[ ROM ] Cube U30GT2 Android 4.2.2 custom root firmware version 2.06 final (2013/10/29)
sztraik
2013/10/29 - 22:00
My problem now is that having installed your CWM recovery package I can't use stock recovery anymore... or am I wrong here?
Thanks Received: 3177
2013/10/29 - 22:06
Correct, CWM Recovery overwrites the stock recovery.
I wonder why you would need it anyway, CWM provides way more features.
sztraik
2013/10/29 - 22:26
Thanks for the quick reply and sorry, I should have explained better :)
Since I installed CWM, Rockchip batch tool doesn't see the tablet while in cwm recovery. PC require a 3066 driver and when I "force" to use the rockusb one it still doesn't see the tablet.
What am I doing wrong?
Edit: nevermind, I rebooted to bootloader... sorry!
ebeb2 U30GT2
Australia
Forum Posts: 36
Thanks Received: 9
2013/10/30 - 00:03
Hi Guys,
I have updated to this version and played around this for 2 hours now.
The antutu score is around 17500 which is much better than the previous versions.
It is definitely faster but it freezes sometimes in opening or sometimes in running heavy apps.
The problem with WIFI is not solved yet. It is slow at times and disconnects on standby.
I am not a hardcore gamer. I tested templerun, the app froze for a second in the beginning but thereafter it ran smoothly.
In conclusion, I feel this is the best rom till date if I ignore these drawbacks as they don't affect the basic functionality of the tab.
danielrostron
2013/10/30 - 00:24
Just installed this on mine.
Come straight from factory 2.03 and its running great so far.  The wireless seems slightly better however video playback doesn't seem to be as smooth as 2.03 - played a 720p x264 .mkv file and it was a bit jittery/stuttery, not massively but you could notice it.  It was slightly less noticeable when I was on 2.03.
Anyone know what is causing this?  Kinda bought the tablet to be able to watch 720/1080p stuff on my travels.....the tablet should be more than capable of handling it.
maikal
Jacksonville, Florida
Forum Posts: 394
Thanks Received: 51
2013/10/30 - 01:25
shadowx21 said
I can use this firmware for cube u30gt2 16gb model?
There is a 16gb model?
Forgot about that. Anyway yes, u can use this ROM for it. If you look at other kasty ROM threads they will tell you how. Version 2.04 "kasty" ROMs have instructions within the first 4 or 10 post. Not the ones with "Darth jab a in the title though. Those are different formats.
shadowx21
Riederan
2013/10/30 - 02:59
Something I've noticed with every recent update is that it somehow takes away the feature of being able to tell Google in Google Now "OK Google" to begin a search.
Is anybody else experiencing this?
francsal
Guatemala
Forum Posts: 48
Thanks Received: 17
2013/10/30 - 03:03
I'd be a bit careful there. I could be wrong, but I think that the "16 GB model" refers to the U30GT1, which doesn't have a HD display (it's 1280*800). As far as I know, the ROMs are not compatible between each other.
The following users say thank you to francsal for this useful post:
maikal, shadowx21
maikal
Forum Posts: 394
Thanks Received: 51
2013/10/30 - 03:49
Yes Francsal, you are right. i went back to where I purchased my tablet and found no u30gt2 with 16gb. It must be the u30gt1. I am thinking this far along in the changing of the roms that if these two were anything alike at one time, they are not any more. So I withdraw my earlier opinion and yield someone more knowledgeable to offer their thoughts.
Sorry Shadow, and i hope you have not gone there yet on my advice. I think I mixed my reply to you with wanting to also reply to danielrostron who asked where to find instructions to flash the rom.
kar12
Forum Posts: 16
2013/10/30 - 07:37
Is it possible to restore my application with CWM from old backup since I install new 2.06 ROM ??
I can use titanium back up but it takes hours to restore .
Thanks in advance .
robiom
Norwich, UK
Advanced Member
Forum Posts: 124
Thanks Received: 27
2013/10/30 - 09:01
Just installed this and all went well. Then flashed cwm with arc tools and restored all my apps.
Amazingly all is working okay. A good start to the day!
Rob
shadowx21
2013/10/30 - 09:23
Thanks for your replies.
I checked these threads but didnt found info about compatiblity between arctablet firmwares and 16gb model.
all tools which i used show me i got cube u30gt2 and with hd display. some screenshoots:
http://img854.imageshack.us/img854/5412/uy63.png
http://img20.imageshack.us/img20/8882/yt1r.png
http://img9.imageshack.us/img9/2176/jipu.png
http://img138.imageshack.us/img138/7483/0oxy.png
now really dunno which device i got....
2013/10/30 - 09:27
shadowx21,
Can't say for sure, but looking at the model number and kernel/firmware version in first screen shot, it looks like your device is a regular U30GT2.
uy63.pngImage Enlarger
shadowx21, maikal
Oyeee
Forum Posts: 11
Thanks Received: 9
2013/10/30 - 10:10
@ maikal & francsal
My U30GT2 is 16 GB with quad core and full HD
The following users say thank you to Oyeee for this useful post:
maikal
Wintermute
Forum Posts: 89
Thanks Received: 30
2013/10/30 - 10:18
Well, U30GT2 has definitely been offered in 16GB and 32GB options and still is. Same model, different flash NAND size. Even cube51 doesn't make difference between them in terms of provided ROMs or other specs. I'd suppose it to be fully compatible then.
Have installed this ROM mod and Arctools CWM, no major issues here so far. Well except the H264 MKV video playback is still jerky.
The following users say thank you to Wintermute for this useful post:
shadowx21
Currently Online: desluk
98 Guest(s)
Devices in use: Desktop (95), Phone (4)
desluk
cimoral
merlin077
nrod
midnight-gr
Pajaro047
