2014/01/21 - 21:53
Here is an Android 4.4.2 KitKat rooted firmware for the Cube U30GT2 tablet . This custom firmware is based on a KitKat test firmware from Cube dated 2014/01/21.
pipo_m9_pro_android442_kitkat_20131226_kitkat_b.pngImage Enlarger
Build information:
Kernel: Linux version 3.0.36+ (tangy@tchipserver2) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #305 SMP PREEMPT Tue Jan 21 16:51:52 CST 2014
Android 4.4.2: rockchip/u30gt2/rk3188:4.4.2/KOT49H/eng.tangy.20140121.170723:eng/opinions-on-teclast-p90hdst-keys
ro.tchip.version=(US@140121)_N2.61_V442.01
  • root with latest SuperSU version 1.89 (free version)
  • added Google Experience Launcher (GEL) in addition to Cube's stock launcher
  • optional ClockworkMod (CWM) Recovery easy install package (apparently reported to be not compatible with this firmware)
pipo_m9_pro_android442_kitkat_20131226_adduser4b.pngImage Enlarger
Notes:
Download: kasty-cube_u30gt2-442-20140121-rooted4_mu.zip
maikal, hasanpb, Wintermute, Uznamer, brmxn, plumplum88, Marcio, o.g.ram, Iemand, Burs, JuLePe, geloczigeri, validatus, saciorlux, Baeckman, Ohamn, bender83, Reini, vonkarayan, robiom, sipdude, timle, csjanne, swallow74, vandall666, diwill, affs, liketaurus, Ansgar, jrgalang, pfiffi3311
maikal
Jacksonville, Florida
Forum Posts: 394
Thanks Received: 51
2014/01/21 - 22:03
"sniff" Thanks Admin!!! Thanks to all who worked on this rom...."sniff" I thought Cube had forgotten us!
--Selv--, BigMihca
mooro20
2014/01/21 - 22:11
any issue?
plumplum88
Forum Posts: 40
Thanks Received: 14
2014/01/21 - 23:59
Thanks! wow you're fast!
Marcio
2014/01/22 - 00:20
Thank's from Brazil....Works with CWM???
kellbain
Forum Posts: 25
Thanks Received: 17
2014/01/22 - 06:46
Downloaded and installed with RC 1.71, absolutely no problems yet! I'll add an edit to this posting tomorrow when I have more time. So far it looks good, went to play store and installed a few apps. Try it!
diwill
2014/01/22 - 07:47
Installed with 1.7, no problems.NenaMark2 shows 36.0fps, and Launcher is very lag.Thanks and waiting for stable version!
--CoolZone--
Forum Posts: 14
2014/01/22 - 08:21
Thanks a lot for this release; really looking forward for a CWM-compatible version.
DarthJabba
Forum Posts: 551
Thanks Received: 396
2014/01/22 - 08:55
I could easily produce one - but it won't work.
You must use the Batch Tool. First, this is a totally new firmware version that cannot simply be tagged on top of Jelly Bean (there are too many incompatible binaries). Secondly, there is a totally new bootloader, so the storage really needs to be reformatted.
--CoolZone--, validatus, YS Tang, Ohamn, timle
2014/01/22 - 09:16
As DarthJabba just said and I already mentioned, an upgrade for Android 4.2 Jelly Bean or earlier Android version to Android 4.4 KitKat is unlikely to work, due to the new bootloader and system updates in the KitKat firmware.
Still, it may be possible (but not yet tested AFAIK) to update from one KitKat firmware to another KitKat using CWM if there is no new change in the Rockchip loader.
Vresto
2014/01/22 - 09:20
I have installed. But it is too lagy..When I tried 2.04 there was option to change resolution to normal and there was a big difference with speed..It is possible to change resolution in this version?
--CoolZone--
Forum Posts: 14
2014/01/22 - 09:29
Thank you for the clarification. I will try to flash it and see how it goes.
DarthJabba
Forum Posts: 551
2014/01/22 - 10:00
One thing that everyone should note - CWM Recovery for Rockchip is broken by KitKat. Don't install it (i.e, don't install CWM Recovery - until an updated version that fully supports KitKat is released).
JuLePe, geloczigeri, maikal, robiom, Ohamn, timle
Burs
Advanced Member
Forum Posts: 144
Thanks Received: 33
2014/01/22 - 10:34
I would also like to know if there's dual resolution support in this firmware. Thanks!
DarthJabba
Forum Posts: 551
2014/01/22 - 10:48
Can't see dual resolution anywhere. And I can't see multi-window anywhere either.
109 Guest(s)
Devices in use: Desktop (90), Phone (19)
hans41
rickybk
soniya07
ironmangitar
