2013/06/06
I have read through a number of online posts here and elsewhere. It seems that I must first root the system, then install Arctools (which version?) and then CWM before flashing. I am not sure about if this is the right order, and whether I can skip the earlier upgrades (4.2.2, for example) and go directly to the newest available firmware and OS. A summary of the major steps would be helpful to me.
2013/05/25
you can install through usb via rockbatchtool. Just download and extract the chinese rom from 30102014. Then use wmshua to root it and if using the overclocked rom use build prop editor from the market to set rotation degree from 270 to 0 or 360 degrees.
Cube u30gt2 tab
96 Guest(s)
Devices in use: Desktop (87), Phone (9)
JEssicannn: 279
AnnaStockm
IAmTheOne86
tkowalski
Devlin
gitidi3813
goliad
Topics: 6129
Members: 266802
