2013/04/25
I bought U30GT2 yesterday and today I found something weird on mine.
I can power on and power off by pressing power button 4-5 seconds so I can tell it works godd and physically no probsÂ
The weird thing that I would talk is it won't go sleep when I pressing it softly. Also wont wake up after screen off even I press the power button.
Anyone has the same problem with me? help plsÂ
2013/04/25
Didn´t happen to me, yet.
You could workaround it for the time being with disabling lockscreen and assigning wake up to the volume keys, no idea though if that option is in the rom. it is in cyanogen, so even if not there should be an app for that
Or it´s a problem with the rom installation, maybe you should consider giving the 1.05 or the 4.2.2 beta a go...
2013/04/25
ecki2k said
Didn´t happen to me, yet.You could workaround it for the time being with disabling lockscreen and assigning wake up to the volume keys, no idea though if that option is in the rom. it is in cyanogen, so even if not there should be an app for that
Thanks Mate,
I had tried:-
1) Upgraded to 4.2.2 and downgraded to 4.1.1 several times but nothing has been improved. Still unable to sleep/wake up with any buttons.
2)Â Edited Keypad.kl and assigned WAKE_DROPPED on volume buttons and reboot but which also not working too.
There is still no way to wake the screen up and turn to back on, I am still reboot the system when the device are into sleep moed......Â
82 Guest(s)
Devices in use: Desktop (71), Phone (11)
Nursat
MaXXWar
adison
Zenn
nicl
FreddyBerlin
