validatus
Advanced Member
Forum Posts: 180
Thanks Received: 18
376
2014/03/17 - 07:51
Battery
I think there is an intrinsec problem with firmware series 7200 mAH
I use 11000mAh with satisfaction
Caution : you will brick the cube by opening it
regards
maikal
Jacksonville, Florida
Forum Posts: 394
Thanks Received: 51
377
2014/03/17 - 14:14
Battery   I think there is an intrinsec problem with firmware series 7200 mAH I use 11000mAh with satisfaction Caution : you will brick the cube by opening it regards
What? Sorry Val you lost me there, "firmware series 7200mAH"?
validatus
Advanced Member
Forum Posts: 180
Thanks Received: 18
378
2014/03/17 - 14:19
Hi guys
May 20132 I bought a U30GT2 CUBE by Hongkongeek
interesting caracteristics
excellent use
February 2014 battery hs
then I received a nonfirmware battery (11000 ma, 7,4 v)
I open the cube
it is a badly recycled one
all the screws are maintained with compound cement
all screws screwed on soft plastic parts
all flat cables are not yet welded but scotched
battery connectors and screen flat cable are scotched with the same scotch
it is impossible to re screws the cube parts
two centring pins of the alu belt re welded
I open a 49 € tablet
no scoth
connectors everywhere
all screws on metalic parts
the cube caracteristics paper is excellent
the cube itself is an obscene material
All problems on the cube come from the very bad quality of the material
A GOOD ADVICE I DON'T BUY ANY CUBE MATERIAL, CUBE IS NOT A FIRM FOR ME
my job research, development, quality, validation engineer
bests
jy_p
Forum Posts: 44
Thanks Received: 20
379
2014/03/17 - 15:08
What do you mean by :"you will brick the cube by opening it"
Many users upgraded their battery, I never heard anyone saying that they bricked their tablet by opening it... It that true?
maikal
Forum Posts: 394
Thanks Received: 51
380
2014/03/17 - 15:14
Val are you going to rant on all the threads now?
validatus
Advanced Member
Forum Posts: 180
Thanks Received: 18
381
2014/03/17 - 16:04
@maikal
What I mean is that the cube I bought was a very bad second hand
But what you do DJ, Maikal, admin is very good and many thanks
for me it's finished
Bests
falcofa1
382
2014/04/09 - 21:35
I tried several times to upload the firmware using rock chip batch tool 1.7 but the machine won't startup after installation. it stops with cube logo on screen... any suggestions?
falcofa1
383
2014/04/09 - 21:38
I tried several times to upload the firmware 4.4 using rockchip batch tool 1.7 but the machine won't startup after installation. it stops with cube logo on screen… any suggestions?
Maxim
384
2014/05/23 - 15:20
Can somebody help me with the noise-problem with skype and google hangout? See this topic: http://www.arctablet.com/blog/forum/cube-u30gt2/skype-hangout-scratching-noise-issue/
maikal
Forum Posts: 394
Thanks Received: 51
385
2014/05/26 - 02:45
Maxim, I offered a reply, go there and take a look.
rvitch
386
2014/06/16 - 23:27
Hi all,
I wanna congratulate al développers of this ROM.
I have buy cube2 because of specs on paper like a lots of US..before flash KitKat on tab ,that's realy laggy with all tested ROM.
The power management was very bad also with the overcloked kernel, now that's work well, no lag .
All work, cwm, cams, miracast miroring ...realy good!
A chance for me, tab i have buy have  réal antenna , i don know why but no métal pieces and at beginning wifi perfs was horrible, that switch thé day were i remove the metalic border ..conclusion good  or bad wifi antenna have same performance with métal border.
ar_sot
387
2014/08/06 - 12:35
For all devices which uses Rockchip31XX, you may use "Rockchip_Batch_Tool_v1.7". If your computer O.S. is windows 7, you may face to "This operation didn't do, because of not supporting!". If the computer O.S. is XP you will see the above warning after connecting your device to computer in the pink number one. Do not worry, press "switch" tab the device will be shutted down immediately, and the "connected devices" icon will be green promptly. Now you can "upgrade" or "Restore" your device.
In conclusion you may perform your device flash using windows XP on your computer, without any problem.
ar_sot
388
2014/08/06 - 12:38
Juanjo said
founded a batch tool that see my cube.
http://www.htcmania.com/showthread.php?t=583011
but when upgrade says:
"this operation didn´t do because of not supporting"
seblang
389
2014/08/19 - 08:13
Hi all
I have installed this rom "kasty-cube_u30gt2-442-20140121-rooted4_mu.zip" on my U30GT2 cube and it works fine.
but this rom is normally rooted ..............why i can not used Superu.
When I try to used it I have SUPERU binary have to be updated but the update is not possible (doesn't work)!
I have try to install ""(OMA / CrewRKTablets) CWM Recovery 6.0.3.1 for Android 4.4.2 KitKat on RK tablets (loader Gen2)"." throo Arctools but I have an error 20............unable to write file!
I just want to keep this rom but have a complet root!
How can do this ?
Please help
evesham
390
2015/01/09 - 12:01
wrong thread sorry
83 Guest(s)
Devices in use: Desktop (74), Phone (8), Tablet (1)
matinf
floki
orocamora
Ellocojoe
Tonysc17
olegator
