[ ROM ] Cube U30GT2 Android 4.2.2 custom root firmware version 2.06 final (2013/10/29)
validatus
Advanced Member
Forum Posts: 180
Thanks Received: 18
136
2013/12/04 - 14:58
Hello DJ
You said
max cpu = 1800 mhz
max gpu = 798 mhz
ddr = 720 mhz
can you remember us what are the stock values
thx
DarthJabba
Forum Posts: 551
Thanks Received: 396
137
2013/12/04 - 17:13
cpu=1608 mhz
gpu=600 mhz
ddr=528 mhz
validatus
StefMug
138
2013/12/06 - 12:20
vlevi said
Oyeee said
In sleep mode, 1% per hour is quite normal
I have about the same battery drain, but I don't think it is "normal". I've chechked the system tuner app, and it says, the processor is offline most of the time. This is the expected, for example, whole night it is suspended. The battery monitor shows the wifi active all the time, but it is false, because clearly visible, that the wifi connects when I start using the tablet. But something must be there, which drains the battery in sleep mode. 1% per hour is not normal with 7600 mAh batteries. For comparison, my phohe has a 2000mAh battery, and mtk65.. quad core processor, and it can be idle for 6-7 days. 1/4 battery capacity, but longer idle time, it means, that my phone uses idle power more than 5 times better.
The other thing, which I see as a difference, for example play updates. With the cube, while play is running updates, the tablet is nearly useless, but my phone (lenovo s750), i didn't notice anything, but the gogle play update progess in the statusbar, I can use may phone while updating, withouth any break or slowdown.
I don't know if it is Rockchip's, or Cube's responsibility, but I don't see any significant improvement since the version 2 sdks came out from rockchip.
The only thing, why I don't switch back to the 2.04 is, that I have win8.1 on my pc, and I can't install rockchip drivers http://www.arctablet.com/blog/wp-includes/images/smilies/icon_sad.gif
hy,
I see the same problems as vlevi!
I don't think this short standbytime is normal for Polymere batteries, there is still some bad battery usage in cube firmware
Battery drains within 3-4 days WITHOUT ANY usage! this would be only last 100 hours in standby/sleep...
compared to Google/Samsung/other Tablets which have around 300 hours Standby!!!
also there is the problem with the playstore updates - in this time the cube is useless like a brick, i think there is a problem with chipset, too low cache or something...
but in daily usage i still like my cube ;-)
DarthJabba
Forum Posts: 551
139
2013/12/06 - 15:45
Battery drain depends on many things. Some are not under the manufacturer's control (e.g., which apps you have installed, and what they are doing in the background). Some are under the manufacturer's control (e.g., the kernel). Some kernels are battery hogs, and some are not. Some don't have the phone problem, and some do.
What kernel version does your ROM have?
vlevi
Forum Posts: 46
Thanks Received: 4
140
2013/12/06 - 18:17
I tried many ROM versions. 2.04test, 2.04 final, 2.06, ... I have CWM backups, and I can switch between them easily.
Battery drain in idle might be some of the apps, but I don't think.
System tuner shows, that the processor is offline most of the time (for example 22hrs offline, 15mins are running low speed, 4-5 minutes at higher speeds). I think, if a processor is offline, it means 0Mhz, and nothing can run and use power.
But I will try to install one the stock ROMs, and see what happens.
DarthJabba
Forum Posts: 551
141
2013/12/06 - 18:52
I think you will find that you are mistaken. I doubt that the system will ever run at 0mhz. There is always something going on (else how would the system detect signals?) and so the cpu would be running all the time. If idle, it would mostly be running at the lowest clock speed above zero that the kernel supports.
DocBubba
142
2013/12/06 - 20:08
DJ,
It's 3.0.36+
lincp@tchipserver1 #12
wed oct 16 11:48:36 CST 2013
But listen, my beef is not that it is a battery hog, but that it becomes a battery hog with kasty's ROMs, both 2.04 and 2.06. It behaves normally with stock ROMs.
