[ ROM ] Cube U30GT2 Android 4.2.2 custom root firmware 2.06 test version (2013/10/17)
2013/10/20 - 22:58
Here firmware update test version 2.06 for the Cube U30GT2. Our custom firmware is based on Cube firmware published on their forum with 2013/10/17 release date.
( U30GT 2 V2.06 20131017.rar /  U30GT 2 V2.06 20131017.img )
Build information:
Kernel: Linux version 3.0.36+ (lincp@tchipserver1) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #12 SMP PREEMPT Wed Oct 16 11:48:35 CST 2013
Android 4.2.2 Jelly Bean: rk30sdk/rk30sdk/rk30sdk:4.2.2/JDQ39/eng.lincp.20130906.092409:eng/opinions-on-teclast-p90hdst-keys
(ro.rksdk.version=V2.06 20131017)
Cube U30GT2 1017 firmware revision history (thanks arthurwen1234 for the translation)
  • 1. Original text: Fixed Wifi off, screen off issue. (I think maybe it fixed screen off, Wifi off issue)
  • 2. Setup adds win8 white style (I don't know what this means.)
    In previous version, there is win8ui but it's unstable. 2L attahced WIN8APP
  • 3. fixed multi-task switching error
  • 4. improve stability
  • 5. support H265 video format
  • 6. optimzed power consumption under standby mode
  • 7. Remove dual resolution mode
Chinese speaking users are welcome to provide us with a better translation Wink
  • root with latest SuperSU version 1.65 (free version)
  • increased storage space for applications (/data partition) to 4 GB
Download:
(stock recovery)  kasty-cube_u30gt2-422-206t_20131017-rooted4.zip
Flash the firmware with Rockchip Batch Tool 1.7,  use Restore button.
plumplum88, maikal, francsal, 080200, khmra, refedit, robiom, Wintermute, Bsoft2007, validatus, Baeckman, Dan Mullen
affs
Murcia (Spain)
Forum Posts: 13
Thanks Received: 17
2013/10/20 - 23:15
Are included on the version rom kasty-cube_u30gt2-422-206t_20131017-rooted4 WIN8APP  attached?
would it be possible to eliminate stock recovery from the rom?
The following users say thank you to affs for this useful post:
maikal, validatus
2013/10/20 - 23:19
We'll include a CWM recovery add-on if there is interest in this firmware.
maikal, hasanpb, robiom, itspecht, validatus
newbi
Forum Posts: 46
2013/10/20 - 23:36
To flash or not to flash   hmmm
Love to know what's this about win8 UI.
affs
Murcia (Spain)
Forum Posts: 13
Thanks Received: 17
2013/10/20 - 23:42
The ROM works well, Miltiwindows, wifi, etc..
I Can not install the recovery CWR, by both ways (update.zip, RKAndroidTool)
Segarra
2013/10/21 - 03:59
Hello, what about lag?
robiom
Norwich, UK
Advanced Member
Forum Posts: 124
Thanks Received: 27
2013/10/21 - 10:02
@affs said "The ROM works well, Miltiwindows, wifi, etc..   I Can not install the recovery CWR, by both ways (update.zip, RKAndroidTool)"
I think this is the same problem most others had with previous ROMs with 4GB data partition. I had to use the ROM with a standard 2GB data partition before I could get CWM recovery to install.
Any news on battery drain?
Rob
robiom
Norwich, UK
Advanced Member
Forum Posts: 124
Thanks Received: 27
2013/10/21 - 10:07
@admin, forgot to ask if the new kernel mods include the over clocking and modified operating voltage from kernel #38?
2013/10/21 - 10:15
Nope it's stock kernel, no overclocking.
As for your CWM Recovery install problem, I don't think they are related to the apps partition (/data) storage size. I'm almost done with my ArcTools package for easy CWM R installation, maybe you'll want to give it a try. I'll post about it soon.
robiom, hasanpb, refedit, affs, Bsoft2007, maikal
robiom
Norwich, UK
Advanced Member
Forum Posts: 124
Thanks Received: 27
2013/10/21 - 10:24
@admin
Interestingly, with the over clocking ROM the battery drain was less because the modder also changed the operating voltage when it was in sleep mode to a lower level and the speed was reduced as well.
Good news about the Arctools update, thanks.
Rob
The following users say thank you to robiom for this useful post:
080200
khmra
2013/10/21 - 11:47
Build information:
Cube U30GT2 1017 firmware revision history (Ch'English from Google Translate)
  • a fix wifi off screen off
  • two set to join win8 white style
  • on a version win8ui but unstable, 2L attached WIN8APP
  • multi-task switching error fixes
  • to enhance stability
  • Add support H265 video
  • Standby power optimization consumed
  • seven castrated pair resolution
Download:
first thanks again, but i have some problem on this Rom:
-wifi too slow comparing to others
-Battery drain too fast in processing
-no options to display
newbi
Forum Posts: 46
2013/10/21 - 12:21
Admin doesn't do the roms they come from the Cube Chinese site and it's a test rom so there will be problems.
validatus
Advanced Member
Forum Posts: 180
Thanks Received: 18
2013/10/21 - 13:33
There may be problems !!
maikal
Jacksonville, Florida
Forum Posts: 394
Thanks Received: 51
2013/10/21 - 14:04
With DArthJabba's new #38 special I am not having any major battery drain to speak off so far. Last night I plugged in the old telephone apps. Again not noticing any major drains, but Gsmart battery Monitor was reporting the phone apps taking a major bite of the battery power, but that might not translate to "Major" battery usage, just that it's still using the most of what every other parts  of the system is using. I am doing a battery re-callibration today, so I will report on it later.
I would like to know about the windows UI in this current offering. Has anyone figured out about the ...ouch..castration pair resolution? Could that be what KHMRA is reporting ->-"no options to display"
arthurwen1234
Forum Posts: 25
Thanks Received: 13
2013/10/21 - 16:26
I tried to translate what Chinese showed. (But the summary is too short to be described precisely.)
The following users say thank you to arthurwen1234 for this useful post:
admin, maikal, refedit, Wintermute, robiom
75 Guest(s)
Devices in use: Desktop (69), Phone (6)
