[ ROM ] Cube U30GT C4 Android 4.4.1 KitKat custom root firmware (test version dated 2013/12/12)
validatus
Advanced Member
Forum Posts: 180
Thanks Received: 18
46
2014/01/05 - 13:39
@newbi
where can be microphone
bests
yoavst
Forum Posts: 51
47
2014/01/05 - 13:56
newbi said
Have you tried to flash a factory not a mod one? and use cubes flash tool?
If the computer is seeing it then it's not borked you just got to find away to flash a rom.
I haven't got mine by me but is there a very small reset hole just below the volume button?
It maybe something else I can't remember sorry.
Oh and don't forget the folder name with the rom in it must NOT be in Chinese you have to rename.
the reset hole not working, still same error.
can can you give me link to cube official firmware?
newbi
Forum Posts: 46
48
2014/01/05 - 17:17
Use chrome browser to translate
http://www.51cube.com/ch/DownShow.asp?ID=201
Don't for get to rename the folder to English if needed. This the U30GT 2 also called U30GT pease 2 quad-core
Do not use this on any other tablet not even the U30GT C4. Let us know how you get on.
mooro20
49
2014/01/06 - 14:02
yoavst
Forum Posts: 51
50
2014/01/06 - 14:10
mooro20 said
may be you should try this :http://www.arctablet.com/blog/forum/cube-u30gt2/unbrick-your-tablet/
what should i do with the contacts point?
trecords
51
2014/01/06 - 15:06
May it work with my dual core Cube U30GT-H chip is RK3066, let me know please, it has 1GB of ram and 1.6 GHZ speed.
Thanks Received: 3170
52
2014/01/06 - 15:09
Your U30GT-H has a different architecture (dual core vs quad-core) and different hardware, the U30GT-C4 firmwares won't work on it.
trecords
53
2014/01/06 - 16:06
Right! I have realized it when I connected it and was ready to format but sudden seen a Chip Version RK31 on rockchip updater and stopped process at last second :D
Thanks for info.
Will KitKat available for U30GT-H ever ? hardware can handle it I think.
54
2014/01/06 - 17:58
trecords,
I doubt Cube will make an Android 4.4 KitKat update for their U30GT-H, knowing the device is more than one year old and Cube usually don't support devices longer than a few months, which is quite sad Confused
Still, watch for Crew RKTablets RK3066 forum section as the Crew has some great custom KitKat firmware in the works for many Rockchip devices.
trecords
55
2014/01/06 - 18:56
hmm so pity, I will try to get new cube as this one is already a year with me. I will research for frimwares on that form thanks admin :)
DroidUserRJC
56
2014/01/09 - 13:11
I have flashed this ROM to my C4 and it's working just fine. No big problems so far, only 1 freeze and reboot shortly after the flash. Looks like an incident, since I have used it intensive for 2 days and no problems encountered any more.
Also a stability test on the background and using it normally works great. Let me know what I can test more.
niceplay
57
2014/01/10 - 05:18
@yoavst
I have had the same IDB problem. The only solution was disassembling to enter the maskrom mode.
You have to shutoff by pressing the powerbutton >10sec., connect your tablet via usb and start RKBatchTool and load a rom-image. Bridge the two solderpoints now and press the powerbutton while bridging. Your tablet should recognized by pc and RKBatchTool shows blue square, now release the powerbutton before shutoff.
Now its time to click restore button in RKBatchTool.
My tablet (rev. v2) has a "maskrom bug". When i  release the powerbutton after i got the blue square the tablet disconnects  and i get a grey square. The only solution in this case was holding the powerbutton after blue square appears and !quickly! click restore. Then the restore stops because tablet shutoff (caused by pressing powerbutton >10sec.) but after this it is possible to restore in usual flashmode (green square).
I've tried to flash the 2.07 bootloader again with no success (same IDB failure). I think the rev. V2 has other rom-IC's and its not compatible with 2.07 bootloader but i don't know.
If somebody knows about the bootloader issue and maybe about fixing please post!       -e.g. imasoft ;)
-good luck
pasconat
58
2014/01/10 - 11:07
kellbain said
I did load the KitKat rom onto my U30GT2, it can't get past the multiple screens it wants to open with. Figured it would be a display problem as the displays are different. Had to do a full restore of a working ROM. No problems afterward. You do need to restore with Rockchip 1.70 and you'd better know how to push the buttons to get into bootload mode.Surprised
Hello !!
Thank you all for your excellent work and help !
This morning I did want to update my U30GT2 to the latest firmware and guess what ... Eyes semi opened and not used to see U30GT2 and U30GT C4 in the same sub folder in the forum I did take the first one I saw.. that's to say this one for U30GT C4 instead of kasty-cube_u30gt2-422-206_20131029-rooted4.zip ...
Consequently, flashed worked but after restart I had a screen split in 4 with the booting process until it would switch off automatically ... Then I looked closer to the rom and I discovered my mistake but too late !
So I put back my tablet in flash mode, connected device green in Rockchip Batch Tool 1.7, but when I try to "Restore" the rom kasty-cube_u30gt2-422-206_20131029-rooted4.zip I have at the end Layer 2-1-2 Fownload Firmware Fail ...
Now the tab will not switch on anymore (also no CWM access) but stays in flash mode. After firmware fail, I have a red square (in Rockchip Connected device) but if I disconnect and reconnect, I have the green square back !
I saw some people here may have had the same issue ... Could you please detail how you solved your problem ? Would help me a lot :) Thank you very much !
Have a good day ;)
Pascal
pasconat
59
2014/01/10 - 11:54
Additional news !
So I tried official U30GT2 firmware : fail
Unoffical U30GT2 firmware : fail
I tried to reinstall U30GT C4 firmware from here, and flash is successfull.
Now tablet is booting with the same multiple screen boot and automatic shutdown.
So apparently the problem is I can't flash from U30GT C4 4.4.1 to U30GT2 4.2.2.
Any help would be welcome :)
Thank you in advance !
PS : Windows detects it as a U30GT C4 but doesn't find any driver (probably normal)
validatus
Advanced Member
Forum Posts: 180
Thanks Received: 18
60
2014/01/10 - 12:50
@pasconat
what's your cube
bests
80 Guest(s)
Devices in use: Desktop (66), Phone (14)
makaryura
dnjakabssh
KaanFDS
jackthomas
hakhiem
jenom
