You cannot use the kernel because it contains specific hardware blobs used only by the Cube tablet, which will work only on a identical piece of hardware
CrewRK have started to compile some kernels and firmwares for some tablets based on 3188 chipset, to get more info check this
http://crewrktablets.arctablet.com/.
Also, having an overclockable kernel involves having the code source released, it depends when that happens.
2013/04/04
Ok!
what about this https://github.com/crewrktablets/rk3x_kernel_3.0.36 its the kernel?
yes, that is the kernel but it needs specific things for each tablet
stassen said
Cube U35GT have rk3188 1.8Ghz not 1.6 like most of the 3188 tabs, but now the question! maybe its possible to use kernel or samthing from this to ouer u30gt2 to get them running 1.8Ghz?maybe a stuped question.... who cares
Are you sure the U35GT runs at 1.8 GHz, did you get confirmation from somebody that has one ? is it stable ?
I'm preparing a custom firmware for this device and would could probably put this kernel on the U30GT2 but there is little change that it will boots or work properly as the machines have different specs and hardware.
2013/04/04
No i have read a lot about this RK3188 in russia and china forums, thay say its 1,8Ghz and not 1,6Ghz like other RK3188 tabs..
i just saw thay releas U35GT V1.04 http://www.51cube.com/ch/DownShow.asp?ID=163 take a look on this and see if you can make samthing
Bless
I have double checked, current reviews of the Cube U35GT on the Internet are reporting 1.6 GHz speed, there doesn't seem to be any Rockchip RK3188 device running at 1.8 GHz at the moment.
You may like to hear that overclocking works on some devices, at 1.8 GHz and even further at 1.92 GHz
2013/08/06
Take a look @ http://www.51cube.com.cn/en/ProductShow.asp?ID=229 they are advertising the cube u30gt2 also with 1,8 Ghz! I have one and its only running @ 1,6 Ghz. Also i read somewhere that the gpu is also running only @ 250Mhz not 533 Mhz. So the 3D Graphic speed is as slow as the rk3066. That Sucks!
Hopefully the Kernel Source will be released soon (or is it released?!) So the poor buyers of this false
advertised device can have the features advertised!
U30GT2
OS: Android 4.1
RAM: DDR III 2GB
NAND Flash: 8GB-32GB optional
TF Card Extended: 128MB-32GB
10.1'' 16:9 AHVA screen resolution 1920*1200(1280*800 optional)
Support WIFI: 802.11b/g/n
Support 3G USB Dongle
Support Flash11.1
Support Bluetooth 2.1
Support light sensor
Support Triaxis gyroscope
Support compass
Support HDMI,G-sensor, Camera (Front: 2.0 Mega Rear with Auto Focus: 5.0 Mega)
I/O Port: USB 2.0, Micro USB, TF, 3.5mm earphone, build-in microphone, DC,HDMI
Music: 10 hours, Movie: 4 hours, Browse: 5 hours
Battery: 7200 mAh
Dimension(mm): 10*171*261
RK3188 | 28 nm HKMG | ARMv7-A | Up to 1.8 GHz Quad-coreARM Cortex-A9 | Mali-400 MP(Quad core, 533 MHz) | LPDDR2, DDR3, DDR3L support, up to 2 GB | 2013 | Cube Pea II,[24] Cube U30GT2,[25] CloudnetGo CR9,[26] iMito QX1,[27] PIPO M8pro,[28] PIPO M9,Rikomagic MK802 IV,[29] Ugoos UG802B, Ugoos UG007B, Ugoos MK809 III,[30] Ugoos QC802,[31] Measy U4B,[32] Minix X7,[33] Tronsmart MK908,[34] Tronsmart T428,[26] Measy U4B,[32] Freelander PD800,[35]FNF iFive x2 [36] Vido Mini One |
don't
57 Guest(s)
Devices in use: Desktop (47), Phone (10)
cutierogue
