2013/05/25
first, download this "FirmWare_UpGrade_U30GT-2_RAT2.1_SYS950DATA4096LDR210CWM6031_220114.rar" form this site: https://yadi.sk/d/VTIdv9QaDqFZP/ImaSoft/FirmWare, extract it and flash it to the cube.
Then download this rom, the one most below: https://yadi.sk/d/VTIdv9QaDqFZP/ImaSoft/%D0%9F%D1%80%D0%BE%D1%88%D0%B8%D0%B2%D0%BA%D0%B8
copy the zip file to external sd card.
Now you can enter cwm mode and install the zip file. After installing it you must make a factory reset, otherways it won't work. Then reboot selecting yes to recovery disable. Wait bout 80 seconds and voila you're in android menu.
Cube u30gt2 tab
2013/05/25
merde, the tab is in bootloop with the new rom when i reboot through the rebootapp. Possible this is because of the 2nd gen loader installed for the 1st gen firmware. So the second lowest firmware is a 2nd gen firmware, try installing that one with the manualdescription above.
Cube u30gt2 tab
2013/05/25
jellybean loader is a version 1 loader right?
*edit: if using a gen 1 loader, the installation goes very slow( latest jellybean ami firmware). Now trying the 207 loader. Not working either. Can't get that latest firmware based on jellybean to work.
the one that is working, antutu benchmark score as usual.
Cube u30gt2 tab
2013/07/09
2013/05/25
maikal said
That's pretty confusing Mark. Start from the top and break it down for us again.
It is a special flash 'image' that prepares the cube for installation of the actual firmware. Actually it takes care of installing the right cwm recovery for the newer firmwares. Then if you like to install the latest firmware, you have to install it as an upgrade of a previous firmware. That said, my former post has the right downloads for installing the latest firmware. It's all bout overclocked firmwares. The preparation file, is extractable and contains androidtool, which for flashing the preparation files to the cube. The other two files are zip files installable through the (with androidtool) installed cwm. The first is an update, the second an upgrade.
Grtz mark
Edit; the latest firmware is overclocked and either gets to hot or to little voltage for the cpu, reboots in antutu. Lowering the freq from 1800 to 1608 is a remedy. No lag in the image like the secondlast firmware though.
maikalCube u30gt2 tab
2013/05/25
You can change the kernel, with the files in this file:FLASHER_v2.23_ADB_FOR_U30GT2. If you like to use a patched(overclocked) version, you have to install the normal version (also in the datamap) first. Those are all old jellybean 4.2.2 kernels from back 2013. Seems jelly bean(jb) rom 4.4.2 isn't quite well for overclocking. Antutu benchmark will give a hard reboot. Maybe kitkat(kk) rom is better for overclocking.
PreInstallation of firmware, also know as installationfiles for adapted CWM:this file ------>androidtool zip file,install from pc
Then the firmware android 4.4.2 based on kitkat kernel:this file ---->CWM zip file, install from tab holding vol + and power
Then you can upgrade the kitkat kernel based 4.4.2 firmware:this file ---->CWM zip file, install from tab holding vol + and power
2013/05/25
if you like to have the phone removed from scratch, you can open the zip file of the firmware and remove next apk's:
-\system\app\
telephonyprovider.apk
stk.apk
picotts.apk
-\system\priv-app\
mms.apk
teleservice.apk
2013/05/25
am using a t13 kernel. Now 93 % battery and 17.14hrs runtime, leaving the tab in standby for one night. There is also t8, t10, t13 overclocked, see here. Just extract and flash the kernel.img with androidtool.
All the neede files, like described in this topic, here. The firmwares are without phone stuff and sleek.
Cube u30gt2 tab
148 Guest(s)
Devices in use: Desktop (143), Phone (5)
