM Factory reset, you're on the safe side.
You have to disable Developer options in Settings, and while connected to PC, reboot to bootloader. Then it will turn green.
Nightviper
114
2014/01/25 - 23:36
You mean rebooting to boot loader with the Power button and Vol up ?
DarthJabba
Forum Posts: 551
115
2014/01/25 - 23:43
I used RKAndroidTool 1.37 (the version by Finless - although I don't think it matters which version you use). The parameter file is attached (in a zip file - you obviously have to extract it).
A screenshot of what to do is attached - before clicking on "Flash ROM" (or however that button is translated on your tool). BTW: I'm sure you know that you first have to reboot to the bootloader and wait for the tool to detect your tablet before any of this will work!CWM_442.jpgImage Enlarger
Burs, timle
brmxn
116
2014/01/26 - 00:28
Yes exactly, the "switch" button in RKBatchTool 1.7 works fine for me too. (Switches Tablet in Bootloader via Software).
If it still fails to recognize/flash your tablet correctly install the "RockUSBDriver" via device manager for the listed device
drivers attached; thanks to programmer!
diwill
117
2014/01/26 - 04:16
Maybe using parameter file can back to 422?:)
maikal
Forum Posts: 394
Thanks Received: 51
118
2014/01/26 - 06:13
I just noticed that in "Google now" Location refuses to turn on! The message I get "google now is turned off for your domain" " If you are seing this message, you are using google apps for bussiness, and your system administrator has turned off google now for your organization... WTF is that? I downloaded everything through the rom or google play.  I tried changing it in settings but its a no go. any ideas?
By the way I downloaded the oc rom, parameters and cwm per instructions and everything is working.
Burs
Advanced Member
Forum Posts: 144
Thanks Received: 33
119
2014/01/26 - 09:56
It was discussed on this page before, but I didn't quite get it...?
cxdani
120
2014/01/26 - 10:05
Is there a problem with flashing back 4.2.2 after I use this 4.4.2? Did anyone managed to go back to a previous version?
68 Guest(s)
Devices in use: Desktop (64), Phone (3), Tablet (1)
wheaten156
luislx
algua
Twotrains
alexanddercrb
tsmfallen
