vandall666
151
2014/01/27 - 20:53
@Burs
Yes i have tried flash both ways in 4.2.2 and it was working fine.
By both ways i mean using camera app and standatrd flash light apps (tried 5 dfferent apps)
@ Sacirlux
Im glad that flash works for you, how many times u tried to flash kitkat ?
Im thinking about compiling list of issues ... so maybe pm me with stuff you have problems with and i will create new thread with up to date info for devs to look at ?
The following users say thank you to vandall666 for this useful post:
Burs
Burs
Advanced Member
Forum Posts: 144
Thanks Received: 33
152
2014/01/27 - 20:55
validatus said
it seems that installing earth permts to anable location it must be a client for location installed
Unfortunately not a case on my end. Still disabled and greyed out. Which version do you have? Mine is 7.1.3.
maikal
Jacksonville, Florida
Forum Posts: 394
Thanks Received: 51
153
2014/01/27 - 21:08
MY camera and flashlight work fine. Also been getting some fc when I have switched between launchers.
Has anyone distinguished their performance between the oc rom Darth prepared and the stock? Or either of those using one or the other launcher or a third party launcher? Just a thought. I was not paying too much attention before but I think I will check those out and pay attention.
My antutu scores are in the mid to upper 19ka so far.
Burs
Advanced Member
Forum Posts: 144
Thanks Received: 33
154
2014/01/27 - 21:08
Great idea. All my issues are on last few pages, so I have nothing to hide :)
You'll have to check for other people posts/issues anyway, so it all on one place and no need for PM...
Burs
Advanced Member
Forum Posts: 144
Thanks Received: 33
155
2014/01/27 - 21:19
maikal said
MY camera and flashlight work fine. Also been getting some fc when I have switched between loaders.
Switching between which loaders? You mean launchers? I don't get you.
I measured performance between stock and OC kernel with AnTuTu, and the difference is about 7% in favor to OC kernel. How much warmer it gets I'm not sure, because I didn't do those stuff on stock frequencies. Default launchers stutter a bit, so I recommend Next Launcher, Nova Launcher or SPB Shell 3D.
saykooo
Forum Posts: 11
156
2014/01/27 - 21:39
hi
screen use 100%
battery runs out quickly
everything off in the background
What is the problem
jesmail
usa
Forum Posts: 26
Thanks Received: 5
157
2014/01/27 - 21:47
I can add, my camera flash and flash light both work.
The flash light app I use is "Super-Bright LED Flashlight" by Surpax Technologhy Inc.
On the camera, at first I thought it did not work, but I switched it to manual mode and saw it worked. Then switched back to auto mode and it worked as well.
So far this release has been much better for me. Much smoother and less lag then earlier releases.
I have seen the problem in the launcher being able to switch backgrounds, but was able to use the first launcher and select the back ground, followed by a reboot and it would stay. Then switched to launcher3 and the back ground stayed. Plan to try some of the launchers in msg 155 by Burs.
I also loaded CWM and OC kernel without issue, have not checked battery drain.
maikal
Forum Posts: 394
Thanks Received: 51
158
2014/01/27 - 22:07
S
Sorry, yes launchers. I notice mine acts different while I as setting the apps up to my licking with each launcher. I had Nova in the 4.22. I will probably thry it again tonight.
vandall666
159
2014/01/27 - 22:25
Ok guys, pm me with issues
i will create new thread with problems for devs so they dont have to dig through 10+pages
jy_p
Forum Posts: 44
Thanks Received: 20
160
2014/01/27 - 22:44
This would be useless...
The ROM comes from a guy/opinions-on-teclast-p90hdam in China.  There is already peoples reporting bugs there.  They will make the next or final version without even looking at you bugs here.
This one here is a custom ROM build from the BETA and it will never be fixed.
Just wait until they release the final 4.4 and I'm sure you will get a new custom ROM out of it.
regards,
Burs
Advanced Member
Forum Posts: 144
Thanks Received: 33
161
2014/01/27 - 23:44
I tried it just now and no joy. But now I remembered something I forgot to ask at least 3 times. When booting up (before the first logo shows), and immediately before complete shutdown, I hear some crackling on the back side where camera is located. It's the same sound I hear when switching from video to image recording inside camera app. Is that a normal sound? If not, maybe it's in connection with the led flash?
saykooo said
screen use 100%
You mean 100% in Settings/Battery for the screen? Yes, that's weird. But I think it's just a stats bug. "Screen on" shows different, but I think correct data.
Nova, Next and SPB are super-fluid and very eye-candy. Some live wallpapers drop the framerate, but most of them can be set up without considerable frame drop. I wasted 2,5 hours today on setting my Next launcher lol
maikal
maikal
Forum Posts: 394
Thanks Received: 51
162
2014/01/28 - 05:27
I just wanted to mention that on a whim I pulled down on the action bar were the time and wifi is displayed and ticked on the gps in the action bar and it turned on my location setting. Pressing on  the gps changed the grey area text to "device only", then my google location reporting immediately turned "on".
Burs
Burs
Advanced Member
Forum Posts: 144
Thanks Received: 33
163
2014/01/28 - 10:59
Wow! Thanks. Why didn't I thought of that before? :)
Location is now working. I've set it to "Battery saving" mode, although "High performance" is working too, but I guess it drains the battery faster. And I'm already sick and tired of that excessive battery draining, so no thanks :) Google Earth still don't see the location with any option set. But at least Maps are working now.
DarthJabba
Forum Posts: 551
Thanks Received: 396
164
2014/01/28 - 12:49
The battery drain is indeed horrendous. But I am not sure whether we are simply getting incorrect battery information. Whatever the problem, it is very annoying - so much so that I am now seriously contemplating a return to Jelly Bean Kasty v2.06 DJ mod ...
Burs
Advanced Member
Forum Posts: 144
Thanks Received: 33
165
2014/01/28 - 13:13
How's that? Haven't you said before you're loosing only 6% per 14 hours? Or did I get something wrong here?
On the other side, the tablet is indeed in deep sleep mode while loosing so much battery, so what else could it drain so much? Unless, as you said we're getting incorrect battery info. Can we somehow disable auto-shutdown when the battery level reaches 0% by editing some file or something? That way we could know for sure if there's more juice in it, simply by disregarding that it is at 0% and checking how much longer could it work. If it shuts down, battery indicator is ok, and if it continues to work for longer period of time, it obviously shows false info. Am I making any sense?
75 Guest(s)
Devices in use: Desktop (71), Phone (3), Tablet (1)
wheaten156
luislx
algua
Twotrains
alexanddercrb
tsmfallen
