[ ROM ] Cube U30GT2 Android 4.2.2 custom root firmware version 2.06 final (2013/10/29)
lambo2000
271
2014/02/18 - 00:24
I don't think it's placebo effect, apps in the startup have timed out like, drive playstore and the web browser.
If I compare the time to be able to use the tablet now and when it was fresh it's much longer now.... also please read about trim and android to understand what I'm talking about: http://www.anandtech.com/show/7185/android-43-update-brings-trim-to-all-nexus-devices
Burs
Advanced Member
Forum Posts: 144
Thanks Received: 33
272
2014/02/18 - 11:50
Ok, so triming is introduced on Android and nand chips, but this is not Nexus and OS is not 4.3. And the article is also saying that performance degrades when copying stuff to a device multiple times, which is not your case as you said. So I would still say it's something else at play.
gblnCube30GT2
273
2014/03/29 - 10:48
For those that asked for the stock rom: This baidu page appears to offer the cube V2.06 file ... click the downarrow-in-a-tray icon, then pick the 2nd button (right hand side of upper row) in the dialog (for standard, slow, download). The 1st button is for faster download using a baidu downloader that I didnt install. I have not put it on my tablet.
U30GT2_V2.06-20131029.zip
http://pan.baidu.com/share/link?shareid=4191368204&uk=322335357&from=name
The following users say thank you to gblnCube30GT2 for this useful post:
lardd
pcarrefour
274
2014/04/19 - 14:53
Hi
installed this ROM,works good, but now, I've found that lower buttons like BACK, HOME, OPTIONS, are blacked out (if I touch there, it works but the buttons are not there)
they are not white with the black background like they must be. It's just all black
When I've innitially installed rom, it was OK
any solution?
by_ron
275
2014/08/12 - 11:51
I installed this rom and everything looks good, but in standby mode battery lost ~15% in a night.
I set the wifi turn off in standby and with the stock rom it worked properly (lost 1-3%).
What is the secret to work? :)
Herb
276
2014/08/16 - 20:17
hi.
im looking for the cwm package for this rom. the link in the first post takes me to the kitkat cwm.
thank you.
never mind found it.
by_ron
277
2014/08/19 - 12:57
by_ron said
Solved after some reboot.
MojoDojo
278
2014/09/21 - 05:23
People, I'm very sorry for the (likely) stupid question, but I've checked everything around, and googleing always pointed to devs applying it in apps, or installing those launchers...
Plain and simple, I can't find anywhere in this topic's rom an option to change the 'layout' of the configuration to the black (dark) theme, with the black background. All my other devices have it, and when I installed it remained in the white background, even some options appear with white letters in a white background.
There are no 'Theme' options anywhere in the rom provided - or am I missing something? Sorry if off-topic but any pm would also be appreciated.
And thanks for the dev team for this amazing work, you managed to max everything the hardware of the tablet is capable of - I don't go to 4.4 Kit kat android because I'm a lover of good old Google Talk app, and am afraid to lose it to Hangouts (yuck!) in a more up-to-date rom.
MacGyverG
279
2015/02/13 - 20:34
Hello all,
I really would like to use the ROM of this post as this seems to be the most stable one for the U30GT2, but it's now twice that I tried to flash it, and everytime the same error at the end of the proces.
Is something wrong with the image (since it was last posted) or am I doing something wrong.
This is the log of the Rockship Batchtool 1.7
**********Restore Action**********
**********Restore Start Total<1>**********
<Layer 10-4> Test Device Start
<Layer 10-4> Test Device Success
<Layer 10-4> Lowerformat Device Start
<Layer 10-4> Lowerformat Device Success
<Layer 10-4> Check Chip Start
<Layer 10-4> Check Chip Success
<Layer 10-4> Get FlashInfo Start
<Layer 10-4> Get FlashInfo Success
<Layer 10-4> Prepare IDB Start
<Layer 10-4> Prepare IDB Success
<Layer 10-4> Download IDB Start
<Layer 10-4> Download IDB Success
<Layer 10-4> Reset Device Start
<Layer 10-4> Reset Device Success
<Layer 10-4> Wait For Loader Start
<Layer 10-4> Wait For Loader Success
<Layer 10-4> Download Firmware Start
<Layer 10-4> Download Firmware Fail
**********Restore Done Success<0> Fail<1> Time<83663>ms**********
Thank you for your help.
Mark06
Forum Posts: 222
Thanks Received: 41
280
2015/02/13 - 20:51
reset idb in androidtool, then flashing firmware img with androidtool.
Cube u30gt2 tab
musico59
Forum Posts: 14
281
2015/06/24 - 12:56
I have also the same problem....I'm using now this rom since 1 year and last 6 months the tablet is becoming slow and slow.....
now when I press the home button, it takes sometimes 10 secondes to arrive to the home page....and its the same with most actions like starting an app.....
Is it an app that is taking all the ressources ? or cache memory sommewhere full......
I didn't try to reset to factory....and I don't want to...
Lawsomester
282
2015/06/26 - 17:25
Pls am new here i want to instal this custom rom on my cube u30gt2 but its not yet rootrd how can i root it
52 Guest(s)
Devices in use: Desktop (44), Phone (8)
wogoko8553@yubua.com
hellander
elousstad
relaytester
revoltown
