muting sound for longer battery use
I have the idea that putting the volume to mute is extending battery life for very much
Mark06
Forum Posts: 222
Thanks Received: 41
2014/12/09 - 10:33
Goodday,
now i have set the audio to mute on the cubeu30gt2, the battery shows charged while it has been on for like 3 hours. Normally that seems like kinda impossible. So is it right that sound eats a lot of battery?
greetings,
Mark
Cube u30gt2 tab
Mark06
Forum Posts: 222
Thanks Received: 41
2014/12/09 - 16:11
The battery keeps lasting long. Is there a way somebody can make use of your webcam? And is there software to turn the cam off? I have the cube with 13000 mah battery on for like 7 hours and only like 3 percent used. Normally it would say something like 70 or 80 percent. Can't believe the battery lasts that long.
1 percent per hour.
Cube u30gt2 tab
cio
2014/12/19 - 18:26
1 percent per hour.
Are you serious? I've changed my batteries too, and tried many roms and kernels, and I'll be happy if it will last 3h. Can you tell us what rom and kernel do you have? Please tell us if you have made any trick to improve the battery.
Thanks.
Mark06
Forum Posts: 222
Thanks Received: 41
2014/12/19 - 19:21
well it seems the battery is actually charged to percent level above 100 percent. Will try some things and let you know.
Cube u30gt2 tab
74 Guest(s)
Devices in use: Desktop (70), Phone (4)
