[ ROM ] Cube U30GT C4 Android 4.4.1 KitKat custom root firmware (test version dated 2013/12/12)
Jgarciaillanf1
Forum Posts: 35
Thanks Received: 13
31
2014/01/03 - 13:30
Do you know if anyone it's going to make a full aosp ROM with the new SDK? DarthJabba maybe? ;) Hahaha
Regards!
DarthJabba
Forum Posts: 551
Thanks Received: 396
32
2014/01/03 - 15:25
It is not difficult to make a CWM-based installer for it. However, I suspect that a full installation with the Rockchip tools would be required. I also read on a Russian forum that a new boot loader (v2.x) might be required (which would already be in the ROM image). So, there would be no sense in making a CWM-based installer at this point in time.
yoavst
Forum Posts: 51
33
2014/01/03 - 20:19
it breaks my u30gt2!
Error:download idb failed
now my tablet don't even boot up and not recognized by the pc.
how do i fix it?
Pcbrenner
34
2014/01/03 - 23:32
@yoavst
Take this rom
http://www.arctablet.com/blog/forum/cube-u30gt2/rom-cube-u30gt2-android-4-2-2-custom-root-firmware-version-2-06-final-20131029/
connect the tablet with your pc
start rockchip batch tool v1.7
select the update.img from the downloaded zip
disconnect and than reconnect the tablet,
Connected devices should change color to violett,
now you can upgrade.
yoavst
Forum Posts: 51
35
2014/01/04 - 07:19
Pcbrenner said
@yoavst
Take this rom
the color is green and it still prepare idb failed
DarthJabba
Forum Posts: 551
36
2014/01/04 - 10:16
I think you might first need to restore the v1.x bootloader, because the KitKat (v2.x) bootloader is quite different. For this, you will need the RKAndroidTool. It is normally included in 900supersport's ROMS in the freaktab forum - see for example:
http://www.freaktab.com/showthread.php?7963-Cube-U30GT-2-v2-06-20131017-900supersportROM
The instructions are here:
http://www.freaktab.com/showthread.php?8032-Cube-U30GT-2-v2-06-20131017-900supersportROM&p=111209
Installing the 900supersport ROM in accordance with those instructions may well restore the tablet to full working order (you may find the sdcard not formatted though). You can then install Kasty again with RKBatchTool, if you want.
For the curious: what is the difference between RKBatchTool and RKAndroidTool? The batch tool only installs single (i.e., all-inclusive) update.img ROMs. The android tool allows you to select and install individual components of a ROM (when the components have been extracted from the update.img). This is useful where, for example, you only want to change the bootloader, or recovery, or kernel, etc (if you are only changing selected components, then you must NOT click on "EraseIDB" - the command that formats the sdcard - otherwise, you have to install everything).
yoavst
Forum Posts: 51
37
2014/01/04 - 10:25
the problem is that eraseidb take only 3 seconds which mean that it doesn't really erase it.
and then the installation stuck
DarthJabba
Forum Posts: 551
38
2014/01/04 - 11:50
Why not just select only the bootloader first?
yoavst
Forum Posts: 51
39
2014/01/04 - 14:40
it is the same - idb failed
DarthJabba
Forum Posts: 551
40
2014/01/04 - 15:54
Did you try installing the bootloader (or anything else) without first clicking on "EraseIDB"?
I don't know if it will work, but, at this point, your options are limited. Can you boot to CWM recovery?
yoavst
Forum Posts: 51
41
2014/01/04 - 16:21
don't working, and can't reboot to recovery, just to flashing mode..
DarthJabba
Forum Posts: 551
42
2014/01/04 - 19:15
Presumably you have removed any external sd card ?
yoavst
Forum Posts: 51
43
2014/01/04 - 19:55
Never used SD card
DarthJabba
Forum Posts: 551
44
2014/01/04 - 20:46
Sorry, no more suggestions. You'll just have to keep trying.
newbi
Forum Posts: 46
45
2014/01/04 - 22:23
Have you tried to flash a factory not a mod one? and use cubes flash tool?
If the computer is seeing it then it's not borked you just got to find away to flash a rom.
I haven't got mine by me but is there a very small reset hole just below the volume button?
It maybe something else I can't remember sorry.
Oh and don't forget the folder name with the rom in it must NOT be in Chinese you have to rename.
88 Guest(s)
Devices in use: Desktop (75), Phone (12), Tablet (1)
jomama
biggfafa
himikus300483
CyberByte
printerr724
KarlCharlson