I am, however, open to suggestions.
validatus
Advanced Member
Forum Posts: 180
Thanks Received: 18
143
2013/12/06 - 20:09
Yes
This is called "idle loop" where the system stands since an event occurs
vlevi
Forum Posts: 46
Thanks Received: 4
144
2013/12/07 - 10:29
" It behaves normally with stock ROMs."
I will try it.
tobbe
145
2013/12/09 - 22:34
Does anyone have any more input on this subject about the battery idle drain?
My experience is that my Cube drains about 2 % per hour when it is on stand by.
That means that I have to charge it many times a week, which is a shame compared to i.e. an iPad.
I am going to try this app -> "cron tasker free" to see i this app can completly turn off the wifi during night time to see if the wifi is the problem.
Can you, vlevi, give more input from your try with "stock ROM"?
ntinos_tech
Forum Posts: 19
146
2013/12/10 - 15:41
Hi everyone,
2 Questions:
a.does anyone tried to connect u30gt2 with a USB LAN Ethernet adapter? I need this in order to have the tablet connected to internet without wifi. If yes can you please share with me the adapter model....and from where you got it.
b. does anyone succeeded to connect external usb HDD to the tablet? even using an external power USB hub and OTG cable....?
thank you all in  advanced
Thanks Received: 3177
147
2013/12/10 - 15:51
a. I successfully used an adapter based on ASIX AX88772 chip on another tablet, I don't know if the Cube U30GT2 supports it as well as I don't own this tablet. Don't expect fast speeds for the LAN, you'll probably get something in the 10/100 Mbit/s range.
b. As for the external HD connected thru an OTG cable, it may work or not, depending on which filesystem it's formatted and if it's self powered or not. I don't know the exact rules there...
Wintermute
Forum Posts: 89
Thanks Received: 30
148
2013/12/10 - 16:14
a. Kind of. Had bought a cheap ASIX AX88772 from Chinese site which turned out to be using a clone of original ASIX chip (oh well, they copycat about everything apparently...). Worked out of box in Linux. Worked on Windows and OSX only with particular drivers, older ones that didn't include checking of HW authenticity. In Android however, no luck whatsoever. Tried two Android tablets, both froze a few moments after plugging ASIX USB device in. Everytime. It might work with authentic AX88772 HW, i don't know. Also when tested in Linux/Windows, transfer speeds were tolerable, hitting 100mbit limit both up and down.
b. I have connected several, 2.5" - 3.5", NTFS formatted, <=1TB, USB2 HDDs to U30GT2. Detected and accessed just fine. No comments on stability. Can't remember whether I used powered USB hub or connected directly via OTG cable. Will check again and post here eventually.
Wintermute
Forum Posts: 89
Thanks Received: 30
149
2013/12/10 - 19:57
@ntinos_tech
Update.
No device connected to an USB hub (powered or not) gets detected by tablet. As pointed out elsewhere, there must be a specific support in kernel to allow for USB hub functioning. How it comes default kernels are lacking such trivial feature is difficult to understand.
Results:
1) 2.5" USB-powered HDD connected to OTG fails to spin-up due to insufficient power provided by U30GT2. Tried two different HDD brands and models. No luck.
2) 2.5" same as above, but connected using Y fork cable is detected and works. I've used powered USB hub as power source only this time.
3) 3.5" externally-powered HDD connected to OTG is detected and works. No problems here.
All HDDs were NTFS formatted, capacities 0.5TB and 1TB, mounted as read-write by default. Write speed was ridiculously low, like ~2MB/s for large files, much less for small files. Measured by copying files from internal NAND.
The following users say thank you to Wintermute for this useful post:
maikal, ntinos_tech
ntinos_tech
Forum Posts: 19
150
2013/12/11 - 19:51
Really thank you.can anyone let us know how we may avoid battery drain during stand by? Does anyone succeded something please share your findings and yor actions...else i have to go back to august kasy rom.......i hate updates hahaha especially when it create issues.
Currently Online: Stellar7, WhiteD2125
104 Guest(s)
2 Guest(s)
Devices in use: Desktop (69), Phone (37)
WhiteD2125
Bokser
hamishduke
squal
squalangel
anqilan456
