2013/07/18
hello
my cube came from the factory with a version of sw 2.03 Android 4.2.2
on the back cover there is written that the model is 32 gb
but I read in the settings:
internal memory space totate: 1.97 gb
nand flash, total space: 12.60 GB
might be a firmware problem?
how can I check if there is unpartitioned space?
thanks
Try to re-flash the tablet, if that does not clear the problem, you should contact the seller.
You need to know also that the 32 Gb is used also for storing the Android OS composing from the bootloader, system.img, recovery, back-up, boot.img, cache, data, all these take around 4/5 Gb from the 32 Gb storage.
2013/07/17
Not sur ask your dealer about that.
Need to know what is your original firmware to answer.
But at least you could backup your actual firmware and restore him later.
1)Juste flash cmw without touching at the rest of the partitions.
2) Backup your actual firmware to a sdcard
3) remove the sdcard and flash the firmware of your choice
4) if you want to restore your firmware reflash cmw and restore him
5) juste reflash stock recovery so nobody can tell the tablet was flashed to another firmware
2013/07/18
animehq said
Not sur ask your dealer about that.Need to know what is your original firmware to answer.
thanks animehqÂ
for flash cmw  theres a guide/tutorial or a old thread?
thanksÂ
2013/07/17
The following users say thank you to animehq for this useful post:
rickee
2013/07/18
the cube support wrote:
We sent the cube u30gt2 32GB for you .
Please finish update firmware from http://www.51cube.com/ch/DownShow.asp?ID=150
Maybe some apps in it .
Please finish updated firmware to solve the problem .
For updated firmware guide ,please check the link about http://www.youtube**.com/watch?v=op2RxeBipw4
and http://www.cube-tablet.com/news/cube-tablet-pc-upgrade-tutorial/
I tried to update firmware 1.05
2013/07/18
globula_neagra said
did you used the RESTORE option or UPGRADE ?
the first time I flashed, I used the stock rom 1. 05 and the upgrade button
Then I tried again and the second time I used the stock rom 1. 05 and the restore button
then I tried again using a custom rom and restore the button
2013/07/18
if I connect the tablet to the PC with the vol + button, the tool rockciph marks the square with the color green and I can still flash
but I've done that three times without changing the result.
This procedure writes a succesfull with 0 fail but then I do not see the logo and does not start Android
85 Guest(s)
Devices in use: Desktop (73), Phone (12)
culo1
dfrt
PQNY
chema1971
speedyftp
georgicaa97
