2013/07/10
PlayerPro worked flawlessly up until the firmware upgrade.
But when I go into settings and Music library to select the target folder I just get "/". And no way to press it and try to change it even if I tick the "Limit library to this folder"-box (or whatever it says, I'm running a translated version).
I've seen that some other people here have had the same problem with earlier versions, but none of their solutions seem to work for me.
I have the latest release, 2.72 and I have uninstalled the program and reinstalled it a dozen times without any difference. With reboots inbetween.
I have also cleared any chaches that I know of.
The music resides on an external SD card but I can't even browse the internal memory.
And it applies to several different firmwares, so it ain't a specific firmware problem. I've tried 2.03, and all test versions of 2.04. All with the same problem.
Fresh installs of PlayerPro on a fresh flashed tablet.
I've posted on the PlayerPro bug forum, but to no avail.
As I understand PlayerPro relies on the Android media scanner, so I guess that's where the problem is.
I've also seen that this seems to be a pretty common issue among other users.
The stock player of the tablet doesn't seem to find any media either.
Any thoughts or help?
Edit: And there's no ".nomedia" file on the External SD card.
Currently Online: ondateste
71 Guest(s)
Devices in use: Desktop (62), Phone (10)
ondateste
lilila3
Anatrop
antoniors021
wemiy54158
sidor
