[ ROM ] Cube U30GT2 Android 4.2.2 custom root firmware version 2.06 final (2013/10/29)
Burs
Advanced Member
Forum Posts: 144
Thanks Received: 33
226
2014/01/21 - 19:35
Wow! :) And? How does it look like? Is it usable? Are there many issues? Do you recommend it?
Wintermute
Forum Posts: 89
Thanks Received: 30
227
2014/01/21 - 19:44
Interesting... it comes with new Flash utility. It's in Chinese but can be switched to English translation by editing ini file. I wonder whether the first tab (called Download Image) can be used to download full image backup from tablet or it's the other way round. Other functions are also quite interesting.
I am not going to flash this and destroy my data, hoping Kasty and DJ would prepare and publish CWM compatible ZIP file at some point. Is there even any hope 4.2.2 could be upgraded to 4.4 retaining user data, without resorting to full img flash?
jy_p
Forum Posts: 44
Thanks Received: 20
228
2014/01/21 - 19:48
...hmmm.
The instructions are in chinese. I can deal with that using google Translate, but the tool fails to open the config file (probably because of chinese characters in there), and I can't find how to deal with that.  Someone else would have to help finding how to flash that img file.
Wintermute
Forum Posts: 89
Thanks Received: 30
229
2014/01/21 - 19:54
Edit ..AndroidTool_Release/config.ini to have entries like this:
[Language]
Selected=2
That will switch to English translation. Also make sure none of the folder names contain any chinese characters, use rename function to remove them.
Flash tool starts for me with both Chinese and English translations but I am not ready to proceed with actual flashing.
jy_p
Forum Posts: 44
Thanks Received: 20
230
2014/01/21 - 20:21
Thanks Wintermute!
I just flashed it! It is booted and functionnal...
I'll have some feedbacks latter or tomorrow.
The following users say thank you to jy_p for this useful post:
Burs
Wintermute
Forum Posts: 89
Thanks Received: 30
231
2014/01/21 - 20:28
Great Smile
Thanks Received: 3170
232
2014/01/21 - 21:58
I have just posted a custom Android 4.4.2 KitKat test firmware:
http://www.arctablet.com/blog/forum/cube-u30gt2/rom-cube-u30gt2-android-4-4-2-custom-root-firmware-20140121/#p37485
I am afraid a CWM style firmware packages can't be done for upgrade from Android 4.2 or earlier versions as KitKat firmwares use a new Rockchip loader than can't be upgraded thru CWM. You will have to use Rockchip Batch Tool.
brmxn, Burs
jy_p
Forum Posts: 44
Thanks Received: 20
233
2014/01/21 - 22:18
It boots fast, it is more fluid than all previous ROM 4.x.x that I have tried.
No crash so far.
Camera (both),Rotation, bluetooth are working.
TUN modules present, but no CIFS.
Audio over USB doesn't work. :-(
Antutu score:  18286 @ 1.6GHz (even if I got over 20000 with some other clocked kernels/ROM, I found this ROM to be more responsive).
Really good!  I am surprised to see a good ROM straight from Cube after all we have seen.  I don'T see any reason why I would go back to any other ROM.
Cheers!
brmxn, Burs, maikal, Ohamn
DarthJabba
Forum Posts: 551
Thanks Received: 396
234
2014/01/22 - 13:52
19441 Antutu score with an overclocked kernel (cpu=1800mhz; gpu=768mhz; DDR=stock). Pity there is no CWM for playing with overclocked kernels (had to use RKAndroidTool to install separate components - and that is not for the faint-hearted).
maikal
Jacksonville, Florida
Forum Posts: 394
Thanks Received: 51
235
2014/01/22 - 14:08
Darth did it fix your camera issue we briefly discussed before? It di not fix mine. If anyone has any ideas let me know. I had tried instaling the camera app for KK early on when they offered the apps. I could not get rid of the older camera so I went ahead and tried to delete the kitkat camera. Well that appears to have taken something with it and the camera will only work for screen shots now. I would like to get it back before I give this tablet to my daughter as a gift now that it has kitkat.
DarthJabba
Forum Posts: 551
236
2014/01/22 - 14:38
Yes, the camera is working.
maikal
Forum Posts: 394
Thanks Received: 51
237
2014/01/22 - 15:06
Thanks. Unfortunately mine is forceclosing each time. If any one has any ideas I'd appreciate it. Think I will reflash to see if that works.
NeurOSick
Montreal
238
2014/01/22 - 16:06
hello, great custom firmware, even if it is almost perfect, all firmwares have qualities and faultless. I do not know where it comes from, but when the tablet is in standby mode continues to drain the battery, which is not the case with CF TNT and 900SuperSport. I tried to flash it with the CF kernel 900SuperSport and this has not solved the problem. Someone has an idea? Otherwise, for dev's, it would be nice to have a look because this firmware really worth it.
Thank you and good continuation!
NeurOSick
DarthJabba
Forum Posts: 551
239
2014/01/22 - 16:57
Presumably you are talking about 4.4.2, and presumably you used the "Restore" option in the Batch Tool?
DarthJabba
Forum Posts: 551
240
2014/01/22 - 16:59
I'm not sure we should be talking about KitKat in this thread, because I am now confused as to which ROM everyone is talking about!
robiom
83 Guest(s)
Devices in use: Desktop (74), Phone (9)
dubsiki
dubsi
vblxcimdwqgcztgrve
billcamp1984
simoxor33
kontra007
