2013/07/09
Okay so the latest news from my tech friend is that the lcd for my U30gt2 Cube is damaged by the now replaced bloated battery. Its still working but its got multi-colored lines running horizontally across the screen, some web pages are pink!
I am looking for a new replacement or even a non-working cube to extract the lcd. I don't want to get it from china if possible, though that is the current option I could find on the alibaba site, I'm just not trusting that it would get to Florida in one piece and then I have to deal with returning it. Any ideas? For a second or third hand cube? Is there a second hand store anyone can point me to, or is someone on these forums whose cube is not working but their lcd is and would like to sell it? I am willing to pay postage, so long as it' reasonable! Please let me know. Please pardon me if this is not the right forum for this Admin, if you would advice where it could go instead. I have tried eBay, amazon and geekbuying.com, and will keep trying for now if no one can offer solution.
I do have a tech question, is there another tablet with a comparable lcd? Meaning must it be a u30gt2 lcd or can I search for an lcd from another tablet? Thank all in advance.
2013/07/09
2013/07/09
Mark06 said
Can't you get à used cube which is broken. For the Parts ?
Indeed, I would love to find a broken Cube. I've spent the last 3 days scouring and searching the internet looking for a broken Cube, or any acceptable option. All I can find is the Chinese sites on Aliexpress. I may have to settle for them if I can't find one soon.
2013/07/09
Admin or Oma, or anyone that may know. is there an LCD screen from another model tablet that is comparable to the LCD inner screen of the u30gt2? I have looked everywhere for the LCD but I am unable to fond one outside of China. If there is no choice from another tablet I guess I may go ahead and bite the bullet and take a chance on getting it from China. Thanks in advance.
I cannot recommend to order such things from China. This will high likely end in non compatibility.
Go for a used U30GT2 or better for a successor.
2013/07/09
I cannot recommend to order such things from China. This will high likely end in non compatibility.Go for a used U30GT2 or better for a successor.
Sorry Oma, to make sure I understand. You do not suggest I order a replacement LCD screen for the u30gt2 from china at all? Or are you suggesting I don't order any LCD at all from china? Even from a vendor on Aliexpress? I am trying to find a used/or parts from a cube, but alas no luck. I did have luck with batteries, they worked fine, that's how I found out about the bad LCD. Aliexpress has an eBay like policy. I saw 3 or 4 vendors for LCD, from $65 to $87 US. But like I said, still looking and hoping for used one.
Well, there is a specific screen which has a specific driver into your kernel. Often identification codes shown up in the dmesg logs are not the same identification codes seen when open the tab. It is high likely that different batches of the tab have different hardware components. Identification codes are often not unique. So, what does that mean when you found a product from a Chinese vendor which claims it is for a Cube? A battery is on thing, a component which needs kernel support another.
Just my 2 cents.
2013/07/09
Well, there is a specific screen which has a specific driver into your kernel. Often identification codes shown up in the dmesg logs are not the same identification codes seen when open the tab. It is high likely that different batches of the tab have different hardware components. Identification codes are often not unique. So, what does that mean when you found a product from a Chinese vendor which claims it is for a Cube? A battery is on thing, a component which needs kernel support another.Just my 2 cents.
Your two cents goes a long ways in my book Oma! If you don't think its a good idea then I'm not fooling with it! Not just yet anyway. The good news is that I just picked up another cube u30gt2 on ebay for $83US, so I am not in any desperate hurry now I will continue to look for a replacement from a used cube for now and hope to find it to repair my damaged screen if possible. On the good side, since the lcd still works a bit I can use that cube to continue trying new roms before trying them on this new one coming from eBay!
Mark06 lol I saw that sexy beast for auction starting at $153ZUS on eBay, and though I can live without the hdmi that its missing I just don't have the $153US to plunk down on it! I don't think it may go much higher, But here is the link in case anyone else is willing! I have to buy a new/used phone!
http://www.ebay.com/itm/271682513630?_trksid=p2060778.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Just for documentation purpose, at least two different LCD's:
- CLAA101FP01
- B101UAN02.1
2012/11/14
I found a cube U30GT2 LCD screen here with free shipping in the UK, and further up this topic is two numbers for cube u30gt screen the one with the number B101UAN02.1 is wrong (OMA??) because if you look at the connections for the cable it is on the wrong side of the screen and it is not for a cube u30gt2 it's the wrong connection they changed them from the cube u30gt-h and gt1, "LOOK AT THE PICTURES" the first one is the difference in the two connections, The second is a GT2 and the third is a GT1. http://www.ebay.co.uk/itm/10-1-INCH-TABLET-REPLACEMENT-LCD-SCREEN-FOR-A-CUBE-U30GT-2-ONLY-/161743069969?ssPageName=STRK:MESE:IT
78 Guest(s)
Devices in use: Desktop (77), Phone (1)
revoltown
tdomnic024
otismaibe
Tsuna77
docentik2006
