2013/05/25
When this has happened to you, you will have to open up the cube and make a shortcut between the 2 open connections on the left from the gnd/tx/rx solderconnections on the board. While having the usb cable connected to the pc push the power button untill it restarts and windows will find the drivers again. The rockchip batchtool will turn blue making it possible to restore a img again. You have to keep the shortcut shortcircuited while pushing the power button to make windows find the cube again. This way i have managed to get the cube running again after no connection to the pc at all.
maikalCube u30gt2 tab
2013/05/25
when rockbatchtool gives blue, you can flash any firmware you want. So both the 1st generation bootloader and the 2nd generation bootloader ones. Maybe you have to try it for a second time to make it work. Yes you have to shortcut the two open spaces next to the gnd/tx/rx while pushing the on button. Should work.
Cube u30gt2 tab
2013/07/09
2013/05/25
Cube u30gt2 tab
68 Guest(s)
Devices in use: Desktop (59), Phone (9)
