[ ROM ] Cube U30GT2 Android 4.2.2 custom root firmware version 2.06 final (2013/10/29)
Wintermute
Forum Posts: 89
Thanks Received: 30
106
2013/11/08 - 18:58
CRF450Jim said
Thanks ... but it looks like UNLOCKROOT just supports phones??
It looks like I need to root it first to most current Kasty firmware (U30GT2_V2.06-20131029.img)  which has ARC Tools.  Then, use ARC Tools to install CWM.
What is the best way to root the u30gt2?
Don't worry about rooting unless you intend to use original Cube ROMs. Kasty ROMs are rooted, just flash U30GT2_V2.06-20131029.img using RKBatchTools and you're done. That will set your tablet to factory defaults and destroy all your data on it, including internal_sd.
jy_p
Forum Posts: 44
Thanks Received: 20
107
2013/11/08 - 19:08
Have you tried it?  It did worked for me with Cube's 2.04 and 2.06.
validatus
Advanced Member
Forum Posts: 180
Thanks Received: 18
108
2013/11/08 - 20:15
@jy_p
204 206 are rooted
look at su version
regards
CRF450Jim
109
2013/11/08 - 20:21
Wintermute, thanks for the info!
I have 20131029 loaded.
Next is ... CWM.
CRF450Jim
110
2013/11/08 - 20:23
OK, CWM done.
Can the clk speed be adj with this?  If so, how?
jy_p
Forum Posts: 44
Thanks Received: 20
111
2013/11/08 - 21:38
validatus
Strange, but I got error from Titanium BKP reporting that the tablet wasn't rooted.
After I rooted it, I didn't have that error from Titanium BKP anymore.
The following users say thank you to jy_p for this useful post:
validatus
christospr
112
2013/11/12 - 21:59
after i flashed the rom i can't get the miracast wireless display to work, it's connected but the screen won't appear on the tv. Has anybody tried that feature after the update?
Riederan
113
2013/11/13 - 15:52
Any way to center the home button?
tatyos
114
2013/11/14 - 20:54
Can somebody add these roms Sony Bravia Engine 2 script it is on sony developer .com its very useful code for sharp and colorful screen sight
Thanks Received: 3177
115
2013/11/14 - 21:04
Can you please give a direct link for the script/app ? Is it licensed to be redistributed freely ?
tatyos
116
2013/11/17 - 21:25
http://forum.xda-developers.com/showthread.php?t=1352859
tatyos
117
2013/11/17 - 21:27
tatyos said
http://forum.xda-developers.com/showthread.php?t=2281243
eeprom
Forum Posts: 15
118
2013/11/21 - 21:01
Any News about cube u30gt 2? the new kitkat? a new rom around? nothing!?
2510
119
2013/11/25 - 11:20
Dear all I am a newbie and I need some info from your side:
1. Does anyone experience abrupt restarts from this tablet while using a game or app or you enter an app and it exits immediately to the home screen?
2. Do you experience warmth on the left side of the tablet ( connections side while holding in Landscape ) while using apps or games?
3. Are these worrisome symptoms or is it normal?
ebeb2 U30GT2
Australia
Forum Posts: 36
Thanks Received: 9
120
2013/11/25 - 12:33
TiredTait said
Firstly, a huge thanks to the devs who release this firmware, you're 100% of the reason why I swapped my apple fondleslab for the cube.
Secondly for all people who are googling this question: The Cube U32GT2 with the most recent firmware works just fine with Fat32 formatted 64gb SD cards.  I couldn't find a casual answer on searching, so just telling the wirld
Thirdly, I am having one issue, don't know if it's hardware or firmware but thought I'd start here, every now and then if I don't use the tablet for a bit of time the tablet won't turn back on.  If I plug the power in (even for half a second) the tablet starts the boot sequence and works properly.  This happens regardless of tablet battery level and holding down the power button for a length of time does nothing.  Any thoughts?
I am the same issue...Does anyone know the reason.
Currently Online: Stellar7, WhiteD2125
104 Guest(s)
2 Guest(s)
Devices in use: Desktop (69), Phone (37)
WhiteD2125
Bokser
hamishduke
squal
squalangel
anqilan456
